Question about Dell Inspiron E1505 Notebook
Processor glitch - Dell Inspiron E1505 Notebook
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 26 Answers
Receiver won't turn on unless u unplug for 5/10 min
Hi Bart, I would suggest that you try a hard reset as there might be a glitch in the processor, if you email me your model number I can advise you of the reset procedure. Please email me at askOnkyo@us.onkyo.com, Thanks, JT
Oct 18, 2015 | Onkyo Audio Players & Recorders
EMachine EL1333G windows 7 64 bit AMD Athlon 2650E Processor ( BIOS OVERCLOCK HELP)
Troy,
When Processors (CPU) are made, they are made on a Pass/Fail scale. Processor is either Good, or not good.
This means you may get a Processor that is on the Top of the scale, or Bottom of the scale. The AMD factory doesn't discriminate.
In fact they don't care. (This goes for all Processor manufacturers, not just AMD)
All they care about is does the Processor work, or not?
Therefore, you may have a Processor that is on the Bottom of the scale, but passed as Good.
Point? Stating a setting that might be good for joeblow's AMD Athlon 2650e, may not work for yours.
Might work for yours, and not joeblow's.
This is why you need to go into BIOS Setup, and using a SMALL increment, overclock the Processor.
Run the computer for 24 hours, and see if everything is chiily.
(Computer still works OK)
This is a "Burn-In test"
Works OK for 24 hours? Then go back into BIOS Setup, and go up one more small increment. Do the Burn-In test.
Keep going until the computer has glitches, or doesn't work.
Then go back into BIOS Setup, and come down one small increment, or go back to where the computer WAS working OK.
It's an individual thing. Each Processor (CPU) is different from the others.
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 23, 2013 | E-Machines eMachines Desktop PC
Error 53000921
Your video processor has a problem, seems like it is overheating:
graphic glitches on startup blue screen
Also, my computer would blue screen on me when i tried to run a high end graphical game, in this case Guild Wars.
I ran a full length diagnostic on my video card, and over half the tests failed.
I had many errors in the reading and writing of video memory, and failed tests of whether a page was void of colour errors and such.
I wrote down all the error codes and they are as follows:
5300:0119
5300:031E
5300:051D
5300:0820
5300:0921
5300:0B21
If you're under warranty, call Dell with the error information and they will replace the video card. If you're out of warranty, you can order a card:
Dell Spare Parts 1-800-449-3355 ext 7269937
Nov 23, 2010 | Dell Inspiron 9400 Notebook
Hp sr2023wm core just shuts down. boot back and shuts down again! runs for hrs and then poof down again. possibly a power suppy? or an overheating processor?
If you are overclocking the processor it may be overheating.
ALSO check that the fans are running, including the one on the processor AND vents and heatsink fins are not clogged with dust.
Also consider if your pwer to the unit MIGHT be glitching or brownout due to heavy loads or bad receptacles or wiring. Make sure you are not running off a switched wall receptacle.
May 02, 2010 | HP Compaq Presario SR2023WM PC Desktop
Where can i get driver for intel motherboard 915
use this link to download it :
http://www.intel.com/support/chipsets/sb/cs-011594.htm
choose the one refering to chip set drivers ....it the manufacture's site so should be clean w\o glitch .
good luck !
Oct 26, 2009 | Intel Pentium D 915, 2.8 GHz (BX80553915)...
Problem w/ Mitsubishi WS-65869After losing power
I found this answer and I believe it fits your problem perfectly.
Your TV has two microprocessors that depend on each other for communication. The problem is that a power glitch gets them out of sync. Try this:
1. Press the power button and wait for the blinking light to stop.
2. Press all the front panel buttons one at a time, except for the reset, and power button.
This will send a command to one processor and sets an interrupt.
3. Hit the power button, and the TV should power up.
4. Set the TV to low energy mode(see TV manual to find out how to do this. Doing this step will help prevent the problem from coming back. These instructions were taken from a Mitsubishi service manual.
Oct 03, 2009 | Mitsubishi WS-65869 65" Rear Projection...
My games every so often and i have to reset the console
did you mean to say that your games freeze up every now and then? I have a fourth generation manufactured 360 the ones produced after the red ring of death epidemic and I still rarely experience my console freezing up and have to reset the console. These machines use micro processors just like computers and are sort of bombarded with various pixels and other binary information which can overwhelm the processor at times as such as what could occur with your home pc or laptop this occurs primarily from the software (games) pushing the console to the limit. If you'll notice that this may occur only on certain games and some game programming may also have glitches upon release. You can connect to x box live and check for any updates which may be available to correct any glitches. Hope this helps
Aug 05, 2009 | Microsoft Xbox 360 Console
Changing file names
I'm thinking this may be a software glitch with the pic program you're using. You might try removing and reinstalling it. At this point I'm out of ideas, and I think the only way i would be able to help you is if I had the machine in front of me. I'm going to suggest reposting the problem, maybe one of the other experts here will know a solution, and reply.
Aug 16, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Freezing
This could be caused by a number of problems either with the hardware or software. Start by doing a virus scan, then a system restore back about a month or so. If it's a software glitch this should clear it. Also, an operating system error or glitch can cause this, so you might try an operating system repair with your recovery or operating system disc. If not, then do a hard drive and memory test from the bios or setup (if your machine has these diagnostic tools, some don't). A bad or failing memory chip or hard drive can cause this, a malfunctioning or failing processor can cause this, and a dirty fan or heat sink can cause the processor to overheat causeing this. You'll just have to sort through these one at a time until you find the cause.
Jul 23, 2008 | IBM ThinkPad R50e Notebook
Dell Inspiron E1505 Notebook Logo
43 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
