Question about Microwave Ovens
Replacement part i broke my coffee pot and i was trying to c if i could get a replacement pot for my microwave
  • Microwave Ovens Master
  • 8,803 Answers
Re: replacement part
Sears Parts at (yes the three is correct)
Posted on Oct 22, 2007
0 characters
3 Points
When putting the lid back on my coffee pot I screwed it on in the wrong position and I cannot get it off.
put your coffee pot in the oven on warm lowest setting for 15 minutes, take it out and try it.
Apr 08, 2011 | Microwave Ovens
I would like to purchase a 9 cup corningware purcolator coffee pot
Click the link below:
Corningware coffee pot
Be CAREFULL they were recalled. See the information at the site below.
Corningware coffee pot recall
Good Luck.
Mar 16, 2011 | Microwave Ovens
What am I doing wrong. Cusinart 1200 less than a year old. Takes an hour to brew. Took out permanent filter and use paper #4 filter. Has been slow since I bought it. Please advise. Other than that,...
Try cleaning it with vinegar. Sounds like you need alot of help on this one run a full pot of vinegar through the machine. with a paper filter in the basket. then run two to three full pots of just water. this should help decale the coffee pot.
Mar 09, 2011 | Microwave Ovens
I have a Black 4 cup Mr Coffee with luminate lighting and time display programer so that I can have coffee brewed in the morning when I get up for work at 4:30am my problem is the coffee pot has started...
I had a black and decker coffee pot do same thing and it was brand new. here is how I fixed it.
make sure the filter seated down good. If you look at the top of the coffee pot it should open up the little valve of the coffee filter holder. also mine had a little water spout above the coffee filter that swings over the filter. make sure it is over the filter. I know my coffee pot is different, but I think the problem is the opening from filter to coffee pot is not open some how so the water is flooding over the filter and going out the sides onto counter
hope this helps
Jan 28, 2011 | Microwave Ovens
Plastic ring is broken inside coffee pot - replacement lid or complete pot is needed for 12 cup barrista unit. Thanks.
I read in a web blog that Starbucks will send you the needed parts (for free) for the coffee pot if you contact them and let them know what your problem is. Here's their site:
Good luck, and hope this helps.
Nov 09, 2010 | Microwave Ovens
My coffee pot quit working. it turns on but doesnt warm up or start brewing. how do i fix it
Either the heating element is open, the thermostat is open, or the overheat fuse has popped. You can probably replace the pot for what it will cost to repair it. Good luck!
Oct 09, 2010 | DeLonghi Microwave Ovens
Unless there is a clock, they use no current when turned off.
Apr 30, 2009 | General Electric Microwave Oven
Kenmore Microwave / coffee maker leak
I have a Kenmore Microwave with built int coffee maker (Model 721.63999303). The coffee maker works, but the microwave doe not. Can the microwave be fixed ?
Apr 12, 2008 | Kenmore 63993 Microwave Oven
Microwave Ovens Logo
248 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Barrett Palumbo
Barrett Palumbo
Are you a Microwave Oven Expert? Answer questions, earn points and help others
