Question about Dewalt Planer (DW734)
Chain feed skips - Dewalt Planer (DW734)
    Master:
  • 550 Answers
Chuck or worn chain cog
Posted on Apr 08, 2014
Arctic cat snowmobile drive sprocket chain skippin
I am assuming you are saying that the Drive Chain is "SKIPPING", inside the Drive Chain, there is OIL and a External Chain Tensioner. Adjust the Chain Tensioner to take care of your Problem of Skipping...
Feb 16, 2014 | Toys
Dw734 planer problem
You have badly worn-out sprockets, or you have an idler sprocket that's missing or very badly out of adjustment. It's possible that your chain has stretched beyond recovery, and needs to be replaced.
Jan 01, 2014 | Crafts & Hobbies
Just purchased bike and chain skipped under load
very likely that chain links not "fitting" cog teeth . if both chain and cogs are brand new, then skipping should never happen. more often than not, a repair would require both new chain and new rear cogs, and possible new fron t chain wheel. all depends which item are worn. I would probably get a new chain firstly, then see if this fixed the problem. nigel
Jul 06, 2012 | Specialized Hardrock Pro Disc
My chain is skipping on hill climbs
Skipping chain is usually caused by either one or two tight links, or a worn chain.
This is assuming the derailuer is in good condition and not bent or damaged.
Chain and sprockets need to be replaced as a set as a new chain on old sprockets can also slip.
Turn the crank backwards slowly and you wiil see if there are tight links as it goes through the small tensioner wheels
Aug 27, 2011 | Shimano Dura Ace Di2 RD-7970
My chain skips
there may be a tight chain link, if you turn the crank backwards you may see the problem. then work the link back and forwards until smooth. and apply some light oil.
The other reason can be a worn chain and sprocket, if it has been ridden a lot.
Chain and sprockets must be changed as a set, as this can also cause skips if only a new chain is fitted.
Aug 12, 2011 | Shimano Cycling
My Makita 2012 planer 'skips' making a 'machine gun' sound and the wood won't feed through. I think it's the 'plane bearings', but I'm not sure. Does this sound right?
Have you cleaned your rollers? I must admit, I'm having this problem with my 2012NB, I HAVE cleaned the rollers (with ethanol), and have taken the side covers off, and the drive chain and gears look just fine, as does the primary drive belt. I ran the planer with the covers off, and although the gears and belt seem fine, the planer still skips (or slips). I think probably your blade is dull, creating drag (I replaced mine not long ago, but have been planing a lot of rough lumber). I still haven't gotten to the bottom of it, but I think the rollers are slipping, I just don't know why yet.
Feb 02, 2011 | Makita 2012NB Electric Planers
My crank/chain is skipping on my mongoose pro bmx. This just started when I was riding it, and it skipped. The chain is in the right right place and does not seem to be skipping place, but the crank is...
It seems you will need more tension on the chain. Place the bike upside down, loosen the nuts, grab a broom stick or bar and place it between the rear tire and crank housing straight up and down with the handle bars away from you, push the bar away from you. When done properly the tire will come toward you tightening the slack in the chain. While you hold pressure on the bar tighten the nuts and WALLA.
Dec 04, 2009 | Cycling
Popping skipping chain
how long have you had the chain on your bike? it may be worn (or your rear cassette may be) if skipping is occurring. have you attempted to adjust your shifters as well?
May 01, 2009 | Cycling
New kmc 10speed chain skipping over a newer durace cassette
If you replaced the chain yourself , you may have left it too long. With the chain on the biggest cog on the rear and the biggest cog on the front , pull the two ends of the chain together and see where they will link up. Leave another two links in the chain and it should be the correct length. You may also have the wrong chain for the bike. Also carefully check each tooth on each cog front and back for wear. Also check the idler wheels in your rear derailleur.
Mar 29, 2009 | Cycling
Huskylock - 530 - Serger won't create 'loop'
My stitch is good, upper and lower correct, but it will sew along and skip stitches. What do I need to do?, am good at repairing things on it all these years, I havent used it a lot the last few years, but it has started this skipping problem.
Mar 28, 2009 | Husqvarna Sewing Machines
Dewalt Planer (DW734) Logo
111 people viewed this question
Top Dewalt Crafts & Hobbies Experts
Ivan
Ivan
Level 1 Expert
CliffOnTheRo
Level 1 Expert
Tony Crow
Are you a Dewalt Craft and Hobby Expert? Answer questions, earn points and help others
