Question about Bosch Classixx WFL 2066 Front Load Washer
Washing machine tripping electric
My washing machine is tripping electricity at rinse cycle but will do a cold wash cycle
    Prodigy:
    An expert who has answered 500 questions.
  • Bosch Expert
  • 517 Answers
Take out plug first
check your heater
check the motor
Posted on Jan 25, 2014
SOURCE: he3t washing machine
F02 is a drain problem. I took the back off the washer and cleaned out the drainage hose and I guess its a holding tank before it goes out. Both were very clogged with STUFF cleaned it all out now it works better than ever.
Posted on Feb 04, 2009
  • 228 Answers
SOURCE: Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Posted on Aug 12, 2009
  • 228 Answers
SOURCE: washing machine is tripping electricity when door
FAULTY LOCK REPLACE
  • 414 Answers
SOURCE: My washing machine started the cycle then all the
More than likely the heating element needs replaced as it is down to earth.
Posted on Jul 07, 2010
SOURCE: washing machine has electric power supply but
There is an electrical short which needs professional service. It's dangerous -- do not try to operate it -- could be lethal.
Charlie
Posted on Feb 27, 2011
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
H6 error code on a NEC NFL-1065 washing machine
see this causes, and fix it. God bless you
Sep 26, 2012 | Washing Machines
Water will not fill during rinse cycle. it does fill when i start the machine but not during rinse cycle.
The rinse cycle only takes cold water so I suspect that you have a bad or maybe clogged water valve on the cold side of valve.hope this helps.
May 29, 2011 | General Electric WBSR3140GWW Top Load...
Simpson esprite 650 front loader washing machine. Electricity trips on programs b & h wash, can't complete cycle. Spinning and draining cycles OK. Why ? thanks sally
Hi Sally.Now in your posting you mentioned the machine trips the safety switch during the main wash.Is this correct?Does it trip as soon as the barrel stars to turn or a little later.Could you explain what b& h wash is.If the machine spins and drains and fills but trips during the cycle then from working on this model of machine I think the fault is your heating element.Have you tried a cold wash without any temp setting?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Sep 12, 2010 | Washing Machines
I have a candy go1282 washing machine that has stopped mid cycle and blew the electrics in the house ( not sure if it was the washer or something else that tripped the electrics), now it will not do...
do u still have power to the machine? try a spin cycle? try a rinse cycle if neither works u have a power supply fault.did u wire the door lock correctley?
Jun 28, 2010 | Washing Machines
Cold water does not fill for the wash cycle but will fill for the rinse cycle
just a guess make sure hot water line goes to hot water inlet look close there is a difference and cold to cold cold will be blue
Apr 12, 2010 | General Electric WHDSR316G Top Load Washer
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
Hotpoint WMA5 trips the electric on heating cycles
obviosly sound like the heating element is the problem, it is behind the machine in the lower rear of the drum. best to get it checked/replaced by someone who knows what they are doing as can leak if not done properly.
Jan 29, 2009 | Washing Machines
My washing machine is tripping the circuit breaker
sorry to hear about the problem it will be your motor or module try online for recon both these parts are prone to go on bekos
Jun 14, 2008 | Washing Machines
Inglis Washing Machine - Heavy Duty Extra Large Capacity
if it doesn't empty check the pump for blockages or just not working electrically, or check cold water supply to machine, or the cold water solenoid, this may also be faulty hope you can find what you need starting from the above, if i have helped please rate me
Oct 04, 2007 | Washing Machines
Bosch Classixx WFL 2066 Front Load Washer Logo
71 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
