Question about Hoover H-F7425-900 SteamVac/SpinScrub Hand Tool Steam Vac Spin scrub
How do i remove the hood assembly to inspect the spin brush motor?
My spin brushes wont spin. i need to remover the hood assembly to inspect the spin brush motor
  • 9 Answers
SOURCE: brush won't spin
Dear Xana,I have had problems like yours before. More times then not the roller brush "belt" got damaged and needed to be replaced.
You should also check your roller brush and make sure it was not knocked out of alignment.
If neither of these solutions help,then it could be, your roller brush "Bearing Assembly"got damaged which would mean you need to either replace the "Bearing Assembly" if it is removable and if you can find that part.Or else you would need to replace the whole "Roller Brush".
You can normally tell if the "Bearing Assembly" is damaged by trying to turn the roller brush with your hands,if it takes a lot of force to make it turn,then theirs a good chance it was damaged!
These repairs are fairly easy to do, just read your Vacuum manual on replacing parts,also make sure you always have the vacuum unplugged while replacing parts or doing repairs.
I hope this info helps,EarlsOK
Posted on Dec 08, 2007
reddevil6
  • 1673 Answers
SOURCE: Brush assembly will not spin at all.
The turbine is bad, that is what drives the brush roll. You either replace it, sometimes you can take the turbine apart and clean it, alot of times they just get gummed up and won't work. Number 23 is the turbine.94b67a6.jpg
Posted on Feb 19, 2008
reddevil6
  • 1673 Answers
SOURCE: Spin brush not working anymore.
Is the shaft still on the brush block, if it broke off, then replace the block. if it is ok, then the turbine(#13) is most likely the problem. It is what drives the brushs. You may be able to take the turbine apart and clean it, if that doesn't work the replace it.
Posted on Mar 15, 2008
SOURCE: hoover F7431-900 steam vac brushes wont work
the brushes are activated by suction, my berings and gears froze up, i took it apart, kinda hard to figure out, but not as bad as it looks. i lubed the berings and the gears, then i took an air compressor to the activation fins and let it spin, lubed again then hit it with air again, now works better then new.....GL
Posted on Jul 29, 2008
  • 400 Answers
SOURCE: The brushes won't spin. I have removed and
On mine there is an air turbine that powers the brushes. There is a red screen that you squeeze and pull out to clean. Perhaps yours is clogged. If the screen is clear, perhaps the turbine has something binding it to keep it from turning. I hope this gets you on the path to repair your problem.
Posted on Oct 30, 2009
After my son vacuumed up maybe a lego theDiamond G Kirby started sparking from inside housing. We took brush and checked for any loose items and found none. Any ideas and can I diy?
Sucking up a Lego or similar item normally should not have done any damage to the motor. It may stop the brush roll which may burn the belt if the belt is tight. If the item got sucked into the fan it may have broken or cracked it which could seize the motor. Remove the brush roll assembly, spin the motor shaft while you inspect the fan. Fan replacement is best to be done by an experienced technician.
Jan 24, 2017 | Kirby Vacuums
Concerning 1970s 830 Bernina. There is no motor sound..nothing. Are the carbon brushes in the pedal?
The 830 models varied so I'm not sure. My machine looks like this:
Bernina 830 sewing machine feet pedal accessory box table instruction...
If you scroll over to the photo of the motor, there is a white plug which pulls out. Underneath, there is a screw. The carbon brush may be there. However, some 830s had the speed switch on the machine (right above the knee control) and others have it in the foot pedal.
I found the following information in my computer files that may be helpful: Bernina 830 Motor Brush Replacement
My machine is actually a Bernina 830 (mechanical 34 years old) I need to know how to get the housing off the motor so my hubby can replace the brushes
Re: sewng machine motor housing
DISASSEMBLY TO INSPECT OR CHANGE BERNINA 830 MOTOR BRUSHES:
Remove the big plastic cover piece on the bottom of the machine with the single screw in the center.
Remove the machine's end panel by removing the single silver screw from underneath the bottom middle of the side panel. Pull the bottom of the side panel out and down to remove it. It comes off easily.
Remove the two screws under the motor assembly (silver screws with black washers).
Swivel the motor assembly enough to remove the belt.
There is a another plastic panel on the motor assembly over the motor itself. Remove the two phillips head screws to remove this panel.
At this point you can see the commutator and inspect the "business" ends of the brushes. (In our case, one brush was almost gone and there was nothing left of the second brush except the spring!)
You can then slide the motor out of the housing. I pushed on the motor pulley and pulled on the other end of the motor with pliers. The motor comes out rather easily, but be careful not to disturb the wires any more than necessary.
With the motor exposed, unscrew the caps over the brushes and remove the brushes.
Our motor's commutator looks significantly worn and the motor may need to be replaced.
FWIW, if your machine hasn't been oiled for a long time, you should probably take time to do that. When the old oil solidifies, it sticks the moving parts together. Forcing the motor to try to run the machine can damage the machine. Use fresh good quality sewing machine oil or (I use) liquid Tri-Flow Synthetic Lube and apply a couple drops every place metal rubs on metal. (Wiggle the handwheel and watch where things move.) Do NOT oil belts, synthetic gears, cams.
Oct 22, 2016 | Bernina Sewing Machines
Why are the brushes not spinning?
Hi Liz, if your brushes are still in good shape and do not need replacing then I would see if something else isn't broken or busted. You can always check for an obstruction in the brushes or remove the brush assembly & then reseat the brush assembly. Before doing so you should remove both Tanks from your Hoover. Then there are two buttons on top of the Nozzle Assembly that holds the brushes. You will need to release these two buttons on top, then tilt the handle of the unit backwards and this should let the brush assemble fall out of place. Inspect the brush assembly for any obstruction and even check to see if all the brushes still spin okay. If all looks good then align the post on top of the brush assembly with the hole on the bottom of the nozzle assembly and then snap the brush assembly back into place. I know this might sound crazy but did you first check to make sure that you did not have the switch set to "Wet\Dry Pickup." This will stop the brushes from turning as the switch needs to be in the other position to turn.
Aug 11, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Wer is the brushes in a hotpoint aquarius extra as it wont go in2 a spin
YOU WILL NEED TO REMOVE THE MOTOR FIRST TO SEE IF THE BRUSHES CAN BE REPLACED AS SOME OF THE MOTORS FITTED WERE SEALED UNITS. 15 MINUTES TO REMOVE THE MOTOR. BRUSHES ONLY ABOUT £25
Jun 22, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Brushes won't spin
First, please be sure to unplug your Steam Vac and remove both the clean water and the dirty water tank.
There should be a square stem that sticks up in the center of your brush assembly. If this stem is broken you will need to replace the complete brush assembly. If the stem is good; turn your cleaner on it's side and check in the area where the brush assembly goes (with the brush assembly removed). In the center of this area there is a square hole where the stem from the brush assembly goes. The square hole is in the bottom of the turbnie that spins your brushes. Using a large flat blade screw driver (not so large that you'll damage the hole), stick it in to the square hole and try to spin it. It should spin freely, if it is very hard to spin or won't spin at all, your turbine is bad and will need to be replaced.
Hoover part number for brush assembly:48437022
Hoover part number for turbine: 43191008
May 19, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Why wont the brushes spin? I have had this machine for about 3 years and it has always worked great, tonight the brushes will not spin at all, it still sprays and sucks up the water. We took the brushes...
In this machine there is no belt. The brushes actually spin by vacuum and in the turbine assembly there is a small wheel bearign which rusts out. You will need to remove and repair or replace the turbine and gear assembly P/N should be 43191009
Feb 10, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Hotpoint wma22 fills with water but won't wash or spin
Suspect motor brushes need replacing.
Simple task accessed by removing the top of the washer and releasing the clips holding the brushes into the motor - clip on back of brush - to remove the brush assembly.
Replace complete brush assembly.
Feb 16, 2009 | Hotpoint First Edition WMA22 Front Load...
Washing machines
sounds like your belt may be loose or the timer control maybe worn out
Aug 17, 2008 | Hotpoint Aquarius WD63 Front Load...
Sewng machine motor housing
Our motor's commutator looks significantly worn and the motor may need to be replaced. If you find a source for the brushes or a replacment motor, please let me know! Thanks, John john@jldnet.com
Jan 27, 2008 | Bernina Activa 130
Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Jan 22, 2008 | Bissell 8910 ProHeat Clear View Upright...
Hoover H-F7425-900 SteamVac/SpinScrub Hand Tool Steam Vac Spin scrub Logo
29 people viewed this question
Top Hoover Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Hoover Heating and Cooling Expert? Answer questions, earn points and help others
