Question about Kettler Exercise & Fitness
E11 error code - Kettler Exercise & Fitness
M frigidaire washer model gltf2940fs1 shows me a e11 code
Thanks for your post, friend!
From my understanding your Frigidaire frontload washer, GLTF2940FS1, is displaying an "E11" error code. Typically, "E11" stands for fill time too long which means you could have an issue within your pressure sensor or control board. I would recommend a reset on your washer and that can be done by flipping the household circuit breaker off for ten minutes. If that does not help correct the issue you may want to consult with a technician for proper diagnosis. I hope this is helpful. -Matt
Oct 15, 2014 | Frigidaire GLTF2940ES Front Load Washer
Eternal hot water heater error code e11
I cannot find what e11 means but it seems most people have just unplugged it an it came back on. Code goes away.
Mar 29, 2014 | Eternal Hybrid Tankless Hot Water Heater...
I installed a new control panel in my Frigidaire dryer and it displays E11. Is there anything I can do to clear this code?
Hi Steve, thank you for your question!
Generally, error code E11 means that it has detected an internal checksum error or processor error. First check to see if it is a false error code by resetting the power to your dryer by either unplugging it or flipping the household circuit breaker for about 30 seconds. If the error code persists, your dryer may have a faulty main control board. Regrettably, this is not a simple DIY job. It is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Best of luck!
Feb 02, 2014 | Frigidaire Dryers
I have a Frigidaire affinity washer error code reads E11. Unit immediately pauses after activating start. Troubleshooting door ssitch revealed resistance was 1320 ohms. I was told 1500 ohms should be...
Good Morning Neil, thank you for your post!
Typically, error code E11 indicates that the water fill time is too long. This could be due to a faulty valve, clogged valve filters, kinked inlet hoses, or low water pressure supplied to unit. Also, if the drain hose is installed too deep into the house drain pipe the water may syphon as it fills. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Oct 05, 2013 | Frigidaire GLTF2940ES Front Load Washer
E11 code on the dispay
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Oct 20, 2012 | Washing Machines
My oven is beeping on an E11 error code on my electrolux range. How do I stop this?
E11 indicates a communication error where a technician needs to diagnose the control board.
Jul 23, 2012 | Electrolux EW30ES65GS 30" Slide-in...
Error code e11
if its a frigidaire front load washer then code e11 indicates thats its a slow fill water problem,remove your hot and cold inlet water hoses and check the hose screens for blockage
May 31, 2012 | Washing Machines
E11 error code fios motorola box
Eb 11 - Invalid unit address / Resettable only at factory / Replace the DCT
Here's a site with a list of fault codes:
How to use Motorola DVR Boot Error Codes
Mar 31, 2012 | Motorola Televison & Video
Error code E11 on hoover washer dryer vhw854d
Nov 12, 2010 | Hoover Washing Machines
Exercise & Fitness Logo
Top Kettler Exercise & Fitness Experts
ray gallant
Steven Brandon
Steven Brandon
todd
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
