Question about Kenmore 2942 400 3.2 cu. ft. Top Load Washing Machine
Washer wont work
Washer turns on fills with water then stops. switching power outlet worked for a few minuetes than same thing happened
  • 1314 Answers
SOURCE: Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Posted on Dec 31, 2007
  • 1028 Answers
SOURCE: washer won't stop filling and go to next cycle automatically
if not running over ck to be sure drain is proper height and end of washer drain hose is not too tight in standpipe sound like siphoning after 1st wash and not filling to advance to rinse also be sure washer dring hose is not more than 6-8 in into standpipe
Posted on Aug 16, 2008
  • 1122 Answers
SOURCE: Washer will not fill with water.
YOUR INLET WATER VALVE ON THE BACK OF WASHER HAS FAILED,HAVE YOU TRYED IT ON COLD ONLY,HOT ONLY TO SEE IF ONE OF THE VALVES WORK?IF NOT YOU CAN GO TO SEARS .COM CLICK ON PARTS PUT IN YOUR MODEL NUMBER AND YOU CAN ORDER THE PART YOU NEED,LET ME KNOW HOW YOU DO-MIKE
Posted on Nov 01, 2008
  • 63 Answers
SOURCE: Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Posted on Nov 12, 2008
larryyb
  • 291 Answers
not your timer / if anything its eather the water valve or the water slector switch
Posted on Nov 24, 2008
Water will not stop running into washer
one of 2 things can do this,first unplug the unit from the power if it continues to fill then its the water fill valve thats bad,second if it stops filling when unplugged from the power outlet then its probably a plugged pressure switch line from the tub so the water pressure cannot switch the pressure switch diaphram from fill to wash cycle,open the cover and remove the pressure hose from the tub and blow into it and you will hear a click in the pressure switch its connected to,then replace hose onto tub side and blow into the other end of this same hose and make sure theres air movement in the tub as you will see and hear bubbling noise
Jun 03, 2012 | Samsung WF448AAP Front Load Washer
Maytag neptune front loader
check the following
power cord plugged into a grounded 3 prong outlet
the inicator on the cycle conrol knob proprely lined up with a cycle? turn the knob to the right slightly then pull the knob
are you using a extention cord if so dont
washer overloaded
Jul 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My washer will not stop filling with water and overflows
Turn the washer on and let the water run, while the water is running unplug the power cord if the water stops the inlet valve is ok but if still running the valve is bad and need to be replace if the pump is good you need to test the water level switch, if faulty need to replace.
good luck
Mar 17, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer will fill up but after that nothing happens?
The lid switch is my first thing to check. There are two wires going to this switch, jump these together and this will tell you if it is working. The clicking noise won't tell you for sure.
Next, you need a volt meter to see if power is getting to the motor, if so, you have a bad motor.
Jan 23, 2009 | Kenmore Washing Machines
Maytag HAV2360AWW will not start
Check the back of the lid their is a litel plastic button to make sure the lid is closed see if not broken or stack
or see if drain pomp V belt is out of place or broken
this is the simple way
Dec 19, 2008 | Maytag HAV3460AWW Top Load Washer
Got a hoover washer /dryer wdm 1300 , it wouldnt empty properly, watched the impellor on the pump and some times it would run and then stop , a quick flick with a screw driver and away it went again ,also...
HI CHECK THESE....
Step 1: Make sure the washer is receiving power. Check the cord, the plug, and the outlet. If a wall switch controls the outlet, make sure the switch is working. Look for blown fuses or tripped circuit breakers at the main entrance panel. If the unit is receiving power and still won't run, press the reset button on the control panel (if the washer has one).
Step 3: Make sure that both water faucets are turned on and that the drain and soap-saver return hoses are properly extended, without kinks. If the washer has a water-saver button, make sure the button is depressed; water may not circulate through the filter nozzle if the basket is not full and the button is not depressed.
Step 4: To make sure the water is the proper temperature, check the temperature selector switches on the control panel to make sure they're properly set. Also check the water heater temperature control. It should be set no lower than 120 degrees F.
THANKS
Sep 12, 2008 | Washing Machines
Kenmore heavy duty 70 series extra capacity
This could be from a few things. First test. Turn on the washer to fill it up about 3/4 the way. Now turn it back off. Does the water stop? No? You probably have a bad water valve. Replace it. Yes? Listen for the sounds of running water or look for water on the floor. Do you see/ hear this? Yes? Your pressure hose has probably come off, reattach it. If it does turn off and there is not further sounds or leaking water, you probably need to replace your pressure switch.
Jun 15, 2008 | Kenmore 24032\24036 Top Load Washer
WASHER STOPS AFTER A FEW MINUETS INTO THE WASH CYCLE
you didn't say if the machine had filled up with water and stopped after that, if that is so then the place to check first is the heater element for open circuit, this will be located at the bottom end of the drum area, remove plug before testing, work safe, hope i have helped a little, if the machine has not finished filling check the water supply first then the water solenoids. hope i have helped, if so rate me please
Sep 12, 2007 | GE WBSE2090A Top Load Washer
Kenmore 2942 400 3.2 cu. ft. Top Load Washing Machine Logo
35 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
