Question about Whirlpool Refrigerators
Leaking inside back of refrig
Drips at back where comes down from freezer, nothing over freezer vents, seal is good. Can the ice maker cause this?
    New Friend:
  • 3 Answers
If this is a top mount refrigerator (freezer on top), more than likely the drain is frozen. Try defrosting the unit for 24 hrs.
Posted on Jan 02, 2014
SOURCE: refrigerator drip
My SZ 550 (fridge over freezer) dripped constantly. Turned out to be a frozen drain tube, located 6 inches above the refigerator floor, centered on the back wall (cold side of refrigerator). Remove both trays and the lower glass shelf to see it. This tube runs down, behind the freezer, dumping refrigerator condensate in the pan below the freezer. If it's frozen the condensate leaks out the front of the fridge, down and onto the floor.
The fix, suggested elsewhere (not my idea) is quite simple and elegant. Thaw the tube (this will take an incredibly long time.) Fish a string (I used a piece of yarn) from the refrigerator (cold) side of the tube, down and out the other end, under the freezer. I was able to use a vacuum to suck the yarn through. Be creative. Once the fish line is in, tie a piece of nylon fishing line to the yarn and pull it through the tube. You have replaced the yarn with a stronger fishing line, which you can use to pull a piece of copper wire (I used common 14 gage romex, stripped of insulation through the drain tube. Leave the copper wire in the tube. If you wind the bottom end of the copper wire around some of the warm evaporator coils under the freezer the heat will be sufficient to keep the tube from freezing. I did this about a year ago and have had no problems since. Good luck.
Posted on Mar 08, 2008
  • 1073 Answers
SOURCE: water leaking from inside of refrig.I think it could be Ice maker
defrost the freezer drain tube with a hair dryer
Posted on May 09, 2008
  • 112 Answers
SOURCE: Ice forming bottom of freezer leaking out the door
It is acutually a collector pan for the drain hose. When the refrigerator runs a defrost cycle (about every couple days), that pan collects the water from the ice that is melted and drains it through a hose inside the unit, to a pan under the unit. You will have to pull the back panel off the back of the freezer and melt it with either hot water or a hot blowdryer. Do it until you see the water draining freely into the bottom pan.
Posted on Oct 18, 2008
SOURCE: Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Posted on Apr 28, 2009
Sea Breeze
  • 4655 Answers
SOURCE: We have a GE Profile refrig, circa 1995. The ice
If you are sure it is caused by the ice maker or if it is not it can be fixed. The only way an ice maker would leak like that is if ice is blocking the inlet tube and when the water comes on the water is spewed in a different direction than the ice maker. Most times this is caused by a slow leak in the water control valve for the ice maker side at the rear of the refrigerator. You can stop the problem by melting the ice in the fill tube with a hair dryer and keeping an eye on it until you see ice beginning to build up there again. That would indicate a slow leak in the water control valve that is not closing all the way when off. The other reason for large pools of ice in the freezer is a frozen over defrost condensate drain behind the cover in the rear of the freezer and would require you to unplug power and remove the rear panel. I will try to get some photos and a link shortly that covers that problem a lot more in just a few minutes. Sea Breeze
Posted on Aug 20, 2009
I have a samsung rfg297aars refrig. I believe the water is leaking from the ice maker into the cube tray and running out and freezing in the cube dispenser and it is freezing the cubes together and...
you need to check the flapper in the door where the ice comes out,, if you take the ice bin out look down in the hole where the ice comes out,, if it is not sealing good it will let warm air come up the chute and melt the ice,, if it is sealing good,, then you need to check and see if the water fill tube( the one that goes into the icemake) is not froze up or has asomething blocking it
Jan 19, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
I have a Kenmore side by side refrig (no ice maker) Freezer works fine. The refrigerator side is not cooling. I have cleaned out the vent between the freezer and the refrigerator section by defrosting the...
Check to make sure the evap fan is running.
IF so, then let unit defrost, then turn back on, check for air comming thru top of refrig vent, if air moving ok, then let run for a few days and see if refrig warms again, if so then check for frost build up on back wall of inside freezer, if so, you have a defrost problem. With a defrost problem, defrost heater may be bad, defrost timer/electronic control may be defective. Either way, in most cases it is a defrost problem unless you don't have air moving and fan is running in this case you have a damper door problem inside air duct in refrig.
Sep 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker leaking inside freezer compartment, water dripping down from unit
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Leaking ice maker
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze diverting the water. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 | Freezers
Refrigerators Logo
56 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
