Question about Global Star Software Age Of Sail 2: Privateer's Bounty for Windows
"Change Mode" Operation Not supported
Privateer's Bounty worked fine on my old computers, but when I try to run it on my Windows 7 machine, it seems to run fine at first, but after selecting which mission to play, and after the loading bar completes, the screen goes black and I get a pop up window that says: "Change Mode Operation not supported." I've tried each compatability mode, but with no joy.
5 Suggested Answers
SOURCE: Age of Sail Privaterr's Bounty will not play
You need to run it under windows 98 compatibility mode:
To do this locate the file "privateer.exe". By default, this file is located in Program Files/Global Star/Privateers Bounty - Age of Sail 2.
- Right click on the privateer.exe and select Properties.
- Click the Compatibility tab.
- Check the Compatibility Mode box by clicking in it.
- Use the drop down menu to select Windows 98/ME.
- Click Apply, and then click OK to close the window.
Hope this helps.
Graham.
Posted on Jan 29, 2009
  • 130 Answers
SOURCE: Age of Sails 2 trouble
U NEED MORE MEMORY FOR THIS GAME ,IT HAS MORE THAN MOST
Posted on Jul 15, 2009
SOURCE: Screen goes black and computer freezes
I found the solution elsewhere on the Web. Go into the "C:\Program Files\JetFighter IV" directory. Edit the jf4.ini file. Change simUseLoaderThread=1 to simUseLoaderThread=0. Then it'll work fine.
Now I need to figure out how to make a Saitek Cyborg V.1 joystick work with JetFighter IV. It fails within about a second after the cockpit simulation comes up. Any ideas on that one?
Posted on Dec 28, 2009
g33k4u
  • 485 Answers
SOURCE: On my Privateer's Bounty Age
I would first make sure your system meets the minimum requirements in order to play the game properly. You can find the requirements at the link below.
Click here for requirements.
If you do meet the requirements, then next I would recommend you install updated drivers for your graphics card.
Regards,
G33k
Posted on May 09, 2011
Print shop deluxe version 6 on 64 bit windows 7
download free virtual machine then you can install xp on your windows 7 64 bit pc. then install your print shop 6.0 and you can use it just like you did on your older pc. windows 7 professional has a mode that you can also use windows xp.
Feb 11, 2013 | Broderbund The Print Shop 21 Deluxe Full...
Cannot install MGI PhotoSuite4 on a computer running Windows 7 OS
The PhotoSuite 4 program is very old and won't work under Windows 7. http://sonic.net/mnitepub/pccafe/reviews/photosuite4/photosuite4.html says that the version 4 Platinum edition ran under Win95-Win2000 versions of the Windows OS. Thus even the compatibility mode probably won't help under Windows 7 32-bit. You can try it though by right clicking on the installer and then selecting Properties. In the Compatibility Mode tab, select Always Run this program in the compatibility mode and an older version of Windows. Then right click again and choose Run as Administrator. (You may have to do this again on the program itself.) Since Win7 64-bit requires signed drivers or programs, it is not as likely to work. (Check your version of Windows 7 by clicking Start > Control Panel > System and Security > System. If the title of your OS ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit OS.)
If you have Windows 7 Pro or Ultimate (or upgrade to one of those versions), you can run a virtual version of XP for free. Download and install Microsoft's Virtual PC and then XP mode (in order). This works best if your CPU supports virtualization and you enable the feature in your computer's BIOS. (There are work-arounds for computers without virtualization. See the MS support pages.) Install your PhotoSuite inside the virtual XP program in that case.This old software may run in that case. (However, I've had some Win2K software that ran under XP with the compatibility mode but didn't run under the virtual XP. Note: virtual computers do have some additional limitations. They do not talk to the host hard drive and other hardware directly. (You can install a printer on the host machine or the virtual machine but not both.) You'll need to save files on external media (flash drive, optical disc or other hard drive) to transfer them between the machines).
Another option is to run an older version of Windows on another computer, as a dual boot computer or with Virtual PC (or another virtual computer package - VMWare or Parallels). In that case, you need a licensed version of the older Windows OS. Again install the program while running the older OS.
The final option is to upgrade to a Windows 7 compatible Photo editor and organizer. (Even the Microsoft Windows Live Photo Gallery has some of the features of Photosuite SE.)
I hope this helps.
Mar 24, 2012 | MGI Software PhotoSuite SE V4.0
On my Privateer's Bounty Age of Sail !! Pc game, it will get on the main menu fine, and on the list of battles, and then selecting a battle is fine. But when I click "Play" the loading bar...
Regards,
G33k
May 09, 2011 | Global Star Software Age Of Sail 2:...
I recently picked up an older game, Heroes of Might and Magic IV get home and install. Install wizard runs fine except for one thing despite the fact it correctly identifies all my hardware, it tells me...
I have Heroes of Might and Magic 5 Running on Win 7. There were many patches to install before this title worked(on my computer). Have you installed all the available updates for it?
Here are 2 sites that have the compatibility options:
http://techpaul.wordpress.com/2009/06/28/compatibility-tricks-for-old-programs-new-machines/
http://www.sevenforums.com/tutorials/316-compatibility-mode.html
If that does not work, you can also try to set up XP mode in Win 7: (Note: you need to have Win 7 Pro, Enterprise, or Ultimate for this one) Win 7 Home Premium does not support XP Mode.
http://arstechnica.com/microsoft/reviews/2010/01/windows-xp-mode.ars/
Jan 29, 2011 | 3DO Heroes of Might and Magic 4 for...
Unique customer Registration for MYOB Plus 11 I used MYOB 7 for years, and it worked all the way up to Windows 7 - now it won't even start. Its time to leave. I have a copy of MYOB Plus 11 that seems to...
Or, just get a version of windows 7 (look for "Windows Anytime Upgrade" on your computer) that can run a virtual XP machine (Pro or Ultimate versions), then download and install the virtual PC hyper-viser kernal and the XP Mode virtual machine.
Next, install your old copy of MYOB 7 into the XP mode virtual machine, copy your data files, and it should work....
EXPLANATION OF "WHY": MYOB 7 was actually meant to run on windows 95/98 machines, and this wasn't a problem in XP, because it could run a program that would basically emulate all of the win95/95 API's, under which MYOB 7 could run. Starting with windows vista, those old API's and emulation programs were basically tossed. Running the program under a virtual XP machine will give your old programs, like MYOB 7, access to those old API's. BTW, once the program is installed, it should auto register with windows 7. After which it will run in the win 7 interface almost as if it were a native program (will take longer to load as it has to load XP OS too).
One note, any custom forms (invoices, etc) may not work after copying them to the new installation of MYOB. Change their file attributes from Read Only (uncheck that box from within the files' properties dialog, via windows file explorer).
Oh, you'll definitely want as much RAM in your computer as you can get in there. XP mode will take a minimum of 512MB, but it'll be slow unless you set it up for at least a gig of ram.
Dec 11, 2010 | Myob Accounting Plus (BPJUBC00) for PC,...
My old computer that I have XP on is just too slow. I hate Windows 7 and do not care for Vista. My problem is that I am told that my new computer will not run XP because it is 64 bit. Two questions: Is...
Xp will run fine on any PC but it may not utilise all of your ram and CPU cores. You will get more performance from your machine if you use a 64 bit operating system but XP will run.
Nov 26, 2010 | Dell Inspiron 560S Desktop Computer (Intel...
I bought keyboardworks v1.1 it worked fine for my old xp computer. Now I switched to windows 7 and it does not work. Any fixes?
Since this software was designed to work with Windows XP or earlier. It may not run in windows 7 normally, but you can run this application in Compatibility mode.
Windows 7 comes with Program Compatibility troubleshooter, using which you can run older programs in compatibility mode.
To run the Program Compatibility troubleshooter
1. Open the Program Compatibility troubleshooter by clicking the Start button and then clicking Control Panel.
2. In the search box, type troubleshooter, and then click Troubleshooting.
3. Under Programs, click Run programs made for previous versions of Windows.
4. This would scan the computer for incompatible applications and list them, keyboardworks .
5. Click next. this will try running in Windows XP mode.
6. If sucessful save the setting and u should be good to go, else try installing this application in Compatibility mode.
7. right-click choose properties on setup.exe
8. click on compatibility tab. put a check on run this program compatibility mode for and choose windows XP
9. put a check on run this program has administrator. cluick apply and ok and install this application.
10. run the application, if it does not work repeat the steps 1-6.
May 18, 2010 | Computers & Internet
It dont recognise the usb port it says make sure it connected. It works fine on my window xp.This is window 7 laptop,
try running your windows 7 in XP mode. Check the SInger Futura support website. I know they have some patches to run on the newer versions of Windows.
Jan 05, 2010 | Singer CE-200 Quantum Futura Computerized...
Windows 7 and Mathcad 14 compatibility
can anyone get me information whether Mathcad 14 is working on Windows 7
Thanks in advance
Nov 25, 2009 | Mathsoft Mathcad 14 for Windows Full...
Hope this helps.
Graham.
Jan 08, 2009 | Global Star Software Age Of Sail 2:...
Global Star Software Age Of Sail 2: Privateer's Bounty for Windows Logo
Top Global Star Software Video Game Consoles & Games Experts
James Wishart
Jax Planet
Jax Planet
john h
Are you a Global Star Software Video Game Console and Game Expert? Answer questions, earn points and help others
