Question about Singer Sewing Machines
Singer golden touch and sew model 630
Thread gets caught in self wind plastic bobbin and pulls bobbin up from shaft
    Novelist:
  • 268 Answers
This series of machines was nicknamed "touch and swear" and "sew and throw", as well as other, less polite, names, because the bobbin winding system is so touchy. Try a couple of new bobbins, and if that doesn't work, consult the nice folks at the yahoo group "wefixit": https://groups.yahoo.com/neo/groups/wefixit/info Most of the time, though, a new bobbin fixes this particular issue.
Posted on May 25, 2014
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Posted on Dec 23, 2007
SOURCE: Singer 6267 self winding bobbin winds around shaft under
I just figured out why my bobbine was winding on shaft instead of on the bobbin. first of all make sure the bobbin is setting up high enough, top of bobbin needs to be a fraction higher then the bobbin shuttle, next check to make sure there are no burrs on the bobbin, then make sure that the thear is catching in the groove (**** in top) of the bobbin. In order to get mine to wind i had to lett the tread go down and then slip the thread in the groove. also remember to leave the pressure foot up do not put it down. let me know if this helps.
Posted on Mar 08, 2009
  • 1116 Answers
SOURCE: I have a Singer Touch N Sew Model 636. The
I had a Golden Touch 'N Sew many years ago and as the machine aged and parts became worn, step 4 of this bobbin winding diagram started to become a problem and I had to sometimes try several times before the "tabs" would release. If they did not release, the machine "thought" it was still winding the bobbin and would not sew.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_2001_touch_tronic_threading_diagram.htm
Posted on Mar 06, 2010
  • 139 Answers
SOURCE: Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Posted on Apr 16, 2010
SOURCE: how to thread the bobbin on a singer touch and sew model # 625
how to wind the bobbin of the singer touch and sew model 625
Posted on Jul 26, 2011
My thread is getting caught under the plate by the bobbin casing when I'm trying to make a buttonhole. Also my fabric is a little thick and my feed dogs will not pull the fabric through, so then I have a...
If you have an a self wind bobbin make sure the bobbin winder is all the way down and no thread caught under it, your machine should be able to cope with thick fabric, slacken the pressure on the presser foot
Oct 03, 2013 | Singer Touch Sew 7462 Mechanical Sewing...
Singer Golden Touch N.Sew 630
it sounds like the machine may need to be serviced
Dec 21, 2012 | Singer 7430.CL Computerized Sewing Machine
How to wind the bobbin on the singer creative touch 1030
on touch and sew models thread the machine up as normal, select straight stitch, presser foot up, take the thread from the needle and wind it round the presser foot screw a few times, open the slide plate, push the little button over, press gently on the foot control to wind the bobbin, when finished close the slide plate to drop the winder down and pull the threads to the back and start sewing
Sep 04, 2011 | Singer Sewing Machines
Mar 06, 2010 | Singer Sewing Machines
Jun 21, 2009 | Singer 7442 Mechanical Sewing Machine
How to thread the bobbin on a singer touch and sew model # 625
Jun 13, 2009 | Singer Sewing Machines
Thread jamming at bobbin
Check to be sure the thread is not catching on the bottom of the bobbin. If it is, replace the bobbin because it is sprung. If it is not catching there, then you need to check your tension to see that it is working properly. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}. Pull the thread through the tension assemblyand test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 orsomething in the middle. Raise the presser foot and pull the thread through thetension. It should pull easily!! Lower the presser foot and pull the thread. Itshould pull noticeably harder.) If it doesn't do this, you need to remove the thread or lint that is stuck between the tension discs. Open them with a small screwdriver and clean them out.
If this doesn't solve your problem, remove the bobbin case and check the hook for rough spots.. If you find some, buff with an emery stick until smooth.
sewman7
Oct 03, 2008 | Singer 7462 Mechanical Sewing Machine
Bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Aug 17, 2008 | Sewing Machines
Sewing Machines Logo
134 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
