Gateway LX6801-01 auto reboot
I have a new gateway LX6801-01. Just bought it in Feb. 2009. Just recently it has been rebooting it self for apperant reason. Will do it quite a few times in a row and sometimes it will go days with out doing it.
  • 2 more comments
  • eva8773 May 20, 2009
    No. There is no warning or error message that appears before it reboots. And when it comes back on a window appears that says the computer was not shut down properly.
  • eva8773 May 21, 2009
    This does help alot, I will try a new power cord. Also it is a desktop computer not a laptop.
    Thank you very much for your help. I will give it a try.
  • Chris
    Chris May 11, 2010
    Does it provide any warning or error message on the screen when it's about to reboot?
While this may be an old thread....
i fixed one of those same PCs by putting a 120mm fan
on the side of the case blowing on the video card. it seems that it was overheating and causing the reboots. it has not done it once since
Posted on Dec 28, 2009
I have to agree with river 100. Mine was still under warranty but I did not care as I was not going to have Gateway fix it. I got a additional fan put in after it kept shutting down three days in a row and it was not even hot (temp wise in the house) but checking core temps they were getting hot. Since fan install no more problems. Obviously lousy design
Posted on May 14, 2010
  • 696 Answers
Ok, thank you for that clarification.
A restart like you describe is generally a hardware problem, usually either unstable voltage from the power supply, or overheating in the CPU, both would prompt immediate restarting to prevent damage to the laptops core hardware. Please look at the bottom and sides of your laptop, you will see a couple vents, the one on the bottom is an intake for the CPU fan, the one on the back/side is the exhaust.
With the laptop on put your hand beside the exhaust port, you should feel a fairly steady stream of hot air comming out. If you don't the fan is most likely dead or blocked. If you do then it is working and your AC adapter is likely failing causing bad voltage.
Although there are a couple other possibilities these are the two most likely. If the fan is not spinning, try using a low preasure head on an air compressor(25lb/sq" max) to blast the dust or debris out of the vents and try firing up again. If this doesn't work, test the voltage coming out of the AC adapter with a voltmeter, if it doesn't stay stable and match the markings on the bottom of the adapter(19V) it is the cause.
If neither of these solutions pans out there are still some options but most involve removing internal parts that require some skill.
Hope this helps FixYa, if it doesn't get back to me and I'll try a few more steps.
Chris
Posted on May 20, 2009
  • Chris
    Chris May 21, 2009
    Sorry,
    My bad was think MX series, being a desktop, you can also try looking inside while it's running to see if the CPU fan is spinning or not and visually check for dust buildup. If it's clean and the fans are spinning check the capacitors for bulging. They are tall cylinders with a hash mark in the top. The tops should be flat, if they are bulging or leaking that's usually the problem, causes voltage issue on the motherboard.
    If the fans are OK, the Caps are OK and the new cord checks out, then it's likely the power supply. Disconnect all the PS wires from the harddrives CD/DVD and motherboard then take it into a local computer store and they should be able to sell you a replacement. They are one of the easier things to replace.
    Chris
Gateway NE56R34u
I'm a bit confused, Task Manager? Out of the box new? Remove ALL media, DVD, CD, USB, Unplug, remove battery, plug in , reboot. If that fails Return it.
Apr 26, 2013 | Gateway Computers & Internet
My Gateway computer will log me on to a black screen where I can't see my desktop or right click to adjust the apperance. I tried "ctrl" "atl" "del" and I was able to get the task manager up, and open up a...
Once your task manager starts click on application and then new command type explorer in the popup and hit enter. This will solve your problem for now. If you wan't to make this permanent on every startup. then add explorer program to your startup list
Mar 14, 2010 | Gateway M6307 Notebook
I do not have a reboot cd for my 7330 gateway laptop. I need to reboot my computer back to its original state as I bought it.
To do this, you must have the original software. Visit Gateway/support and see if they will provide you with either a CD version or if you can download the image.
Oct 19, 2009 | Gateway 7330GZ Notebook
My gateway 7330 will not reboot.white letters and black screen er
format your system and re install Windows,
this is master boot problem.
Jun 30, 2009 | Gateway 7330GZ Notebook
Reboot to original settings
start in safe mode, then restart it normally
Feb 27, 2009 | Gateway Profile 4M PC Desktop
Letters on Gateway desktop keyboard not working. Tried Rebooting.
First check the Device Manager and see if there is a problem with the device driver. If you see a yellow! or a redX, then right click on it and choose to update the driver. In fact you may just update the driver anyway, it will not hurt anything. If updating the driver does not work there is not much else you can do with a keyboard; they are pretty simple machines. You may have to just replace it.
Dec 27, 2008 | Gateway 2520915 Keyboard
My computer keeps freezing when i turn it on
reboot the machine. tap the f8 key and select safe mode. boot into safe mode and see if the computer freezes up again.
in the event it doesnt, you have a bad driver or new software on the drive. to correct this go to gateway.com select your model and download any recent updates including the bios. also uninstall any new service packs or software you had loaded recently.
reboot machine and see if you have the same error.
if this continues or it froze in safemode you could have two problems,
1. Corrupt OS files, the fix: Restore Machine after backing up data.
2. GPU having issues and heating up to the point it turns off, the fix: Local repair shop or Gateway replace mobo or local repair shop reflow board.
Let me know what you try and what works! Good Luck!
Ruben
Nov 08, 2008 | Gateway MX8711 Notebook
Computers & Internet Logo
574 people viewed this question
David Payne
David Payne
