Question about Brookstone Stunt Copter RC Helicopter
No main mottor power
The main propeller will spin but very slow even at full throttle the rear propeller still has normal power. what do i do?
Why can't i get my scooter to move it has full power.
Even though battery meter is showing full voltage, does not mean the batteries are necessarily capable of propelling the scooter. Have you had the batteries capacity tested? When you press the throttle does it beep or flash to indicate a fault? Is the solenoid brake clicking is it making any noise at all?
Jul 21, 2014 | Invacare Lynx Lx-3 Scooter Model...
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Minn kota e drive
I may can help. First, sit down and sip on a cold one. (coke,beer,ice tea,ect). Please send me model of unit including all options. I will research unit & reply ASAP. Maybe just a bad connection internally.
Aug 04, 2013 | Boating
I cHarged the helicopter and can get the directional Propeller to spin but cAnnot get the main throttle proPellers to spin. Help
try to play around with the trimmer.. i had the same problem but then guessed it was the trimmer and iwas right!
Dec 25, 2010 | JCPenney Gyropter RC Helicopter
Tines run slow/stop even when engine is at full throttle
What is the task you are doing with the tiller? There are some uses where the tiller will stop.
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
Is this engine normally slow on pull of?.... on d 4x4 models ? is it easy to disconnect the transfer case and vehicle to function normaal without 4 wheel drive?
Slow? Depends on what you are pulling? Is it just the truck itself? Or are you trying to pull a backhoe? The only thing you will disconnect on the transfer case is the propeller shaft, and it will run fine, but I don't think you will gain anything by it. The transfer case does nothing till it is engaged, it doesn't even spin, the power goes through to the rear, untill you put it in 4 wd, Hope this helps.
Mar 14, 2010 | 1997 Nissan Pickup
Hi I have a 2009 Yamaha SHO i were just wondering why can you still hear some parts of the motor spinning after you have shut down the motor..
It is the supercharger slowing down from its high spinning cycle. Dont worry about it, because it is normal. Trust me, I asked the same question on my 2008 SHO. You have the same motor I do.
Dec 23, 2008 | Yamaha 12V Air Pump
Brookstone Stunt Copter RC Helicopter Logo
Top Brookstone Electronics - Others Experts
Are you a Brookstone Electronics - Other Expert? Answer questions, earn points and help others
