Question about KitchenAid KUDS30FXSS Builtin Dishwasher
How to replace top rack adjuster kitchenaid kuds30fxss3
Need to replace top rack adjuster with new part
SOURCE: I need to know how
I got someone locally to help me.
Posted on Apr 02, 2008
techcrazy
  • 72 Answers
SOURCE: Kitchenaid, new dishwasher, stopped cleaning top rack dishes
The problem most people encounter with dishwashers is a simple inability to get the dishes clean. There might be stuck-on food or residue from the detergent. A water pressure problem may be the culprit. You may need to replace the water intake valve. Another common problem is mineral build-up. If your house has hard water, the mineral build-up can clog the water jets. Clear each jet with a wire or pin, and run an empty load with some vinegar in the detergent dispenser about once a month.
Sometimes, the dishwasher has problems draining properly. There could be a clog in the drain hose, or a problem with the pump. It's also possible that the dishwater is getting too sudsy, and sensors in the washer aren't detecting the soap foam as water. This causes it to shut down the drain cycle too early. Just use less detergent.
Posted on Feb 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: need an upper rack for a Kitchenaid KDI21A
WHOOPS - turns out on that same diagram #24 is actually the top baaket.... and is $230.
I would think you could get an entire dishwasher for that price :D
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 23, 2009
  • 161 Answers
SOURCE: Kitchenaid KUDP02CRB - top rack dishes are not getting clean
maybe not... if unit is incorporating more than one spray arm,chances are the upper spray arm is not getting water.pull top rack forward,gaze under top rack near rear manifold.slowly push rack back in.notice if manifold inserts into upper wash feed.if so,possible motor issue. if not,bingo was his name-o!
Posted on Nov 13, 2009
SOURCE: I need a top rack part #9741982 for my old Kitchenaid Dishwasher!!! Can anyone help me? thanks so much!
If you contact an appliance dealer that sells kitchenaid I'm sure they'll be able to get it for you.
Posted on Jan 09, 2012
I have kdte104dss0 dishwasher. Top rack will not pull out completely. Is there a way to fix this?
It seems that you need to order a adjuster assembly, slide rails for the top rack of your dishwasher. You can follow the below link to order the parts: http www searspartsdirect com model part kdte104dss0 0593 0130000 w1312023.
Jun 19, 2016 | KitchenAid KDTE104DSS Architect Series II...
Need to replace the adjuster and need instructions how all the parts go together.
Replacing Adjuster Wheels on a Kitchenaid Dishwasher ...
? 2:50
https://www.youtube.com/watch?v=ClCHpDL--Gw
Jan 26, 2014 - Uploaded by natifamily
Replacing Adjuster Wheels on a Kitchenaid Dishwasher. natifamily ... Dishwasher Top Upper Rack Adjuster ...
Whirlpool, Kenmore, KitchenAid - Dishwasher Replacement ...
Nov 29, 2015 | KitchenAid Architect? II S SERIES KUDS03FT...
Top rack not getting clean on Normal Cycle
Empty the dishwasher. Look at the 2 rotating plastic arms in it (like 2 bladed windmills) spin each one, do they move freely without hitting anything? If so remove the top one (its a press on fit) the look inside it with a torch, is there any debris or dirt inside it blocking it? Water has to flow inside it or it will not spin, and top rack gets no water spray.
Dec 20, 2013 | Dishwashers
Dishwasher rack falls off
Could it be that KitchenAid wants you to replace the entire rack? Check with a local appliance parts supplier if you can because the roller must be a hot replacement item.
Nov 21, 2013 | KitchenAid KUDS30IXSS Builtin Dishwasher
Upper rack track wheel broke
You can try to obtain the part from KitchenAid or an appliance parts supplier. However, you may only be able to get the complete assembly.
Nov 07, 2013 | KitchenAid KUDS30IX Dishwasher
Top rack rails came off the rollers
How to replace the adjuster on the top rack of KitchenAide dishwasher model number KUDS35FXSS1
Feb 03, 2012 | KitchenAid 24 in. KUDS01FLSS Built-In...
Jan 09, 2012 | KitchenAid Dishwashers
Nov 13, 2009 | KitchenAid Dishwashers
I have a Hobart Kitchenaid Superba kds-20 and I
Your best option is to contact a used appliance dealer and hope for the best on locating racks.
I priced some similar model racks for a customer 2 months ago. They were over $400 each.
Nov 10, 2009 | KitchenAid Dishwashers
Need an upper rack for a kitchenaid kdi21a
May 23, 2009 | KitchenAid Dishwashers
KitchenAid KUDS30FXSS Builtin Dishwasher Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
