Goodman GNP075-3 seems to work fine but air coming out is only about 46 degrees
Air filter new, nice blue flame, blower comes on but cool air comes out
  • 2 more comments
  • viethsr
    viethsr Jan 01, 2014
    I did notice that there is a solid red light on the control board
  • viethsr
    viethsr Jan 02, 2014
    according to panel solid light indicates normal operations
  • viethsr
    viethsr Jan 06, 2014
    This unit is in the garage and the return is wide open with only a filter on it. It has 2 outputs on the top of unit, 1 is about 8 ft, the other is about 18 ft long.
  • viethsr
    the air that comes out seems to match the air temp coming into the return. If I heat up garage with a heater then the air coming out is warm as well.
    Master:
  • 571 Answers
Check to see if the return duct has come apart in the attic or in the crawlspace (wherever the return is connected)
Posted on Jan 06, 2014
Therinnaiguy
  • 1420 Answers
SOURCE: goodman heater
Depending upon your installation the filter could be located in the bottom section of the furnace right or left of the blower, remotely located in its own housing in the return air plenum or it may be missing altogether. If you can find a spot to put one in, do it. You may just have to reset your thermostat. Some models have a pre-timed indicator that comes on after a number of hours reminding you to check your air filter. Post the model number of the thermostat and maybe we can help you reset the timer.
Posted on Nov 12, 2007
SOURCE: Goodman Heater Blower Not Coming ON
The Ignitor on my furnace glows and fades. I do not hear anything blowing either as I watch the ignitor get bright orange..then fades.
Any answers? I tried to look here on this site but have not seen anywhere where there is a solution. I was going to replace the entire gas valve assembly because I am guessing the problem is with the coils sicne the ignitor fades away.
Help please?
Posted on Dec 16, 2007
aries_67
SOURCE: 1993 goodman status light 4 times blinking
I have a goodman GMP075-3 that won't turn on. I think it is the pressure switch since I do not have a vent blockage. What is a venter and where can I find it??
Posted on Dec 30, 2008
  • 51 Answers
SOURCE: Goodman GMH950904CXAC
make sure the blower is not set on rather than auto or the blower will run all the time. You might want to disconnect the thermostat and test the low voltage circuit to make sure the wires are not shorted
Posted on Aug 12, 2009
co7196
  • 3433 Answers
SOURCE: I have a Goodman GMPN120-5 furnace that has flame
I hope this helps you_Ned
http://www.fsti.com/rollout.htmd
Explains flame roll out. :)
Posted on Oct 07, 2009
I have a goodman model gms80703ana the burner comes on and when the blower comes on the burner goes out.
This can be due to a dirty flame sensor or a high limit switch tripping. Clean the flame sensor first, this is a metal rod on the opposite side of the igniter, take steel wool and scrub it, then reinstall. If this does not work then the limit switch is tripping due to dirty filter, dirty blower wheel, weak blower motor. Aything that restricts airflow will cause the limit switch to trip.
Nov 30, 2012 | Goodman GMS807034ANA Heater
Central air only blows a small amount of cool air out the vents. After running 12 hours it only cooled my small 1BR apartment 3 degrees. The filter has not been replaced since October 2009 but I can't seem...
I have a Goodman A/C unit APRF036-00B1. The out side unit seems to be sucking and bowing air, the coil is cool to the the touch and the blower seems to be turning. I've check what seems to be the obvious. A small amount of air is only coming out. Any suggestions?
Feb 21, 2011 | Goodman CKL36AR36 Air Conditioner
Goodman GMT045-3A Furnace. Furnace flue fan always on, glow plug hot, gas ignited, on for 20-30 seconds, click is heard, flame off, glow plug cools. Then cycle repeats over and over again. Sometimes...
Check filter to see if it is plugged. Has someone installed a new thermostat? If so, it may not have been installed properly. Sand off sensor to make it shiny, and be sure all supply and return registers are uncovered.
Jan 03, 2011 | Heating & Cooling
My Honeywell AC unit doesn't seem to be working properly. It will not retain a temperature. I set the thermostat to hold a temperature of 70 degrees. Room temp still reads 74 degrees. Something is working,...
The frost on the pipe indicates you have a dirty filter, dirty evaporator coil, Blower not running at the proper speed (to slow) or you are low on refrigerant.
Jun 29, 2010 | Heating & Cooling
Have a Goodman GMT070-3B which the vent motor seems to be sticking. I took apart and cleaned the brushes and reassembled. The furnace will come on only after what seems like the vent motor comes up to...
The whole assembly must be replaced.
The sequence of operation is -
Combustion fan purges the heat exchanger. A pressure switch verifies combustion air fan is running. Usually a 30-45 second purge before the hot surface ignitor glows, or the spark ignition starts.
Gas valve opens after 10-15 seconds and main burners light. Control board monitors for flame and shuts gas valve after 2-3 seconds if main burner does not light.
If burner does not light, some boards repeat this for 3 tries, then locks out and is reset by cycling power.
Air blower comes on after another 30-45 seconds after main burner ignition.
Times may vary based on the specific controller board. A flow chart and timing sequence should be located somewhere on the unit, usually in the fan compartment.
Dec 16, 2009 | Goodman GMS90703BXA Heater
The heater is blowing cool air. The furnace blower keeps running and something ignites and then goes out immediately. any suggestions?
Clean or replace the thermo couple.
It must detect a flame a few seconds after the main gas valve opens or it shuts it down. Since you are hearing the burners fire up the ignitor is working and all the other safety circuits are working to allow the furnace to fire up.
The thermocouple is a small silver tube that protrudes into the flame of the main burners, remove it and scrub with scotchbrite pad or anything mildly abrasive. You just want to remove carbon and corrosion build up, re-install and see if it fires up.
I have two Goodman furnaces and if you are to maintain them your self you should keep on hand a thermocouple and a new ceramic ignitor. They will inevitably fail on the coldest weekend of the year and the only place to get them will be from a service company with a emergency service call ...$180.00 VS $60.00 off ebay or internet sales.
Also if your power vent fan is making ANY noise it is on its last legs and buying on in advance online will save you about $80.00 over the loca ldealers price......been there done that
Oct 24, 2009 | Goodman GMS90703BXA Heater
Goodman gas pack,stopped working,replaced batterys in thermo,board looks good.can reset temp,switch,will run 5 minutes or so.could jets cause flame to wander? not serviced in 2 years,board,temp,switch and...
What switch are you resetting? If it's a limit or roll out then first check for proper air flow (filter, A/C coil) to see if it's overheating. Then watch the burner flames. When the blower comes on do they change shape, color or waiver? If so you may have a cracked heat exchanger.
Mar 31, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
