Question about DXG Technology DXG Pro Gear DXG-5F0VR Digital Camcorder - 3" - Touchscreen LCD - CMOS - Full HD - Red
When i plug in dxg pro gear green light comes on but blank screen
I NEED A BATTERY CHARHER FOR DXG 1080 CAMERA
Try contacting the manafacturer, the info should be in the instruction manual.
Dec 19, 2014 | DXG Technology Pro Gear 1080p HD Camcorder
Can't take picture or record video?
Try turning the screen all the way around and close the screen so the screen its left outside where you can see if that doesn't work you will need to replace the ribon that connects the screen to camcorder.
Jan 30, 2014 | DXG Technology DXG-506V DV Digital...
Satellite pro L300 screen is blank. Power light is on (green), battery light is yellow, HDD light is off.
Sounds like it's broke. Blank screen means it's broken, battery light is yellow I beleive it means time to replace the batteries.
Apr 16, 2011 | Toshiba Satellite Pro L300 Notebook
Unable to view moves from the camera on my TV set.
this could be correct as the signal for the Camera LCD screen is now being sent to what ever device is connected on the TV out cable.
ensure your connection is
Camera - TV out
TV - Video in.
ensure that your TV is set to the correct channel or input setting to view the signal from the camera.
Nov 14, 2009 | DXG Technology DXG-565V Flash Media...
How do i download music onto my dxg 506
When you plug the camera in to the computer a screen will appear ckick it...nuw you will see another window open that has camera...music....ect.....click the music folder and you will get a blank screen.....now open your selected music files in another window....now drag selected music from selected files over to the gpx device blank window songs will now transfer over to the camera...also if you have limewire go to libary music then click explore button and you can drag from there ...camera will flash led red green wile downloading ...unplug wien done
This should fix ya!
Dec 11, 2008 | DXG Technology DXG-506V DV Digital...
LCD Screen
Try rocking the screen back and forth. If the picture changes, there is a short in the cable.
Jul 10, 2008 | DXG Technology DXG-301V Digital Camera
DXG-506V LCD comes on Blank White Screen
I had the same problem ...I bought a new 2 GB SD card put it in the camera and it worked fine.
It may have had something to do with formatting ..I tried to format the other card wiyh my computer when the video camera would stay on.
I tried to reset the camera that didn't work either.
The new SD Card did work.
-Steve
Jun 03, 2008 | DXG Technology DXG-506V DV Digital...
Broken?
Have a look in the battery compartment to see if the connections for the battery is not connecting with one of the batteries, i had a camera that stop that stop working on batteries but ok with the mains.
Mar 12, 2007 | DXG Technology DXG-305V Digital Camera
DXG Technology DXG Pro Gear DXG-5F0VR Digital Camcorder - 3" - Touchscreen LCD - CMOS - Full HD - Red Logo
27 people viewed this question
Top DXG Technology Video Cameras Experts
SHARCNET-USA
SHARCNET-USA
Hjalmer Lamminen
Hjalmer Lamminen
Jose Ma DM.
Jose Ma DM.
Are you a DXG Technology Video Camera Expert? Answer questions, earn points and help others
