Question about GE Ovens
Thermal fuse location - GE Ovens
Whirlpool model YGFE461LBQ1. When I press bake, or convection it says service not available
Hello. There is a thermal fuse located at the rear of the oven, underneath the rear cover. The part number for it is 3196548. If the bake element isn't working, this thermal fuse may have opened. Did you self-clean the oven recently? That is a notorious cause of popped thermal fuses due to lack of adequate ventilation. I hope this helps you!
Aug 26, 2015 | Whirlpool Ovens
Where is the thermal fuse located and how do I replace it on Whirlpool double oven GBD307PRS03? Thanks
The thermal fuse is located on the back of the upper oven to get to it to replace it the oven would need to be removed from the cabinet and the back panel removed ( not fun but what must be done) here is a image of what the thermal fuse looks like.
GENE
Oct 15, 2011 | Whirlpool GBD307PDS Electric Double Oven
Location of thermal fuse in leisure cookmaster range cooker
where is the thermal fuse located in a leisure cooker
Jul 22, 2010 | Ovens
Oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where...
oven will not heat up. microwave works fine. all oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where is it located
Jul 19, 2010 | GE JKP86 Electric Double Oven
Well, it won't come on.
1st check you breaker. If the oven is getting power then it's most likely to be one or more of the thermal fuses. There is one thermal fuse that feeds the control board. It's located in the wiring harness and accessible from the front. The other fuses are chassis mounted on the back or top so the oven has to come out of the wall.
Jun 26, 2010 | Whirlpool RBD305PD Electric Double Oven
How to open door on kitchenaid oven after cleaning cycle is over the there is no power?
do you mean no power to the unit or no display?
if no power, then reset your house breaker and then push the cancel button. it should unlock.
if you have a good breaker, then the unit most likely has a failed thermal fuse. this happens alot on these.
there is a thermal fuse on the back of the unit that will cause the unit to not heat, and another thermal link in the wiring harness at the control board. if this one is bad, then you wont get any display.
you can get the door open by taking a bent wire coat hanger and locate the latch between the doors and pull it sideways to free the latch. then you can remove the control panel and get to the thermal link.
Jan 10, 2010 | Ovens
KEBS 278 DWH6 After self cleanng (Top oven) everything shut down. There is still power to the ovens and I have shut off breaker for a long time to see if computer reset. I read that the problem might be...
The thermal fuse is in back of the oven. This is a design flaw of the oven KitchenAid won't admit. Everytime you use the self clean feature this will happen.
The oven has to be taken out to reach the fuse in the back and replaced. The fuse costs about $40+, but the labor will probably run around $300+ unless you feel confortable doing this yourself.
I am about to replace mine for the 2nd time, good luck!
Jun 13, 2009 | KitchenAid Architect® KEBS277S Electric...
How do I get into the fuse to change it on my whirlpool GBD307 PDQ7 oven? Where is it located?
There are different fuses, a fuse is located on control assembly board, a thermal fuse is accessible removing a panel at the back of the oven, or inside the oven.
Enter here to find assembly diagrams and parts for your model.
Contact the seller by phone if part is not listed on the website.
Jan 02, 2009 | Whirlpool GBD307PDS Electric Double Oven
The Oven won't heat up
the thermal cut off located on the back of the oven has probably tripped,common problem. replace thermal cut off.
Dec 19, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool Oven Control Panel Thermal Fuse
If the display is totally out it is likely the thermal fuse this is located where the wire connectors plug into the board it looks like a small resistor in a platic shrinkwrap type sleeve. test it with a continuity meter.
Oct 25, 2008 | Ovens
Ovens Logo
111 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
