he f20 (or fh) error code on a Whirlpool Front Load Washer is an indication of a water supply issue. To remove the f20 error code from the display panel, press Pause/Cancel 2 times. If that did not clear the error code, see below for what may be wrong
heres a link...https://removeandreplace.com/2016/01/12/whirlpool-washer-error-code-f20-troubleshooting-front-load-washing-machine/
Hi, To remove the f20 error code from the Whirlpool display panel, press Pause/Cancel 2 times.
If Pause/Cancel did not work: -Disconnect the washer from power for 2 minutes -Reconnect the power to the washer -Select a wash cycle and press the start button
Note:- When the washing machine is started for the first time after removing it from power, it may begin to drain. The pause or cancel will not be able to be used for 8 to 10 minutes while your washer drains.
If the error code f20 or fh comes back on the display, further troubleshooting is needed.
Read through the link provided and check the obvious things first. This is an error code that can have several causes, so you will need to follow the steps provided.
If you still have questions, or require additional assistance, please let me know. I hope this helps you.
