Question about Vacuums
Jaguar 2 no suction - Vacuums
  • 55 Answers
Belt off or broken -- roller froze or not rotating
Posted on Jan 02, 2014
If I put a smaller diameter hose on my shop vac will it create more suction power?
Yes, in one way the suction would be higher, but there would now be an additional load on the motor. Also, it would have more suction, but less volume (air flow).
Mar 18, 2015 | Shop Vac Vacuums
Miele, Flamenco II. 2 probs. 1. the head brush is not turning when I put it on the floor. If I pick it up to look inside...the brush is spinning fast..I put it down on the floor...the head does not...
sounds like the belt is not on correctly on the beater brush or the belt is worned out now for the suction check filters or bags that need to be empty or clean
Feb 16, 2011 | Miele Vacuums
I have a Dirt Devil Jaguar bagless vacuum. It used to work great. Now, it is blowing a huge amount of dust out of the front of the machine as I try to vacuum the carpet. can this be remedied?
This generally happens if the hose system is clogged. No suction so the power head brush just kicks out the dirt and debris you're trying to pick up, and loose stuff that is currently in the hose system. If it has been doing this for quite a while, or has been used with blockage, the motor has to work harder and will eventually burn out, if there is no overheat shut of switch in the cleaner.
Check all parts of the hose system, from the power head to the tank. Clear all clogs. That should take care of the problem.
Another possibility is that the fan blades are broken or worn down. This would result in no suction even though the motor is running.
Dec 09, 2010 | Dirt Devil Vacuums
No suction
there are two reasons for this 1 is the belt in good order 2 thevac is blocked unblock then trouble free
Aug 12, 2009 | Hoover U6630-900 WindTunnel Bagless...
Bissell ProHeat 2X(9200) hose to cleaner solution no suction
There are a couple areas to check:
1. The black gasket where clearview water collecting unit and the base's front meet. Ensure gasket is in good condition.
2. Check if you're getting sufficient suction: remove the water collecting unit. When you turn on the the unit, you'll feel suction out of a black hose pointing upwards next to the grey dial. If you're not getting sufficient suction you need to check that all the gaskets are seated properly. there are 3 gaskets: (1) an orange one seated between the black hose and the base unit (2 and 3): On the bottom of the unit there is a removeable panel. This panel has a gasket (red) and inside there is a white gasket.
Jun 30, 2009 | Bissell 9200 Upright Vacuum
My kenmore centtral vac runs but does not ****. HELP11
#1 i assume u checked the bag and filter if so equipped?
#2 verify the hose is not plugged
#3 verify hard plumbing not plugged by taking something metal (quarter) and crossing the 2 little metal nubs at inlet (don't worry it is low voltage u wll not get shocked) it should ****
#4 if hard line plugged you may need a second vacuum to reverse flow
are all outlets not creating suction f so detach vacuum from piping and verify that vacuum is not the problem
May 06, 2009 | Vacuums
Suction through hose but not base
mine did the same when new, i checked all as above then i noticed that i could twist the round peice that will unplug) (right behind the carpet-bare floor knob) and then i got suction at the base to be able to vacuum the floors, then i notice that there was a peice of plastic broken off that actually pushed a black latch down when either pushing the handle all the way up or down this lets the round piece i'm talking about swap over from base suction to handle suction! hope this helps and everyone can understand what i'm talking about! you have to look close to see where the 2" by 2" piece of plastic is missing!
Feb 25, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dirt devil suction not as good
If the belt and filters haven't been changed in over a year, then that could be the problem. You could also have a clog in the hose.
Mar 01, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
