Question about Garden
Oil Pipe is broken
I have just got a new Stilh 029 saw to use for parts. I have removed the oil pump and have found that the pipe running from that to the groove has snapped in what looks like a sleeve on the plastic housing.
I do have a complete one on my but is still attached to another saw, can this be removed, or can i get a new pipe from somewhere?
  • 23 Answers
STIHL PARTS ARE AVAIBLE LOCAL DEALER
Posted on May 24, 2009
Bought the saw used with a new bar and bar it won't oil
*Make sure there is oil in the oil tank
1. remove the bar and chain and run the saw with them off. Oil should be pumped out the oil vein on the side of the saw.
If there is no oil being pumped out then you have 1 of 3 issues.
a) A blocked oil pipe or gauze filter in the tank.
b) A blocked or broken oil pump.
c) A broken or damaged oil worm/drive gear
2. If oil is coming out the oil vein then check that you have the correct bar for the saw and that the oil hole lines up with the oil vein. Also check that the bar groove is clear of dirt and debris allowing oil to travel along the bar.
Feb 18, 2016 | Garden
Bought it used, new bar and chain he said it stopped oiling guessing he has it to gather wrong. looking for a diagram
What Make and Model?
Chain not oiling
Remove bar and chain, run the saw to see if its oiling without the bar on.
If still not oiling, remove the clutch, clutch drum and check the plastic thread on the oil worm.
Also check for blockages in the pipe from the oil pump that feeds the bar.
Lastly check the oil pump is actually functioning properly.
Apr 01, 2013 | Husqvarna 450 X-Torq 18" 50.2 cc Chainsaw...
Oil not goingg to the bgar
Have you cleaned the oiling hole in the guide bar.? Scrape out the full length of the guide bar using a cleaning tool. There is an oiling hole at the back of the bar on either side which the oil flows into.
Is oil being pumped out the saw.? Remove side casing and guide bar, run the saw and check the flow.
Feb 17, 2013 | Stihl 1127 Control Shaft 039 310 290 390...
Husqvarna chainsaw 450 oil leak
The 450 has a very simple non adjustable pump, it sits through a black rubber pick up/delivery pipe, they are quite prone to leaking where the pipe sits up against the crankcase, the part no. of the pipe is 544084201, changing this will help, you can also try using instant gasket to seal it, you will need to remove the clutch , sprocket, and pump plate to get acsess to it.
Oct 19, 2012 | Husqvarna 450 e-series 18" Chain Saw
I was wondering if there is anything I can do about the oil leaking. I have a hitachi cs33eb it is brand new.
The oil pipe is poorly fitted to the oil pump and allows bar/chain oil to sneak past the seal. Buying a new oil pipe may not fix the issue since this is common on brand-new saws. Warranty work probably won't help you.
How I fixed my saw: I bought two small O-rings about the diameter of the oil pump and fitted them to act as hose clamps around the oil pipe. See attached picture. It worked perfectly and now my saw runs out of fuel before oil. Sears/Craftsman have a great video on how to remove the clutch assembly.
Jul 10, 2011 | Hitachi CS33EB16 16" Rear Handle Chain Saw
Haqve model #142 chain saw with very little oil to chain, cleaned every thing all holes are clear new oil and still have problem. also checked worm gear and it is good Have chain saw 3 years, only...
There is a filter in the tank on the end of the oil pick up pipe, if you have checked the gear you must have already removed the cluch and sprocket, if you now remove the two screws holding the pump and take it away, behind here is the pick up pipe, pull it out with long nose pliers and inspect the filter, the later machine has an up graded pick up and delivery tube in one to stop any leakage, if you have a seperate delivery and pick up pipe i would suggest changing to the later pipe part no. 545037101, if this still does not help it will have to be a new pump part no. 530014410.
Apr 07, 2011 | Husqvarna Garden
Stihl 029 super oiler is not working
Pull off the clip and sprocket, then check the spring or wire behind the clutch. There is a notch in the sprocket hub that drives the spring when the hub is spinning. Sometimes the spring comes off the worm gear that it drives. If the spring is not there you need to remove the clutch to check it. It has left handed threads on it)
Mar 08, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Garden Logo
128 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
