Question about Toro Snowblower 826 Oxe 38624w With 3 Year Warranty26 Inch 9 Horse
Only runs with choke open - Toro Snowblower 826 Oxe 38624w With 3 Year Warranty26 Inch 9 Horse
Cold choke baffle has 3/16 opening minute I pump accelerator choke thermostat closes primary baffle shut no air to start I force choke open to start why insufficient air to run at high idle?
Your engine probably has an automatic choke device that adjusts automatically with engine temperature. To set the choke when the engine is cold you have to depress the accelerator to the floor and release it completely. You shouldn't have to depress the accelerator again to start the engine, turn the key the engine should start. As the engine begins to warm up it will also begin to initially run faster then it will start to run rough. At this point you have to press the accelerator and release it again. The auto choke mechanism should allow the choke butterfly to open. There may be a number of stops in the system and the choke butterfly will stop again still not fully open and only become fully open when the engine is at operating temperature. Hope this answers you question, Rgs. Bob
Jun 21, 2015 | Cars & Trucks
Got spark good compression. and fule. electric choke. but wont stay running when cold.
The electric choke may not be getting power. The power wire for the electric choke is usually connected to the ignition "on" switch. When the electric choke coil is energized it will open the carb choke plate completely after approximately 3.5 min. Some potential problems could be: 1, The electric choke is getting constant power and therefore is always open or has no power. 2. The carb choke plate needs to be adjusted or the plate hangs up when opening or closing.
Mar 02, 2015 | Motorcycles
Automatic choke will not shut off once the engine is running so engine dies. Could it be a spring is missing ?
There is a diaphram that the link connects to the choke. It is between the carb and the gas tank, and runs by the vacuum from the engine. B&S engines have to rev up for the choke to open all the way.
Sep 20, 2014 | Cub Cadet Garden
My hmc green machine 3000ss weed wacker carb needs adjusting it only runs with choke closed
Try cleaning or changing the air filter. If it dirty the engine will not stay running with out the choke on.
Feb 17, 2014 | 2010 Vuka XL 125
Acts like the choke is stuck closed it won't stay started and runs ruff until engine warms up then its fine. What do i do?
Well the choke has an electric part that heats up and makes the choke open in a few minutes. As soon as the engine starts the choke should open about 25 percent by way of a vac pull-off.
You can take the air cleaner off and watch the choke while someone starts the engine cold. If the choke does not open after it starts, check the choke pull-off. You can also open the choke with a screwdriver to see if the engine clears up.
Jan 29, 2013 | 1987 Chevrolet Caprice
The saw will start with the choke open, but when you close it, it goes dead. why?
I'm confused you said your saw will run with choke open, that is how it's supposed to run,or do you mean it will only run with choke closed?
Apr 24, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What's the best choke setting for starting a cold generator
Full choke to start, open choke partially immediately the engine starts to where the motor runs smoothly, continue opening as soon as you can while keeping the engine running smoothly. Be sure to open fully before leaving the unit, running it with the choke partially on can cause a rich fuel condition which tends to wash the oil off the cylinder walls and it also dilutes the oil with gasoline.
lp
Dec 26, 2010 | Coleman Powermate Portable Generator...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Stalling out
Generally with two cycle engine as soon as the engine starts the choke needs to be moved to the off or open position. Some chokes have a middle position that lets the motor run until it is warm enough to move the choke into the open position. In other words weather it is a two or four cycle engine the choke is used only to start the engine. If you unit is newer and still does not run well with the choke in the open position, you may need to adjust the hi-speed circuit to a richer one.
Jul 13, 2009 | Troy Bilt Tb70ss Gas Trimmer
Toro Snowblower 826 Oxe 38624w With 3 Year Warranty26 Inch 9 Horse Logo
20 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
