Question about Whirlpool Washing Machines
Control locked on whirlpool duet washing machine wfw70hebw
How to unlock machine
SOURCE: whirlpool duet washing machine ghw9100lw1
To turn off "Control lock" : press and hold the "End of cycle signal" button for three seconds.
Posted on Feb 23, 2008
bemoreonline
  • 4 Answers
The Duet washer is a good machine, just unfortunate Whirlpool engineers used oxidative circuit board coatings. All the circuit board connections are oxidizing causing the machines to have faulty connections. We have fixed the problem using this information.
UNPLUG the machine first . Take the top off (3 screws in the back) , remove the mother board box from the frame housing and remove the lid. Now you can see the circuit board.
Carefully remove ONLY one (clip plug-in) at a time. Scrap with a (knife or sandpaper or steel wool ) the edge connector where that plug was, on the circuit board removing the oxidated metal (it may not look oxidated but must be cleaned), Next put ( vaseline or mineral oil) on the edge connector where that plug was, NOTE: Vaseline or mineral oil is a non-conductive oil and will not effect electronic operation but will prevent further oxidation and the erratic operation of the mother board will cease.
Now do the next plug and repeat until completed.
NOTE: We recommend only one plug at a time so you do not get confused where each plug belongs.
Put the cover back on the mother board box and reattach to the frame, then put the lid back on and screw it down. End of any problems.
Posted on Nov 11, 2008
SOURCE: unlock control lock in washing machine, whirlpool, duet
Hold control lock for 3 sec. It will make a sound and the door will unlock.
Posted on Mar 21, 2009
  • 1294 Answers
SOURCE: control lock is on
Right of control panel "end of cycle", keep pressed for 3 seconds.
Posted on Apr 11, 2009
  • 54 Answers
SOURCE: Control Locked light is on. How do you clear the problem?
if it is stuck on, like the power went out and when it was restored mine did this once, pull the power cord from the wall and count to 10 then plug it back in and see if that works.
Posted on Jun 04, 2009
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
How do I unlock the control panel?
here you go
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. This unlocks the control panel so that the washer is ready for use.
Read more : http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html How to Unlock the Control on Whirlpool Duet eHow
Sep 29, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
I have a whirlpool duet model wfw70hebw. The washer stopped and I can't unlock the door. Have error code E1 F9
Try unplugging for 30 seconds and plug back in. See if you are able to reset the controls after that.
Jan 24, 2015 | Whirlpool Washing Machines
WFW70HEBW does not power
hello guys, i have the whirlpool duet white front loader and its a 120v/60hz and its not powering up when plug in. my supply system is 110v/50hz. how do i convert it to operate on the 110v/50hz?
May 15, 2014 | Whirlpool Duet White Front Load Washer -...
Unlock control lock in washing machine, whirlpool, duet
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal De
