Question about Lexus rx350 flasher assembly, hazard warning signal; relay; relay
Lex 350 electric power steering system - Lexus rx350 flasher assembly, hazard warning signal; relay; relay
Have 2008 chevy Malibu Ltz.past few days the dash will say "power steering "of course wheel gets tight. it's electric..not sure if the pump is going out or if it's the lines..how can someone tell?
The system can be scanned for faults, in the is case you need that test performed. The pump only runs when the computer control unit commands it to run it is on demand, this information comes from sensors in the system..
Dec 11, 2016 | Cars & Trucks
2010 ford fusion hyprid power steering went out
Power Steering - Hybrid The electric power assist steering system consists of:
  • power steering control module
  • electric motor
  • torque sensor
  • rack-and-pinion steering gear
The electric power steering system provides power steering assist to the driver by replacing the conventional hydraulic valve system with an electric motor coupled to the steering gear. The motor is controlled by an electronic control unit that senses the steering effort through the use of a torque sensor mounted between the steering column shaft and the steering gear. Steering assist is provided in proportion to the steering input effort and vehicle speed.
your best bet would be to have the ford dealer check it out !
Dec 02, 2016 | 2010 Ford Fusion Hybrid
My Vauxhall mariva 2011 has loss power in the steering is this a common fault for age of car
It was a common fault on the earlier year cars with the electric power steering system and if you are having the same issue then GM UK still have not fixed the issues in later models. 2011 is not an old car and a vehicle of that age with a typical hydraulic power steering system would not be failing. You will probably find one or more critical sensors in the electric PS system you have has failed and in that event the whole power steering system has shut down. Once the electric motor that provides the steering assistance is shut down you have no power assistance whatsoever.
Vauxhall Meriva power steering
Jun 27, 2016 | Vauxhall Cars & Trucks
Where is the power steering pump located?
ELECTRIC POWER STEERING (EPS)
The TSX uses Electric Power Steering (EPS) which regulates steering via a computer-actuated electric motor. With the computer-controlled system, advanced algorithms built into the operating software allow for continuous fine-tuning of the steering assist forces so that minimal force is required at low speeds- such as when parking or maneuvering. Conversely, progressively higher steering effort is generated at higher speeds (such as when driving on the freeway) to deliver a sport-minded driving experience.
The EPS system found in the TSX is an evolution of an earlier EPS system found on the Acura NSX supercar. Its key features and advantages include:
  • The EPS system reduces the steering effort at low speeds, improving agility and ease of effort when parking or maneuvering in tight areas
  • Rigidity of the steering mount is higher, which allows a more precise and "connected" feel during high-speed maneuvers (such as during lane changes or when on winding mountain roads)
  • The EPS steering assist incorporates computer algorithms based on vehicle speed rather than engine speed, allowing TSX engineers the flexibility of tailoring the steering feel to match actual driving conditions- especially high-speed driving. The EPS steering algorithms incorporate steering assist changes for every 0.6 mph.
  • The EPS system is different (and uniquely tuned) for each of the TSX models: 2.4L I-4 sedan, 3.5L V-6 sedan, and the new Sport Wagon.
  • EPS employs a sporty, 13.5:1 steering ratio which further improves performance driving agility
  • In its evolution from the original NSX system, the TSX's EPS system uses a significantly more powerful electric motor teamed with a far more sophisticated microprocessor
  • By eliminating the conventional power steering pump assembly, EPS uses less engine power which improves acceleration and fuel efficiency
it is an electric pump without a pulley or belt or fluid apparently
Aug 09, 2014 | 2011 Acura TSX
WHAT IS THE AUTO MAKER PREPARIRED TO DO ABOUT POWER STEERING GOING OUT ON THEIR VEHICLES ? NO RESEVOIR FOR POWER STEERING FLUID , WHEN THEIR BOOK SAY THERE IS A PLACE FOR POWER STEERING FLUID !!...
This vehicle could have come with two different types of power steering ! One electric an the other hydraulic needing power steering fluid .
If your vehicle has no power steering fluid reservoir it has electric power steering .
Power Steering System Description and Operation (Electronic Power Steering)
Power Steering System Description and Operation (Hydraulic Power Steering)
An they did have a recall for the electric power steering !
https://www.usatoday.com/story/money/cars/2014/03/31/gm-recall-steering/7127117
May 28, 2017 | 2006 Chevrolet Chevrolet Malibu MAXX LT
I have an 2007 es 350 lex and my VSC, check engine plus track light is on. Its on and off. Not sure what's up. I'm so afraid it could be something big...HELP
Just a guess, but sounds like you are losing a wheel speed sensor. Not sure that will turn on the check engine light, but will cause the other two to come on.
Aug 18, 2011 | 2007 Lexus ES 350
Where is a power steering pump located on a 4 cylinder chevy cobalt ls
Your Cobalt is not equiooed with a Power Steering Pump. It has electric power steering. See the description below.
Power Steering - System Description and Operation
The electric power steering (EPS) system reduces the amount of effort needed to steer the vehicle. The system uses the body control module (BCM), power steering control module (PSCM), torque sensor, discrete battery voltage supply circuit, EPS motor, serial data bus, and the instrument panel cluster (IPC) message center to perform the system functions. The PSCM, torque sensor, not the EPS motor are serviced separately from each other or from the steering column. Any EPS components diagnosed to be malfunctioning requires replacement of the steering column assembly, also known as the EPS assembly.
Nov 20, 2009 | 2005 Chevrolet Cobalt
Where is a power steering pump located on a 4 cylinder in a 2005
Your Cobalt is not equipped with a Power Steering Pump. It is equipped with electric power steering. See the description below.
Remove the pulley of a power steering pump from 1990 gmc 350
Autozone rents the specialized puller for free, there is a special puller just for power steering pumps.
Nov 08, 2009 | RaidMax 350W Power Supply...
GMC 350 V8 POWER STEERING DIAGRAM
The high pressure and low pressure hoses are different sizes at the gear box. And the low pressure /return hose is usually rubber with a clamp at the back off the pump.
Mar 03, 2009 | 1993 GMC Sierra K1500
Lexus rx350 flasher assembly, hazard warning signal; relay; relay Logo
18 people viewed this question
Top Lexus Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Lexus Retail Supply Expert? Answer questions, earn points and help others
