Where can I get a power cord for the Kodascope 8 Model 70 8mm projector?
I have the projector but not the power cord. I'm wondering if there's a particular kind of modern power cord that may be adapted for it. The projector has two circular prongs to receive one end of the cord.
  • Philip Ardell
    Philip Ardell Jan 01, 2014
    This was my first time using this site, and my question was listed under Standard Televisions, although it properly belongs under audio-video or electronics.
Noggin
  • 944 Answers
SOURCE: Rainbow Vacuum Model D3B
If it won't work without a ground wire, but still works with one, then you must have a ground/earth connection to make it work - it sounds like there is a safety device that needs an earth to release, you could almost certainly bypass this relatively easily, but it will be there for a good reason and that would be dangerous. Bearing this in mind, regardless of which 2/3 prong adaptors you use, without an earth connection it will not function without risk probably of electric shock from the case or damage to the vacuum, else the safety device would not be there. Get an electrician to your home, and make him install grounded sockets where necessary (should be all, but at least get a couple). Ungrounded/unearthed domestic power sockets at all domestic AC voltages are lethal eventually, to man or machines. A lot of devices don't need an earth, but especially something with a big motor or a metal case usually does. At least ask a local electrician what he thinks. If you want to do it yourself, an Earth circuit in your home is not too hard to achieve if you have basic wiring skills (and access to the ground floor), but most insurance would dislike the idea - if you want to - post again and I may talk you through it. Hope this helps :) Please be careful :(
Posted on Mar 24, 2007
SOURCE: I have a 4 prong
Purchase a 3 prong cord at a home improvement center. and replace your 4 prong cord. all you need is a screwdriver.
Posted on May 02, 2008
  • 233 Answers
SOURCE: I have a MPC Client pro Model N373N1, I need an A/c adapter 20V 8
Find what voltage and amp rating you need and look for that. Also there are universal adapters around that can be set to your requirements.
Posted on Dec 24, 2008
jsrock516
  • 5911 Answers
SOURCE: changed from 3 prong to 4 prong power cord ,now theres no power.
Please review the following link:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Do you have your power cord wired correctly? Please read through the link thoroughly and confirm the wire color coding and the placement of where you have the wires terminated. I hope this helps you. Let me know if you have further questions.
Posted on Jan 04, 2009
aborcass
  • 2651 Answers
SOURCE: have a three pronged power cord, need a four pronged power cord
four prong sould be installed as followed, black and red go to eitehr ends( amkes no difference which, white goes to middle and the green wire gets screwed directly to the dryer cabinet itself( usually an existing green screw just outside the connectin box. if there no power after that then check to be sure oyou indded have 220v going to the outlet
Posted on Mar 28, 2009
No power on light
That's interesting.. After researching that model I can tell you that it has an intergrated internal power supply(transformer) which does contain a fuse. It is located where your power cord plugs into, inside the unit, start with that. Was it plugged into a surge protector? When you had the power failure the second time was there a fluctuation of power, ie your lights in your house flickering on or off or increasing, decreasing in brightness? This will help me determine if it's something else. Also be sure to check your power cord, look for any kinks, breaks, chips in insulation. Anyway Good Luck
Sep 29, 2007 | Sony VPL CS4 Multimedia Projector
Seeking archive maint. ops manual for kodak kodascope model 1 16mm film projector
Contact the George Eastman House in Rochester, NY for a possible connection to get a copy of the Kodascope user manual. Most dealers stopped repairing these years ago. Hope this helps !! Jim
Nov 19, 2011 | Office Equipment & Supplies
Kodak kodascope pageant model 1 16mm film with sound projector
Contact the Eastman House in Rochester, NY for a possible lead for a repair manual and/or a qualified repair person. I will tell you that Kodak has not had parts for Pageant Projectors in about 20 years - - - but many authorized repair dealers may still have some!!
Good Luck !! Jim
Kodak 16mm projector
See my other response! Check with the George Eastman House in Rochester, NY for leads on the manuals! Good Luck !! Jim
I bought this projector and it wont plug in. It came with two cords. One to move the slide from one to the next. The other cord to plug it into the projector on the side but it wont plug into the...
I suggest you contact: www.micro-tools.com They are a repair / spare parts re-seller. They have a wide assortment of Power Cords, and if you provide them with the manufacturer & model, they should have a cord available to fit your projector. Good Luck!!
Mar 25, 2011 | Office Equipment & Supplies
InFocus LP 250 Multimedia Projector was working fine until i unplugged it and when I went to plug it back in, I used my computers power cord instead of the projector but the plug is almost identical. I...
The plugs on this model projector is very delicate, over time the solder around the plug will begin to crack. Until eventually the connection is lost. Another possibility is that the power supply has gone bad. Using another cord would not cause this. I can fix the projector if you'd like. My ebay screenname is gtitubro.
May 11, 2010 | InFocus LP 250 Multimedia Projector
My xg-e650ub also shut down while in use, and won't power up.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Jul 24, 2009 | Sharp PROJECTOR LAMP, Projector Lamp FOR...
PLC-XW55 KEY LOCK FEATURE
Hi
If you accidentally lock the projector, you need to disconnect the AC power cord. Then HOLD the SELECT button at the same time as reconnecting the AC power cord again.
This should reset the lock out.
Dec 24, 2007 | Sanyo PLC-XU47 Multimedia Projector
Projector will not power on
Check your cooling solution wether its a fan malfunction or if it needs a new fan - or h20 cooling system
if not its either the power supply or something serious - send it to manifacture or go to a in-store repair
(it could be the dust protector)
Nov 16, 2007 | InFocus ScreenPlay 4805 Multimedia...
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
