Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Plug in and light works and clock works but wont do anything else
Is there anything I can do with the horn and cruise cntrol not setting from steering wheel buttons?
The clock spring inside steering column ,under the steering wheel . Is the air bag light lit on the instrument cluster as well ? What make , model and year vehicle . How cars clock spring works
Jan 09, 2017 | Cars & Trucks
Hotpoint oven bs43
you need to send the full model number,most likely you have a bad clock assy.even though your clock might work it comes with the clock and a computer board all together.i never heard of resetting a timer,i do know that if you unplug or shut down the power from the fuse box for 5 to 10 minutes sometimes resets the computer just like a regular house computer, it sounds like your loosing power and i don't think resetting anything is gonna help you,also make sure you have 240 volts going to the oven,but if the fan and light are not working and no heat it sounds like you have a bad clock assy.if it's in good shape and depending on the age you might want to call someone in to check it for you,if it is the clock assy. it might not be avalable anymore but there are companies that can rebuild the clock assy. you have.good luck with your oven.
Jul 10, 2013 | Ovens
1997 Saturn SC2 wont start electrical issue
Some check light on dahsboard or "theft" system there?
Jun 26, 2012 | 1997 Saturn SC
We tried to use or keypad lastnigt- nothing on it will do anything. Light inseide is on and is telling us to press clock.
Your description sounds like power failure, after failure on some machines you MUST set clock next. Before you do anything, unplug unit for longer than 45 seconds, then plug in, set clock and go from there.
Sep 26, 2010 | Microwave Ovens
My washer will not start. The lights come on, and the water is turned on but it will not start anything but lights
If electronic control, try pulling the power plug for a little while, then retrying. If older clock driven control, try turning the knob manually to see if anything happens. If it does, the clock motor on the timer may be stuck. Probably have to replace entire timer unit to fix.
Jul 16, 2009 | Washing Machines
Rangemaster clock
Try first unplugging power cord for ten minutes, then plug back.
Press the selector wheel for 5 seconds and see if this reset it.
If that does not work , then you need to replace the control assembly. YYou find diagrams and replacement parts by entering the model number here:
replacement parts and free diagrams
Oct 23, 2008 | Rangemaster 110 (Gas) Kitchen Range
Setting the clock
Remove the plug from the socket for a few minutes. Then plug it back. Does the clock control blicking? look at the pictures on the control as a whole.
Do you see anything like a table clock? press it once, then press the numeric pad or up and down arrow button depending on the model you have. press enter or start if set correctly.
Jul 24, 2008 | KitchenAid KGST307 Gas Kitchen Range
ELECTRONIC DISPLAY WONT RESET
i think you have to set your clock manually lift the top up by the florecsent lite there should be instructions
Dec 16, 2007 | Kitchen Ranges
Emerson iTone iC200 Clock... Problem
I get no sound on either the radio or CD player. I need help.
Nov 17, 2007 | Emerson iTone iC200 Clock Radio
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
18 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
