Question about Sanyo EM-Z2100GS Microwave Oven
Cannot set the clock - Sanyo EM-Z2100GS Microwave Oven
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
How might I set the clock on toshiba er7900
There are different patterns to setting a microwave clokc, depnding on the brand
and age.
Try these combinations (both with the door open and with door closed) to set the
clock to 1:00:
Clock > 1 > 0 > 0 > Start
Clock > 1 > 0 > 0 > Clock
Clock > Clear > 1 > 0 > 0 > Start
Clear > Clock > 1 > 0 > 0 > Start
Apr 27, 2013 | Microwave Ovens
How do I set the clock
Generally you press clock, type in the time and then press clock again. Galanz have a website where you can download user manual.
Mar 27, 2013 | Microwave Ovens
I cannot get the clock-setting procedure to work......
To set the clock to 4:30, for example:
CLOCK > 4 > 3 > 0 > CLOCK
- or -
CLOCK > 2 > 4 > 3 > 0 > CLOCK
(the two means you're setting the clock, as opposed to 1, which would be to set the timer)
Jun 06, 2011 | Sharp R-1480 Microwave Oven
How to set the clock
ot sure which microwave you have but usually this is how to set the clock on most that I am familiar with....
Press on the clock button area, now press on the time you want i.e. 130, then press the clock button area again...This sets the clock
Apr 06, 2011 | Microwave Ovens
Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
The colon symbol (:) will flash.
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
Cant set the clock
hi
In most brandsof microwave oven, you set the clock by one of these combinations of key presses:
Clock > time digits > Clock
Clock > Clear > time digits > Clock
Clock > time digits > Start
If that doesn't work, please reply back with your brand and full model number.
All the best and do rate this answer if u r satisfied.
thankyou
May 10, 2009 | Microwave Ovens
Setting clock
In most brands, you set the clock by one of these combinations of key presses:
Apr 22, 2008 | Microwave Ovens
Clock Problem
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If you don't have the manual, the usual sequenceof clock setting is one of these:
Clock > digits> Clock
Clock > digits> Start
Clear > Clock > digits> Clock
Clear > Clock > digits> Start
Clock > Clear > digits> Clock
Clock > Clear > digits> Start
Otherwise, it may be hard to help beyond this, since it;s been a long time since Toshiba made microwaves.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 17, 2008 | Microwave Ovens
Sanyo EM-Z2100GS Microwave Oven Logo
15 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
tony denham
Level 1 Expert
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
