Bose AW-1 won't turn on
When the power cord is connected, the system won't turn on. Even when the power source is switched to the carrying case's battery pack, the system still doesn't respond to the power being turned on.
  • Cisco K
    Cisco K Jan 01, 2014
    This posted in the laptop section, when it should be in the Bose Radio section. Sorry for any confusion.
  • 1,511 Answers
You have made an attempt to power up using both forms of energy. Generally, the indication is an internal power failure on the circuit board itself. If when previously used, a power surge damaged the 1st stage section, a shot may occur and render the unit useless. The only way to know for certain is a bench testing of the unit in question.
Posted on Jan 03, 2014
micromend
  • 748 Answers
SOURCE: Dell Inspiron 6400 won't turn on
When lithium batteries discharge past 1.5 volts they can cause havock. Take the battery out of the system (if this is the one that discharged I would throw it away), disconnect the AC and try turning on the system. Of course it won't come on but If there's been a clitch, this tends to clear the system. Then put in a fresh battery and connect the AC. If this doesn't work then buy an external box for your present hard drive and connect it to your new computer to get your data.
Posted on Jan 05, 2009
  • 148 Answers
SOURCE: Acer 5520 power shutdown
Possible heat issue. Check the cooling fans and see if theyre running. Usually one on the bottom, back or side of the laptop. Make sure that the cooling vents arent blocked during use.
Posted on Apr 04, 2009
venexcsd
  • 1185 Answers
SOURCE: Won't turn on even with power cord plugged in
By dumping the power while running you have trashed your Operating System or blown up the Ram
Insert your OS disk and see if it comes to life , if it does then you may have to try a repair from the OS installation CD
If you have popped the Ram then the only solution is to get it checked out on another PC
Posted on Jun 02, 2009
  • 14 Answers
SOURCE: Dell D600 will not switch on - tripping power sources
First thing to try is another power supply. They go out. They run at less effenciecies sometimes, and other times they just stop. The inverters get really hot when we use them for a while and they usually get banged around a bit too. When they heat and cool repeatedly, the chips inside expand and contract and over time they crack their soldering in the boards and they lose contact. If one were to have come loose all together and have bounced around inside until it caught on something, that could be your short. Something could have just gotten into the cooling vents on your power inverter too if it has them. Try swapping out with someone else that has a Dell if you can to see if it works, or take it into a repair shop and ask them if they can check it with a good inverter for you. I would think any decent repair place should do this for you at no charge and it would take them 2 min. You can find universal ones for much much less than a standard Dell replacement as well if that's what it is. I know the Dell OEM inverters are over $100 and universal replacement ones are from $25 to $40 on average.
Posted on Jun 09, 2009
  • 3278 Answers
SOURCE: Notebook cannot power up
Any lights on the A/C power adapter ?? If not, then the power adapter is faulty. If the adapter is OK, the power connector on your Lifebook is faulty. Good luck
Posted on Jun 21, 2009
Won't read, play, or store music.
Performing a product reset To reset your system, follow these steps:
  1. Turn your system off. Wait until "Saving your music information" disappears from the display
  2. Unplug the Acoustimass® module power cord from the power outlet
  3. Wait 60 seconds
  4. Plug the Acoustimass module power cord into a working power outlet
  5. Turn the system on
Note: After the reset, wait several minutes before playing stored music (stored music may not be immediately available depending on how many CDs have been stored). All other sources are available, immediately after the system is turned on.
Feb 06, 2016 | Bose 3 2 1 GSX System
Bose power cord for subwoofer
This could be one of three problems:
1) The on-off switch may be going bad.
2) There may be a cold solder connection breaking loose where the power cable attaches to the circuit board.
3. The plug part of the power cable could be faulty. The wires intermittently separate from the connection in the plug.
May 01, 2014 | Bose Audio Players & Recorders
Bose av321 video settings won't display on tv
Make sure the video output from your Bose System is connected to the right input source of your tv.If it does not work,try using a different remote control.If it still doesn't work,then you will need the service a Bose repair technician.
Jan 28, 2013 | Bose Av3-2-1 Series Ii Media Center...
AVR 1600 receiver won't connect to bose series III EQ
You mean BOSE 901 Series III Active Equalizer; and HARMAN KARDON AVR1600 right?
Sure it will. It goes in a Tape Loop such as Tape Out/In or Video 1 Out/In. But it won't work for anything except analog stereo sound sources as all digital audio is not available to the RECORD OUT jacks when the Tape or Video 1 is activated. AND 901 Active EQ is intended solely for 901's, not any other speaker system
The HK has no Line Level volume-controlled Pre-Outs so you're out of luck if you want the 901's to take part in a multichannel setup, which would require a separate power amp to drive them anyway.
Aug 23, 2011 | Audio Players & Recorders
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
There is a cd stuck in the system how do i get it out
This solution is from the troubleshooting section of the manual:
• Follow these steps:
1. Turn off the unit.
2. Unplug the Acoustimass module power cord from the outlet for 60 seconds, then reconnect it. This
allows the unit to reset itself.
3. Before powering on, press and hold Eject on the media center.
Hope this info may help you!
Mar 10, 2011 | Bose 3·2·1 II System
I am experiencing distortion on my bose lefestyle 38. I only notice when playing dvd's or hd channels that have 5.1 sound. Any ideas?
Completely power down the system, by first turning it off, then removing the power cord from the wall socket. Wait a minute or two. Then, reconnect the power, and turn on the system. This should clear up the problem.
For future reference, it is good to use a top-quality surge suppressor, at the power source, to protect your Bose Lifestyle sound system.
Dec 29, 2009 | Bose Lifestyle 35 System - black Theater...
Older Bose 321 will not eject. Has humming sound when power cord
if the power cord is to close to other cables or the duct work in your home the interference alone will cause electronics to do wierd things ,start there.
Aug 19, 2009 | Bose 3 2 1 GSX System
Bose 321 Series III Lateness
This depends on the source. If this happens internally (from a DVD in the 321) then the problem should be able to be resolved by just resetting the 321. (unplug the power cord from the sub for 30+ seconds) -If this is from external sources like a cable box, believe it or not, you can reset the cable box the exact same way. If resets don't fix this (and this is external) then check the cable box's settings for a/v delay compensation.
Jun 19, 2009 | Bose 3 2 1 GSX System
Bose lifestyle fault code 802
Here's what the Bose support website suggests.  Good Luck!
Messages displayed during a Music Information Update
Messages may appear on your media center display during a Music Information Update. If you see a message with instructions to call Bose, and a three-digit code such as "Error Code 802" or "Failed 172" while performing a Music Information Update, it does not necessarily mean there's something wrong with the system. Performing a media center reset and installing the update again may address the issue.
To reset your media center, follow these steps:
  1. Turn the media center off. Wait two minutes
  2. Unplug the power cord from the media center. Wait 30 seconds
  3. Reconnect the power cord
  4. Wait until "Bose Lifestyle" disappears from the screen
Note: After a reset, you will need to wait several minutes before playing stored music (3 to 20 minutes, depending on how many CDs have been stored). All other sources will be available immediately after the system powers up.
If you have any additional questions about these messages, please contactBose® Technical Support or call 1-800-278-1281.
Dec 01, 2008 | Audio Players & Recorders
Computers & Internet Logo
David Payne
David Payne
