Question about Pyle Tablets & eReaders
Tablet will not boot up
Ptbl10c
Rca tablet how do i get out of fastboot mode
You will be stuck in fastboot if you have failed to flash an img file. You will have to boot a boot.img file using fastboot then download the last update to get your tablet back to normal.
Download the following file onto your computer...
K1_A301_03_03_110829_US.zip
Then unzip on the computer. You will see a file named "boot.img". Make sure your tablet is connected to the computer and you have the fastboot binary. Then run the following command in the directory you just unzipped the file
fastboot boot boot.img
This will allow you to boot up your tablet but the bootloader will STILL be stuck in fastboot. Therefore you will have to update your system. Download the same file above into the Download directory of your tablet. Rename it to update.zip. Dowload the following XML file...
K1_A301_03_03_110829_US.xml
and rename it to update.xml (NOTE: the system file manager won't let you change the extension so just rename to "update". Power off the tablet. Then hold down the Volume + key and hold down power button until it comes on. That will boot the system into recovery and install the update. In a few minutes you will be restored and your tablet will work normally. NOTE: YOU MAY LOSE YOUR DATA and may have to reinstall your apps.
If your boot partition isn't a mess like mine was, you may be able to just flash the system partition from the above zip file by using...
fastboot flash system system.img
fastboot reboot
The key is that a fastboot flash must be successful in order for your device to boot normally.
Source: Lenovo
Nov 13, 2016 | Tablets & eReaders
My polaroid tablet will not boot
polaroid pmid701c tablet stuck at polaroid screen when rebooting ...
freaktab.com/.../tablet.../polaroid-tablets/835-polaroid-pmid701c-tablet-s...
Apr 14, 2012 - It just won't go past the Polaroid screen when booting. ... At this pointPolaroid has not released the factory ROM to be reflashed, supposedly sometime within the ... There are ROM's from Onda that does seem to work well. ROM ** Polaroid AS8 ** ROOTED + TWRP
Dec 24, 2013
Polaroid ptab7200 does not turn on
May 8, 2012
More results from freaktab.com
my polaroid tablet won't turn on - Tablets - Android Tablets - Tom ...
www.tomsguide.com/forum/id-2079971/polaroid-tablet-turn.html
Jun 20, 2015 - 6 posts - ‎5 authors
I have a Polaroid Tablet, Model PMID702C. ... Now, it will not power b. ... my tablet wont turn on , and when i charge it its not working how can i ... My Samsung tablet will not turn on. - Samsung
Dec 30, 2015
My tablet won't turn on! - Battery
Jun 19, 2015
my tablet pc got boot loop - Tablets
Jul 28, 2014
Help! My tablet won't turn on! what do I do?! - Asus
Nov 5, 2013
More results from www.tomsguide.com
Jan 01, 2016 | Polaroid Tablets & eReaders
It is stuck on the logo android is there anyway to make the tablet work again
Second one in three days. Seems a know issue.
  • Android tablet stuck on Android Logo Fix - YouTube www.youtube.com/watch?v=B_bJeLnlClE
    • BY RICARDO GARDENER
    • 9 MIN
    • 237K VIEWS
    • ADDED 2014-08-13
    Video embedded · Learn how to fix your tablet that is stuck on the Android logo or ... Learn how to fix your tablet that is stuck on the Android logo or Android start ...
  • How to fix an Android phone if it is stuck or frozen on ... www.smartmobilephonesolutions.com/content/android-stuck-on-samsung ... or it boots up to its Samsung logo then freezes, ... How to fix an Android phone if it is stuck or frozen on the Samsung logo
  • Stuck Android Logo - YouTube www.youtube.com/watch?v=w6tmETIerBM
    • BY KELLER KING
    • 5 MIN
    • 553K VIEWS
    • ADDED 2013-06-13
    Video embedded · This video will show you how to restore your Ekko Tablet T700 if it gets stuck on Android Logo. Este v?deo vai mostrar-lhe como restaurar o Ekko Tablet ...
  • Android Tablet Stuck at Boot Screen - Stack Exchange android.stackexchange.com/.../android-tablet-stuck-at-boot-screen Android Tablet Stuck at Boot Screen. ... Samsung Galaxy tab 3 made in Korea stuck at android logo. ... T98G tablet stuck on boot screen.
  • Dec 29, 2015 | Tablets & eReaders
    Will not boot-up or start
    Hi there, If your tablet will power on, but won't boot up, then take a look through this:How to Factory Reset Your Android Phone or Tablet When It Wont Boot
    If it won't power on at all, try out these instead:
    What to Do When Your Android Phone or Tablet Wont Turn On
    My Android Tablet Wont turn on Anymore And cant take the back off
    If those do not help, then contact the manufacturer.
    I post on behalf of HP.
    Jul 29, 2015 | Tablets & eReaders
    Will not boot-up
    If your tablet will not power up at all, then take a look at these two pages, with have some methods you can try.
    If on the other hand it does power on, but does not boot up, then try this one instead:
    If neither of those help, then I would recommend contacting the manufacturer.
    How to reset SVP TCP-1020 tablet
    In most cases, the battery comes loose from the main connection. Those tablets do come apart, the back just presses on.
    Jul 30, 2014 | SVP 10-inch Tablet
    Rca tablet will not boot
    Here are some common reasons tablets wont boot:
    - SD card full or corrupted
    Remove SD card (if you have one in your tablet) and try to boot
    - Corrupted OS / Application / Data
    Try a reset
    If your tablet is rooted, you can often boot with the bootloader and wipe the application data.
    re-flashing the firmware of the tablet works 99% of the time.
    Jan 30, 2014 | Tablets & eReaders
    Tablet freezes on boot up at android screen
    Do a factory reset. Turn the tablet off. Wait 10 seconds or so. Hold down volume down button while pressing the on button. Keep holding down both buttons until you see an android icon. It may be laying on its back with a red exclamation mark over it, like I saw. Once you see the icon, let go of the buttons and press the "back" or return button. This should bring up a list of options. You can scoll through the list by using the up or down volume buttons. I picked the option to delete all user data, which basically will set the tablet back to factory settings, like when you first got the tablet. Once that is complete, reboot the tablet.
    Mar 24, 2013 | Iview 760TPC Android Tablet, ARM Cortex-A8...
    Tablets & eReaders Logo
    138 people viewed this question
    Top Pyle Tablets & eReaders Experts
    Are you a Pyle Tablet and eReader Expert? Answer questions, earn points and help others
