Cir Fan on 80amp. A/C on 40amp. If 80amp is discon A/c has no fan
I have a Nordyne single unit model # GQ3RD-042K. Circulating fan is on 80amp. breaker. A/C runs on 40amp. breaker. How do I change circulating fan to 40amp breaker. Changing wires, how?
  • Ralph Herring
    Ralph Herring May 11, 2010
    Why do you want to change wire amp ? What do you think changing the amps will do ?
  • 158 Answers
Swap breakers
Posted on May 21, 2009
Nordyne Split System Blower Won't Start
It's the fan motor. A relay problem would cause the motor not to run at all.
May 08, 2017 | Heating & Cooling
I have a refrigerator with 2 seperate doors, the fridge department doesnt make the stuff cool, the freezer hower works, what can the problem be?
It would be very helpful for you to provide a brand for your unit. If this is a Sub-Zero, you likely have a freon leak on one circuit. If it is a single compressor model, you likely have a circulating fan that is stuck or burnt out. A cold freezer is good. The problem is likely very simple. Check the circulating fan.
Jan 31, 2011 | Kitchen Ranges
Outside unit will not power up t3rc model
you will have to check and make sure you have power to your outside unit, see if the contactor is being pulled in, and power to you fan motor.
Jul 21, 2010 | Intertherm P3RC-042K Air Conditioner
Evaporator coil needs to be replace again. Installed w new manufactured home; 09/2005. Replaced 05/30/08. Needs to be replaced again 09/17/09. All due to leaks. Freon was added. Currently has small leak;...
the manufacture is only required to supply the part free of charge thru its warranty period. the installing company probably would only give a 1year labor warranty and honor the pparts thru the manufacture for 5 years but unless you paid additinal for an extended labor warranty i dont think you are going to have much luck. Make sure you change your air filters every 30 days a dirty filter is one of the biggest causes of evap coils prematurely leaking. Sorry wish i could be more help.
Sep 17, 2009 | Intertherm P3RA-042K Air Conditioner
Need wiring diagram to wire a Gibson GB5BM-T42K-B to a NORDYNE JT5BD-042K
you just need to follow the diagram that came with your new unit but its probably the exact same considering nordyne makes gibson andall thier parts are universal
Sep 10, 2009 | Heating & Cooling
Bad sequencer or fan relay?
does ANYTHING come on when set to heat?
Feb 28, 2009 | Heating & Cooling
Goodman pgb 0300751 gas package unit. The unit started running both the combustion and circulating fans. Technicians have put two new honeywell boards in it. the fans are still running. all circuits and...
then you need toi have them check the fan high limit that is mounted in the blower compartment. if it's closed then the blower fan and the conmbustion air fan will run together.
Feb 03, 2009 | Heating & Cooling
Fan relay wireing
It is a peanut style relay with 5 wires. Two which are for a coil, and 1 normally open and one normally closed and one hot. The relay on that model does tell you that.
Oct 18, 2007 | Airtemp B6D30E7A Air Conditioner
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
