Question about Irons
Sunbeam repair how to clean and oil and tension bar keeps sticking
Sunbeam iron model gcsbcs-212 troubleshooting unit keep turning off while ironing
The iron is getting to hot internally and setting off the high limit switch. Since these cannot be repaired by design, you will have to replace the unit.
Mar 23, 2017 | Sunbeam Irons
Cleaning iron non-stick soleplate
Soak bottom of iron in vinegar until build up comes off easily. May also use an SOS pad with vinegar.
Jan 25, 2014 | Sunbeam Irons
Cleaning non stick soleplate on iron
Soak in vinegar until softened wipe off. If needed use rough side of a sponge or SOS pad to aid removal.
Jan 25, 2014 | Sunbeam Classic Iron - GCSBBV-212
How to clean a non-stick sole plate iron
I had this iron, and have since gotten rid of it. I cleaned the iron by running it with a solution of vinegar and water, about 1/2 and 1/2. Ran the steam until the solution was empty, and cleaned the nozzles with a q-tip at the same time. It worked temporarily.
May 22, 2012 | Sunbeam 4214 Iron
I have some buildup on the soleplate which is 'non-stick'. How can I safely remove this?
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaning a Steam Iron Soleplate
heatman101
Dec 22, 2010 | Sunbeam Steam Master 4055 Iron
My non stick sole plate on my Sunbeam iron is discolored with a rusty looking color that's coming off on my clothes. I keep it clean as can be, never leaving water in it,but this rusty looking dried on...
The discoloration is from a reaction of your water and the shield. The best way to avoid this is to use distilled water rather than tap water or use a water filter. I have had this problem at home as well (i have well water) and using a filter "fixed" the problem for me. Hopefully this will resolve the problem for you as well.
Please let us know if you still have the problem and we'll look for other alternatives.
Dan
Oct 31, 2010 | Sunbeam 4214 Iron
Sewing machine keeps skipping stitches
Generally, it means that the bobbin is too tight in the cavity.
1. Remove the bobbin
2. Try a drop of oil in the bobbin cavity in the machine, using a Q-TIP
3. After applying the oil, use a clean Q-TIP to remove excess oil in the cavity (may need more than one clean Q-TIP).
4. Replace bobbin.
(I'm sure you already tried differenty thread)
Hope this helps!
Sep 01, 2009 | Kenmore Irons
Sunbeam Steam Master Iron 4048-015 stopped working after cleaning. Will not heat. Can it be opened to look inside?
any steam iron more than a few years old...usually isn't worth repairing.  Just buy a new one.
Mar 24, 2009 | Sunbeam Irons
Cleaning non stick iron surface
There is a product called goo-be-gone available at any hardware store in a small bottle which will remove the adhesive easily.
please mark this as a fixya! thanks
Mar 17, 2009 | Sunbeam 4237 / 4238 Iron with Auto...
Sticking
Here is a tip that will help you with that problem...
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Apr 27, 2008 | Sunbeam 4214 Iron
Irons Logo
64 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
