Error message 41comes up in my HP PC when trying to print from my HP F380 All in One printer
    Master:
  • 630 Answers
I suggest you link this link all 41 error message and answer available so read it and i hope solved you problem.
http://www.advancedlaser-hp-error-codes.com/error_41.htm
If any problem contact HP Printer Support Technician.
Posted on Feb 06, 2014
Candyhelp
  • 136 Answers
SOURCE: HP DESKJET F380 ALL IN ONE
try disconnecting and slide the paper rack press paper firmly into slot
Posted on Mar 18, 2008
SOURCE: I Have a Hp Deskjet
How do I download and install the software? To download the software, do the following:
  1. Click here to go to the Software and Drivers page for your product.
  2. Click your operating system.
  3. In the Driver section, click the appropriate software driver.
  4. Follow the instructions on the page that appears to download and install the software.
How do I install from the CD? Two installation options are available when installing the software and drivers from the product CD. The recommended install installs everything your device requires to work, including a suite of software recommended for your installation. The custom install allows you to choose what software to install. The recommended install is designed to work for most users. Use the custom install only if you have one of the following reasons:
  • Low hard disk space on the computer.
  • You do not want the additional software.
  • Errors occur during the recommended installation. NOTE: If errors occur during the recommended install, fix them before doing a custom install.
Recommended install Complete the following instructions to install the software: CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Choose unblock or accept on all firewall messages or the install will fail.
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer starts automatically. NOTE: The User Account Control screen might display. Click Continue .
  2. Click Install on the Thank you for purchasing from HP! screen.
  3. Click Next on the Welcome to the Install Wizard... screen.
  4. Click Next on the Do Not Block HP Install Wizard Processes screen.
  5. Select Yes or No on the Automatically Check For Updates screen and then click Next .
    • Choose the Yes (recommended) option to check for updates through an Internet connection.
    • Choose the No option if you do not want to check for updates.
  6. Select Recommended on the Installation Options screen, and then click Next .
  7. Follow the instructions on the screen that displays to finish installing the software.
Custom install CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Select unblock or accept on all firewall messages or the install will fail.
  6. Select Custom on the Installation Options screen, and then click Next .
  7. Select which software to install by selecting or clicking to clear the check box next to each item on the Custom Installation screen. Click an item to see its description and the required disk space. NOTE: You must install the drivers and the HP Imaging Device Functions for the buttons on the front panel to be functional.
  8. Follow the instructions on the screen that displays to finish installing the software.
Posted on Aug 19, 2008
ronaldsuboc
  • 449 Answers
SOURCE: What to do? HP Deskjet F380 Error with Cartridge 21b.
hi!!!
removed the cartridge
and placed it back properly!!!
Posted on Oct 26, 2008
  • 4 Answers
SOURCE: HP Photosmart 2610 printer - had been using the
Have you tried replacing the cartridges all together? That worked for me. I use HP 96 and 97 cartridges.
Posted on Jun 16, 2009
SOURCE: print from nokia E63 through WIFI
Try connecting your printer directly to the wifi router/switch in a shared network configuration. Then go to your router settings, find the local ip address add this as the 'host'. Your settings should be as follows:
Driver : HP Mobile Printing
Bearer: Socket/HP Jetdirect
Access Piont: My Home Wifi (kaba)
Host : ip address of you printer
user : Blank ( tried my windows username,no use)
port : 9100
Printer Model: Officejet Printers
You will have to reconfigure your drivers on your pc as well. Mine installed as a wireless shared printer even though the printer is not wireless but I have it connected to my wifi switch for sharing and it worked fine.
Good luck
Damien_1977
Posted on May 20, 2010
F380 printer will not SCAN - keeps giving error message
Do you have original CD with you? if not down load the full feature drivers from hp web site. Un install the drivers, re-install once again..verify your driver CD supports the OS what you are using?..
Feb 03, 2012 | HP DeskJet F380 All-In-One Printer
My hp dekjet F380 all-in-one
Do not place any paper on the scanner and open the lid and press scan button and check if the light glows and moves forward and backward. If the light does not glow its a problem with scanner light.
Also try to uninstall and reinstall the printer drivers.
Else please refer the weblink given below
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00704831&cc=us&lc=en&dlc=en&product=1128296
Jan 20, 2010 | HP DeskJet F380 All-In-One Printer
My hp deskjet printer can not copy or scan
Error message?
Just put something on the scanner glass and press the print button in the printer itself, leave the computer alone.
Did it work? if so... there's something wrong with the HP software, re-install.
That machine takes copies without the computer on, so, it should work.
Sep 12, 2009 | HP DeskJet F380 All-In-One Printer
HP F380 All in One - Scanner Cant Scan, Photo Copy. but can print
I need a some more information from you. What is the exact error message your getting?  In the mean time try this and report back.
Try this first, shut your system all the way down (computer) then once the computer is shut down, turn your printer off and then boot your computer system back on, disable all running programs and then turn on your printer and report back what has happened, try your functions and see if the all in one works or if you get an exact error message. Sometimes it can be a driver conflict or a bad bulb, I am not sure until I can get back some more information from you.
Jan 07, 2009 | HP PSC 1510 All-In-One InkJet Printer
I have a HP Deskjet F380 All-in-One. Error light keeps flashing.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | HP DeskJet F380 All-In-One Printer
HP F380 Error message
your alignment is not detected properly
first check your print cartrages are ok or not if it is ok the align print cartage and put it in the scanner and once scan it
Jul 18, 2008 | HP DeskJet F380 All-In-One Printer
Mar 18, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380 All-in-One Compatible with vista
I had the same problem. I could print, but not scan.
However, if you open up Paint and go to file and scan, it will scan your document. For some reason, using the scan button on the printer itself will not work with Vista, but using Paint will. I also heard that using Windows fax and scan will also work.
good luck
Nov 21, 2007 | HP DeskJet F380 All-In-One Printer
15 people viewed this question
jasbo
jasbo
