Question about Meade ETX-60 AT Telescope
My meade remote contol won't turn on
I'm starting it up for a friend the batteris were fried. there is some corrosion. i celaned it up put in new batteries, no response.
Car won't start and starter is only making clunking noise
You can take out the spark plugs, keep track of your spark plug wire order, try to crank it over see if the engine turns over.
Check voltage on your new battery, some need to charge when new.
check for corrosion on the battery and starter cables.
Sep 29, 2012 | 1991 Saturn SL1
Remote with new batteries won't work
Even after replacing new battery cells only ON/OFF button responding and other buttons are not responding. Pl suggest how to solve it
Jul 15, 2012 | LG LSC121PMA Split System Air Conditioner
My ETX-60 remote turns on but immediately turns back off, ive tried new batteries but it still turns right off, the red light on the telescope stays on but the remot doesnt, any fixes?
About the only thing you can do is buy another hand controller-- contact Meade for a new one.
I am assuming the hand controller cable cannot be replaced check it anyway and see if you can get someone to replace the plastic plug that goes into the telescope on the cable. Sometime these go bad. Any "network" cable guy should be about to replace the end.
http://www.meade.com/support/index.html
Feb 20, 2011 | Meade ETX-60 AT Telescope
Motors won't turn
Are the batteries FRESH? if they are you may have a bad motor. Contact Meade customer service:
It sounds like BAD batteries. Try new ones first before sending it to Meade.
May 15, 2010 | Meade 114EQDH4 (36 x 114mm) Telescope
The circuit board that holds the batteries for my ETX is corroded and I need a new one. How can I get one?
Is the problem that you left the batteries in the battery compartment? (a no-no, BTW.)
If so, you might get away by cleaning the board--if the circuit traces and components haven't been damaged.
Try mixing a tablespoon of backing soda with a cup of warm water. Using whatever applicator seems appropriate--a Q-tip, or small brush--clean the corrosion from the board with this solution. Wipe and dry thoroughly.
Inspect the board for broken circuit traces and damaged components.
If nothing is obvious, put fresh batteries in and try it--it will work, or it won't.
If it does, congratulations. If it doesn't contact Meade customer support at this link: http://www.meade.com/support/index.html
Good Luck!
Mar 25, 2010 | Meade ETX-90 (48x90 mm)
Can you turn on a tedelex ec2975 tv without a remote control?
did you put new batteries in the remote? is the transmitter lens on the remote clean?(on the front edge). is the pick-up window on the t-v clean? (probably a small plastic rectangle to the right or left of the bottom controls). check it out!
good luck!
Oct 04, 2009 | Panasonic CT-36SX31 36" TV
My MEADE etx 105 telescope remote wont turn on but my telescope will. Can you tell me what my problem is please.
Could be just a bad hand controller cable. Check with Meade for a new one.
www.meade.com
Sep 24, 2009 | Meade Optics
E39 starting issues
HAVE YOU HAD THE BATTERY TESTED? ARE THE BATTERY TERMINALS/CABLES CLEAN AND FREE OF CORROSION? ARE THEY TIGHT?
Jul 09, 2009 | 2002 BMW 5 Series
IT WILL NOT TURN ON AND WE TRIED NEW BATTERIES AND STILL WON"T TURN ON
If it won't power on, this likely indicates that your motherboard is fried and needs to be replaced. Have you tried connecting to a wall charger? If you connect it to a wall charger and it STILL doesn't power on, then your motherboard is fried for sure.
Oct 13, 2007 | Creative Labs Zen MicroPhoto MP3 Player
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Meade ETX-60 AT Telescope Logo
46 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
