Question about Alpine MRV-T757 Car Audio Amplifier
Alpine mrv-t757 i have a alpine mrv-t757 and everytime i hook it up my music light on the amp flashes a red light off and on. i have kicker comp cvr subs but they are hooked up only on one side of each sub because the other side is blown. plus i don't have the right screws that go with the amp and i need to find somewhere to get the specker screws and the power screws for it.
  • 709 Answers
Hi Big Nick,
Sounds like you have got almost all the good out of those Subs. You can find the screws you need at almost any hardware store or Auto parts store. The light is becase you are dloading the amp with low OHMS.  You may need use one channel and Run the wiring like written blow to get the power problem to disappear.
S1+ = Kicker comp cvr sub coil 1 positive
A+ = Amplifier Positive output.
A+ to S1+
S1- to S2+
S2- to A-
Posted on Oct 23, 2007
My kicker 12 inch cvr's arent hitting as hard as they should
amps and wiring kits are very optimistic on the output. If you want proper wire, buy some welding cable "0" or "00" guage. That solves the power delivery. Put a 1 Farrad (or more) capacitor near the amp, that solves the surge power issue. Make sure the box is suitable for the subs. Lastly I'd say do some research and find the right amp that can deliver the clean, huge current required to move some serious air!
Jan 28, 2014 | Kicker Comp CVR 12 x 12 Car Subwoofer
2 kicker cvr 12's in prewired kicker box with 1 wire terminal, kicker cx1200.1 amp. Whats the best way to wire this combo?
Well you really can't run both speakers on one term. because you will over heat the amp , unless your amp is rated at twice the capability of your subs , Then if so , Try positive to one sub , then neg. to the other sub , then bridge the remaining positive to the remaining negative terminal , But it is really best to get a two channel amp for your subs !!!
Sep 23, 2013 | Kicker Comp CVR 12 x 12 Car Subwoofer
I need to know how to wire 2 Kicker comp 10" subs
you can find your wiring diagram here
http://www.crutchfield.com/S-lCf6ewrWNQM/learn/learningcenter/car/subwoofers_wiring.html
Select from the list shown which describes your amp and subs (ie 2 channel amp with 2 4ohm subs)
Hope this helps and please rate, thanks
Mar 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
Alpine MRV-T757: Protection and Music light lite up green and Battery light Flashes Red? Do you know my problem?
check all of you connections especially the earth at the amp and the body of the car
Aug 12, 2010 | Alpine Car Audio & Video
The light power is red and it smell like melt
on an amplifier that usually means that its burnt out, or that you've melted one of the wires. check the ground wires and whatever you have the amp sitting on. if everything looks alrite then its most likely the inside of the amp is fried.
Jun 20, 2010 | Alpine MRV-T757 Car Audio Amplifier
I have 2 alpine r type 12's hooked up to a kicker crossover and a NRG 2200 800 watt amp. they are wired series and parallel. when i turn it up the subs sound like the are fluttering. what is going on.
well my friend either your amp is not powerful enough to push your subs or you have a sub that is shorting out cause i just had the same problem with my 2 15 kicker cvr competition subs
Nov 04, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Red protection light on when power,d up from battrie is this normal
check the connector at the amp and make sure the wires aint touching also check ur speaker wire are rigged up right... do not run 2 subs off 1 channel as it will pop fuses and the procet light will come on
Oct 21, 2009 | Alpine MRV-T757 Car Audio Amplifier
Blinking protection light on mrv-t757 amp
Could be the power supply or output stage electrolytic capacitors.
Possibly breaking down/drying out inside.
Mar 17, 2008 | Alpine MRV-T757 Car Audio Amplifier
Car Audio & Video Logo
368 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
