Question about Northwestern Bell 35807-4 Cordless Phone
Bell TE-2008/166 has a flashing green light
Flashing green light on base and flashing phone symbol on handset. Should not flash. Thanks
HOW DO I SHUT OFF THE SILENT MODE THAT IS SHOWING ON
is that "mute" symbol on the base or handset? i have a panasonic dect 6.0 you just have to press off/flash on the handset or the sp phone switch on the base set.
Nov 25, 2014 | Uniden DECT 6.0 Cordless Phone ID
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
Flashing green light on base unit BT Studio 3500
The flashing green light is the in use indicator on the base. Click the scroll button down on the handset to show the call list, then press the x or secrecy button, then press the tick or menu but to confirm, the call list is now empty and the green light has stopped flashing, You need to repeat this for each handset until complete
Oct 11, 2009 | Dual Lands Phones
How can I register my GE 27911 handset?
I also had this problem and then I found a solution from another site.
Just open the handset and remove the battery for about 1 minute.
Reinstall the battery and go through the register procedure again - it will register almost immediately. just keep the handset near the base.
Jul 18, 2009 | Uniden Cordless Phone
Plantronics CS55 requires lifting handset on phone
Please note that your hand receiver has to be off the hook when using the headset.
This is correct, additionally you can use a handset lifter accessory, such as the HL1 or HL10.
Subscribing Headset to Base:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
May 28, 2009 | Plantronics CS55 Wireless Headset
GREEN LIGHT ON BASE UNIT WON'T STOP FLASHING.
check the dial tone is not set to pulse also delete any messages from bt 1571 and the light will stop flashing
May 11, 2009 | Lands Phones
BT Studio 3100 handset 1. Display flashing base 1, cannot go to setup menu, not changed pin code, turned off and on, removed batteries, turned off base unit, waited 20-30secs for all of above and still...
Help
My Bt Studio 3100 cordless telephone ( 2 Pack ). I have carried out the setting up procedures as per instructions.
Handset batteries are fully charged, but I am not getting the dialling tone.
Jul 11, 2008 | Lands Phones
BT Studio 1000 4 handsets
To Mrs Sue Groom,
You probably need to register the handsets to the base.This is the user manual for the BT Studio 1500
http://www.shop.bt.com/content/uni2/documentation/43py/023626.pdf
Mar 21, 2008 | Xact Communication XG2200 Cordless Phone
Main handset won't work; additional handsets do.
Check that you have the larger power adaptor connected to the base unit.
May 16, 2007 | Doro 530 Twin Cordless Phone
Open Questions:
Northwestern Bell 35807-4 Cordless Phone Logo
48 people viewed this question
Top Northwestern Bell Lands Phones Experts
Computer Repairing
Computer Repairing
Andrew Taylor
Andrew Taylor
Are you a Northwestern Bell Lands Phone Expert? Answer questions, earn points and help others
