Question about Car Audio & Video
Autotek sx2150 keeps going into protect mode
Will work for a short time and then will go into protect mode.
    Novelist:
  • 111 Answers
Check to see if all the speaker connections are in polarity ( all + to + connections and all - to - connections in their corresponding places)
also you could check to see if the speaker cables are not exposed and touching any metal surface from the amplifier to the point of where the speakers are installed, any contact would cause a short and force the amp into protect mode.
hope this helps, need any more help let me know
........andy........
Posted on Jan 05, 2014
3 Suggested Answers
  • 63 Answers
SOURCE: KEEPS GOING INTO PROTECTION MODE
make sure that your running heavy enough gauge wire from the battery to the amp. make sure wires to bridge the amp is correct and the av wires from the deck are the right gauge should be like 8 gauge wires.
Posted on Mar 23, 2009
ginko
  • 19396 Answers
SOURCE: Autotek XS-900.4 stuck in protect mode
Hi.
The amp does not go on protection only because of wiring or power source problem , but also and mainly when there is an internal fault.
Protection is started whenever an out-of range voltage value is detected from the controller circuit.
Protection can be triggered from a burnt final IC or from a speaker wiring problem.
Since you have ruled out speake, wiring and power source problems, then this Amp is probably defective
If the Amp works fine on a different vehicle, then protection mode may start either because speakers impedance is not within Amp specs, or because the amp has a too big power draw. In this last case the problem is fixed installing a capacitor on the Amp 12V line.
Regards.
Ginko.
Posted on Jun 06, 2010
Sony home theater system
Hello
There is some short inside the internal circuit board. Normally, this short will occur to its audio output section. If any audio output IC get shorted, the set will switch to protect mode. If this mode should chage to normal, you have to find out the damaged component, and should replace them with same type and number. OK.
Dec 23, 2011 | Sony Audio Players & Recorders
Amp goes to protection mode. if the fuse is too small?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. . Double check all connections. Good luck.
A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Jul 15, 2010 | Autotek MM125.2 Car Amp
Hi.
Regards.
Ginko.
Jun 06, 2010 | Autotek XS-900.4 Car Audio Amplifier
STEREO SHUTS OFF BY IT SELF. IT IS AUTOTEK MM1400.1D what size fuse shoud be in it?it has two 40s in it now.
sounds like the protection circut of amp. check for solid ground and continous power from battery. Doed it get very hot?
Sep 17, 2009 | Autotek Car Audio & Video
Autotek mm4000.1 locked it protect
try disconnecting the power and ground wait 30 mins then hook back up
Apr 12, 2009 | Car Audio & Video
Mar 23, 2009 | Car Audio & Video
Keeps going to protection mode
My ? was answererd
im going to hook up a thicker ground wire and ground it to a better place.
my positive wire is as big as i could get and my RCA cables are the good ones
this is a great place yo get information. Thanks.
Mar 23, 2009 | Pioneer DEH-P3700MP CD Player
Aplifier gettieng protection signal and excess heat
for that amplifier, it is recommended that you are driving a 4 ohm load. It can drive a 2 ohm load, but will produce more heat and shorten the life of the amplifier. Is the subwoofer a single or dual voice coil? You'll want to make sure that you're not running below a 2 ohm load or you'll always go into protection. Also, try disconnecting the speaker wire completely from the amp so nothing but power is connected. If the amplifier is still in protection mode when no speakers are hooked up, then the amp is bad and will need repair or replacement.
Sep 28, 2008 | Autotek Car Audio & Video
Amplifer
recheck your ground make sure it has a good connection most of the time this is what it is
Feb 11, 2008 | Autotek SS290.2 Car Audio Amplifier
Amp in protect mode
Most time they go to protect there is something shorted in power supply. And at times it could be a bad amplifier transistor.
Dec 17, 2007 | Audio Players & Recorders
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
