Question about Dell Inspiron E1505 Notebook
Dell inspirion e1505 graphics and mouse gltich
Graphics and mouse glitch
    Problem Solver:
  • 19 Answers
Maybe a bad or dying graphics card?
Posted on May 14, 2014
  • 34 Answers
SOURCE: dell Inspirion E1505 internet connection problem
NightGirl,
What I would try to do is first check to see if there is a static IP address. You check this by goto START-MY NETWORK PLACES-VIEW NETWORK CONNECTIONS (in the top left hand side) From there, you should see your LAN,HIGH-SPEED INTERNET then under it you should see Local Area Connection. If there is more than one Local Area Connection connected, then disconnect both of them and try only connection one of them, (i couldn't tell you which one as I'm not there to see which is the onboard NIC) It should be connected, but apparently in your case it may not stay on. Right click on the Local Area Connection, then goto PROPERTIES. The properties box is going to open up. Make sure that Internet Protocal (TCP/IP) is checked, then highlight it and click on the PROPERTIES box, here is where you want to make sure that the (OBTAIN AN IP ADDRESS AUTOMATICALLY) is selected, if not, then select it and do the same for the bottom (OBTAIN DNS SERVER ADDRESS AUTOMATICALLY)
Posted on Feb 04, 2009
peeface
  • 180 Answers
SOURCE: how to play music on pc on home theater system
hello. i was just looking over the panasonic manual for your system and it doesnt look like there is any extra inputs to hook anything up. i think from what i was looking at the home theatre system has fm radio on it right? what i do sometimes is use a wireless fm transmitter that i have and plug that into my laptop and set the radio to the station the transmitter is set to. it works ok. you can get them at radio shack and best buy and places like that. let me know if that helps
Posted on Apr 21, 2009
parrotheadpc
  • 2600 Answers
SOURCE: How would I fix a Blue screen of death, stop code
Windows Start-up Errors
Note: This troubleshooting step is usually used for the specific issue indicated above but it may also work for BSOD issues which recently occurred and you're unable to boot to either safe mode or normal mode.
First, The basics. You will need a Windows XP CD. If you only have a recovery disk set like the ones from a HP or Compaq, they will not do what you want. You can normally use a Dell disk, also retail box disks (XP Purchased from the store), or some OEM versions of XP will work (most of these will have the Microsoft hologram on them). You can also download a boot up Floppy disk set from Microsoft here: http://support.microsoft.com/kb/310994 There are a few other places with bootable CDs on the net, but the easiest thing to do if you don't have an XP CD is to borrow a Dell or Retail box disk and get right to work. If your computer already starts at the CD rom first, or you know how to make it go there skip to part C:
After you know that the computer will boot to the correct drive, insert your disk into the appropriate drive. If you have more than one cd rom or floppy drive you may find that your system only checks one drive before going to the hard drive for boot up. If this happens you can just move the disk to the other drive and restart your computer.
When you get the system started and it finds your startup disk you will see a screen that says Press any Key to boot from CD. I normally use the space bar as my any key and then you should see a blue screen that says Windows setup in the left hand corner. Wait until you see the welcome to setup screen and then click the "R" key to get to the Recovery Console How long it takes to get to each of these depends on the speed of your system, but I will tell you that it will take a few minutes to finally get to the Console.
Once you are at the Recovery Console you will be given at least one choice of Windows installations. Normally the choice you want is the number 1 choice. Click the number 1 key at the "top" of the keyboard and click enter.
You will be given a message asking for the administrator password. Unless someone or something has messed with your computer there is no password so you just click the enter key.
This will bring you to a prompt that says:
C:\WINDOWS>
Type: cd \ and then click enter
( Note: between "cd" and "\" there should be a "blank space" otherwise the command won't work. If you find that a command hasn't worked make sure you typed it correctly. These are similar to old DOS commands where spaces had to go between each command so DOS knew where one command stopped and another started.)
You are now at the ROOT of the drive where it all begins. The Prompt should now say C:\>
Now type: CHKDSK /R and click enter.
The chkdsk / r command also includes the P command and will also look for lost recoverable information in bad sectors.
Now after the chkdsk has run type: FIXBOOT then click enter.
It may prompt you with a warning but continue through it and once fixboot has finished type: EXIT and click enter.
Your system should reboot and when it does click the F8 button to get a windows start menu. Use the up or down arrow to highlight the LAST KNOWN GOOD CONFIGURATION and click enter. If it was a simple drive error this should have fixed it.
Posted on Oct 12, 2009
Testimonial: "Thank you so much, that worked perfectly!"
  • 192 Answers
SOURCE: Dell Inspirion mini 10v XP gets graphic error
The graphics chipset in a Dell mini is not capable of running Sims 2. It requires far more power than you are going to get from a Netbook. Even some standard Laptops would be hard pressed to run Sims 2.
Netbooks are for email and web browsing, and that is about it. You'd be lucky to run even a simple Flash-based game on a netbook. Sorry...
Posted on Jan 19, 2010
  • 113 Answers
SOURCE: Dell Inspiron E1505 Buttons on mouse NOT
run your comp in safe mode, if still not working, run 32 bit dell diagnostic using teh drivers disc, test touchpad, if still not working replace palmrest
Posted on Feb 23, 2010
I have a Dell Inspirion E1505 laptop that keeps giving me the error message Windows root.\system32\hal.dll is missing or corrupt. any help on a fix
You would have to re-install the ENTIRE Operating system IF you do NOT have a Recovery Partition or Norton's Ghost, which was common on many older Dell Computers.
Feb 28, 2013 | Dell Inspirion One 2320 IO2320-5555BK...
I had to restore my dell inspirion E1505, and it says i have no wireless network, how do i turn this worless network back on?
You need to check for the wireless switch located on your laptop. Once the wireless switch is on, you'll be able to see networks in range and you will be able to connect to your network wireless.
Good Luck!
Aug 27, 2010 | Dell Inspiron E1505 Notebook
I misplased my laptop cd to install hardware& was wondering were i could get a replacement for my inspirion E1505 ,ijust installed e new hard drive.
http://support.dell.com/support/topics/global.aspx/support/chat/en/hardware_chat?c=us&cs=555&l=en&s=biz go to this web site put in your service tag number then chat wit dell and ask for another one. They are usually pretty co-operative but may charge you a small fee. Please leave rating and comments if this helps you.
Jan 06, 2010 | Dell Inspiron E1505 Notebook
I have a Dell Inspirion E1505 laptop and when I put a CD in it won't load. It just clicks and finally shuts off.
then the system cd player may be corrupted ,try and change it,if it persist then you can now format your system.
Jul 17, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Dell inspirion will not boot up
Get warranty status for the computer at Dell
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen
enter your service tag. this is located on the bottom of the laptop.
If you have warranty, contact Dell's customer service
Otherwise, more fully explain your problem.
May 07, 2009 | Dell Inspiron E1505 Notebook
Screen keeps going dark
thats a lcd failure contact dell tech support 1800629896
Jan 12, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 Notebook Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
