Question about Camping, Backpacking & Hiking
Freezing ham - Camping, Backpacking & Hiking
We froze ham slices in vacuum packs in January and they really turned red in color. Are they still good?
Ham is a cured meat. The curing process can be carried out in a variety of ways - smoked, salted or chemical, or a combination.
I don't know why it turned red but I speculate something, perhaps a chemical used in the curing process has been drawn from the meat to the surface by the vacuum.
Cured meat in the freezer is very unlikely to go bad so it will certainly be safe to eat, though you could find the taste is altered.
Properly cured meat shouldn't need freezing unless you want to store it for a long time and then wrapping it should be sufficient.
A widely travelled friend told me in rural France ham is dry-cured and in many French kitchens a visitor will find a large ham hanging from the ceiling, sometimes wrapped in mutton cloth or cheesecloth. Sometimes a slice or two is taken from the ham where it hangs and sometimes it is taken down.
That ham hangs around for a relatively long time before it is exhausted and no one becomes ill.
Mar 04, 2018 | Kitchen Appliances - Others
Had a fully cooked ham and heated it up with the dressings for it. can tjis ham be frozen
hi Verene.
If you have leftovers, you can easily store ham in the refrigerator for up to a week. However, if you have a lot, or even a whole cooked or smoked ham left untouched, youcan keep it in the freezer for longer storage. ... 2 Place your sliced or cut-up ham into airtight freezer bags.
How to Freeze Cooked & Smoked Ham - Living The Bump
living.thebump.com/freeze-cooked-smoked-ham-7911.html
Can you freeze a cooked ham?Experts recommend freezing uncooked, uncured and fresh ham for 6 months or less. If the ham has already been cooked, it should be frozen for 2 months or less. If you plan on freezing a ham for more than a couple of months, you should buy it uncooked, put it in the freezer and then thaw it when you are ready to cook it.Can You Freeze Ham - Dereezedereeze.com/food-and-cooking/can-you-freeze-ham/Search for: Can you freeze a cooked ham?
if you need to read up some more then go to this link.
CAN COOKED ham be frozen Google Search
Nov 25, 2017 | The Kitchen Appliances - Others
Can you freeze a spiral ham that is a week old?
Yes you can Nancy. Try and remove as much air from the freezer bag as you can when you freeze it. Try and use within 6 months. One of my favourites for it is chicken and ham pie, just dice some chicken, poach it in stock with diced onion and make a nice white sauce using the chicken stock, thicken it and add frozen peas and diced ham. It is also good as a base for eggs benedict, and fried at breakfast with eggs and home fries.
I am a chef :>)
Jan 01, 2016 | Smithfield 3-4 lb. Spiral Sliced Ham and 2...
I need to know it okay to eat a ham that been in the freeze for a year I got from a job I never open it up I just put in the freeze how long before it not any good to eat
If it has been frozen the entire time it should be safe to eat. Most anything that has been continually frozen should be safe to eat if cooked and eaten soon after thawing it out. Bacteria is what spoils anything and bacteria cannot multiply in a frozen environment. Depending on what it is,how long it was frozen and whether or not it was exposed to air while being frozen will determine whether or not there is an undesirable change to the taste, color or texture.
The best (safest) way to thaw anything out would be slowly in a properly working and set refrigerator.
Your ham should be OK,especially if it was frozen in its original plastic packaging without being opened or exposed to air before freezing. I have eaten previously frozen hams and turkeys (in their original packaging) that were in my freezer a lot longer than one year... and I never noticed any difference in taste.
Nov 14, 2015 | Home
How long can you freeze an uncooked smoked ham
http://everydaylife.globalpost.com/store-uncooked-smoked-ham-21113.html
Mar 29, 2015 | Radio Communications
How long can i freeze leftover ham
The answer is that it depends. I don't recommend freezing ham radios. Your owner's manual probably has specified a safe range of operation. Freezing your radio will more than likely cause permanent damage.
If you are talking about the food ham, you are in the wrong place. You can store ham frozen for as long as you want, provided you don't mind freezer burn. Generally three months is about the longest you can freeze cooked meat and maintain the quality.
Dec 30, 2013 | Radio Communications
Is it okay to freeze Boar's Head turkey and ham after they've been sliced?
Yes, as long as it hasn't been sitting out in the warmth too long, bacteria can grow under those conditions. If it's fine you can freeze it, but take care to wrap it so that it is air tight, otherwise it will freezer burn. After freezing it might not be *quite* as tasty as when brought home from the deli, but it will still be good.
Dec 23, 2013 | Freezers
Can i freeze cooked ham
in a word yes. chill it to 5 degrees preferrably in under90 mins then wrap it well and freeze
Dec 21, 2013 | Camping, Backpacking & Hiking
Camping, Backpacking & Hiking Logo
307 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
