Question about EverFocus EDSR1600/500
How do I copy something from the hard drive onto a DVD?
The unit is being used to record security cameras. There is some footage I would like to copy, but I don't know how to transfer it to a DVD. I have a DVD player, but I don't have it connected to the DVR. I don't have a DVD drive on my computer either. I don't know how to get the data that I want out of the DVR and onto something else so I can save it before it gets recorded over.
  • 975 Answers
WELL , check out this DVD Recorder from SONY , CLICK ON THIS LINK:
http://reviews.cnet.com/dvd-drives/sony-dvdirect-mc5-multi/4505-3212_7-32565017.html , I THINK you can get a good price by going to EBAY , hope this helps , please rate thanks AJ
Posted on May 20, 2009
DVD burning problems
try sothink dvd moviemaker software or dvdvideosoft software from www.cnet.com/download.....most dvd recorders will burn (check your manual for the correct type (+ / -) and brand that works best)...but wont let you play on other machines unless you format and the other machine is just as new as the recorder...(our older dvd players will not play these new dvd)
Jun 08, 2010 | LG RC389H DVD/VHS Recorder
Hitachi dz mv230a DVD CAM - can't copy video to computer (WXP Pro)
Make sure its pluged in to a powersource and try again, you should see the camera in my computer.
There might be fault in the camera.
May 18, 2008 | Hitachi DZ-MV230A DVD Camcorder
Hi am wanting to put some footage from panasonic sdr h40 onto computer
Your Panasonic camera has a USB port on it as associated by the accompanying cable that plugs into it and has a USB end on the other cable. Note that if your videos are on the SD card, you can take it out and put in your computer via a SD adaptor to USB. The hard drive files though are a little more tricky... you have to have the camera being fed by the AC adaptor instead of the battery.. (it looks like the battery and plugs into its hole on the bottom with a cable hangiong out that plugs into the battery charger.. You will not be able to transfer the files unless you have this power configuration.. this is to keep the transfer from being disrupted by running out of battery power. The files are MOD files which are MPEG2 files just renemed. You can rename them to MPG instead of MOD once you copy to the computer. The USB connection forces the PC to make a drive letter for the hard drive in the camera. I hope that helps out
Than ks!
STan Skaggs
Oct 29, 2009 | Panasonic SDR-H40 HDD Camcorder
Problems with a dv3 16000 Nuvico digital recorder
did u try using a cd cleaner the dvr only accepts cdr not dvd try using the usb port with a thumb drive to see what happens
Jul 05, 2009 | Nuvico NVDV3-16000N
Can i put camcorder footage onto dvd recorder
You can do this digitally on a computer using Adobe Premiere Elements.
http://www.adobe.com/products/premiereel/
Jun 22, 2009 | Goodmans DVD3000 DVD Player
Cant download to dvd
Hope the following helps. I had the same problem and then a friend recommended that when you plug in the camcorder into your PC, press the "DVD copy" button on the unit and also when it comes up on your view finder. The video cam suite program automtaically comes up on PC screen and you can then proceed. My problem know is that I also used the cam corder to record video footage on an SD card but the software only allows copying of the motion videos stored on the hard drive. Does anybody have any suggestions how I can get around this without having to pay $60 per hour of footage for the professional camera places to do it?
Jun 05, 2009 | Panasonic SDR-H40 HDD Camcorder
Does not read disk
2x dvd will work since it records at 2x speed
Aug 12, 2008 | JVC Everio Share Station DVD Burner Burner
After copying some home
best bet get video on hard drive computer 1st then use nero make your movie and then burn no faste rthen 8x
Mar 13, 2008 | Televison & Video
Filesize query
It's probably not out of line. A one hour minDV holds about 13.5 gigs. AVI files need a LOT of space. Yes, it will be compressed before it goes to DVD, but compression (also called rendering) usually isn't done during the capture process. How much hard drive space do you have? You probably need more.
Sep 14, 2005 | Sony Handycam DCR-HC20 Mini DV Digital...
Televison & Video Logo
291 people viewed this question
Top EverFocus Televison & Video Experts
Are you an EverFocus Televison and Video Expert? Answer questions, earn points and help others
