Question about Kitchen Ranges
Kenmore elite 721.80829 shattered range door
Shattered range door
jumptrout51
  • 3361 Answers
SOURCE: Range door will not seal properly.
Place a hammer handle between the door and the frame at the hinges..
Push on the door, carefully.
This usually works to re-seat the door hinges.
Posted on Mar 08, 2009
57 varieties
  • 1653 Answers
SOURCE: I have kenmore elite gas range 790 series getting
The F93 shows that the Maximum oven door lock time has been exceeded.
Turn off the range and turn off the AC power and wait for up to 10 mins. The door should reopen. Turn on the AC power ans see if the error persists. If it does then check the following.
1. Check the wiring between EOC & Lock Motor Micro Switch.
2. Replace the Motor Door Latch assembly if necessary.
3. Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly.
6. Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
Posted on Nov 12, 2009
SOURCE: Kenmore gas range model 790 door glass shattered, handle problem
We have suffered the same problem for the past 3 yrs. We first had the door all fall apart and I screwed it back together thinking that someone missed tightening a screw. Then shortly after the 1 yr warranty was up it happened again. Sears would not help, first told me that there was a recall, then not. After 6 departments and 12 people later they sent me on to whirl pool the manufacturer who said "see sears".
Anyways since we are abandoned by Sears who we trusted (as parents did) we are on our own, here is how I solved it.
After several times of the screw popping out and chipping and stripping the treads in the handle; I too switched out the bottom handle with the top but now at 3yrs old both handles had the threads stripped and chipped and the oven door fell apart during Thanksgiving dinner with the mother law 2009.
The next step for me after another round with Sears with no results (except they said it was common problem) and a letters to Att. Gen. (keep the letters flowing as they are hearing) was to go to the hardware store. I was able to find (not at the main hardware stores, had to go to mom/pa old fashion hardware store) a packet of #10 Sheet metal screws (Stainless steel) 2 1/2" long and a flat washer. This worked. Cost $1.18. Note it does strip the factory threads, so if your present threads are not too bad you may not want do it. You need the washer because the 2 1/2" is slightly too long. 2 1/4" would be a better length but I could not find them.
I would think Sears would want to avoid the bad press by sending all of us $1.18 worth of hardware out. Sears offered to sell me new handles, but I was not about to give them any more of my $.
And I agree it is a very stupid design to have to small handle (where the most stress is) holding the door/glass together.
Note if glass breaks, do not mess around, buy the proper part to go back in.
Posted on Jan 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore Elite gas range
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^#$%
Posted on Sep 26, 2010
  • 7 Answers
SOURCE: Kenmore Elite 790 series gas range, ran flex clean about 5 minutes after starting recieved a F93 error now door locked.
unplug it for about 15 minutes to reset it self and see what happens
Posted on Mar 17, 2012
My kenmore elite washer keeps giving me the LE error
Kenmore elite 700 series triple action technology glass top load 5.3 cu ft.washer glass lid is shattered..can I replace the glass only or do I have to replace the whole lid top?
Mar 16, 2017 | Kenmore Washing Machines
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
I have a Kenmore Elite double oven, model 790.48123801.(4 years old). My wife attempted to operate the self-cleaning feature and 29 seconds later an F90 error message appeared, the oven began to beep
Oven door latch error code. The oven door latched but the control board did not receive a signal that the door was latched.
The only time that the latch is used is during the cleaning cycle.
KENMORE ELITE Walloven Parts Model 79048123801
How to unlock Kenmore oven
Oct 18, 2014 | Kenmore Kitchen Ranges
Elite range
This pertains to model 790 Kenmore ranges, comprised of an oven door handle that is mounted on the door's glass.
Be careful when tightening the oven's door handle. Even slightly over tightening would likely result in the glass shuttering, because tightening the screws pulls in and thus presses the handle against the glass. This is a problematic design in my opinion. I'd rather give up on a couple inches in the width of the glass, than be unable to adequately tighten the screws fastening the handle and risk shattering the glass.
Aug 24, 2013 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My range door glass has shattered into a million pieces, what can Kenmore do to help me
They can possibly get you on the right track to getting someone sent out to fix the glass on the door since it's replaceable. You could also just as easily contact any glass company to do the measuring and installation for you.
But it's always better to go with a better company name than one that's not usually known as to prevent bad installation.
Feb 25, 2013 | kenmore.com
Kenmore Elite Gas Range C970-441833 - how to clean between glass on the oven
You have to take out the handle screws, all of the srews on both sides of the door. And if you look at the bottom of the door, you should see about 3 or 4 screws as well. When you take out the screws, the inner door should lift right off. PAY ATTENTION TO THE FRAMEWORK AROUND BOTH OF THE GLASS PIECES. IF YOU DO NOT REASSEMBLE CORRECTLY, NOT ONLY IS THERE A CHANCE OF HEAT ESCAPE, BUT YOU ALSO STAND A RISK OF SHATTERING THE GLASS
Jan 31, 2013 | Kitchen Ranges
Front door glass on oven shattered. Is it still operational?
Technically yes, but safely... NO!!
Here is a tip that I wrote about the oven door glassreplacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Nov 24, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Model PLT083-2 glass in door shattered can i order replacement door or glass ?
Yes a replacement glass is available. They can be tricky to install especially if the door has to come off for disassembly. use your model number on searspartsdirect .com then use that part number to search the web and ebay for the best price.
Eric
Nov 13, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Mar 08, 2009 | Kenmore Kitchen Ranges
Oven door won't unlock
I had this same issue and consulted the owner's manual. Once on self clean it takes up to 3-4 hours for it to automatically unlock. It is a built in safety feature of the oven.
Jun 21, 2008 | Kenmore 46123 Stainless Steel Electric...
Kitchen Ranges Logo
15 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
