Question about Char-Broil Grill 2 Go X200 Gas Grill
My regulator doesnt seem to lock into position,seems very flimsy and as a result has very little or no flame at all
The grill has been used one time without and issues but was never really 100% confident that the regulator was lock into position properly
4 Suggested Answers
  • 57 Answers
SOURCE: Have Q grill Replace tank and regulator. Burner is
open up your air vents on your burners that should get a higher flame
Posted on Aug 27, 2009
  • 512 Answers
SOURCE: New Charbroil gas regulator leaks
The connector on the grill side that connects to tank may be bad. Call manufacturer and they should send you a new hose and regulator for free since it is a new grill. If grill does the same then replace tank.
Posted on May 03, 2010
Testimonial: "http://www.fixya.com/ThreadAsker.aspx?thid=4631783&msgid=10151276&type=click&mailid=7&rnd=0.200523876678443#"
  • 110 Answers
SOURCE: do you use lava rocks or just use propane flame?
Hello, There should be vaporizer tents over each burner. As a reference you can got to website: http://www.charbroil.com/bps/char-broil/char-broil/knowledge/7001189_463453306_english_37f8ef8b-0_.pdf
and refer to the bottom of page 9 or find your model number and enter it into the search bar at the top right of the Char-Broil website: http://www.charbroil.com/
You can order needed parts from there or from Sears which I have found to be quite competitive on their prices.
If you found this helpful please vote yes. Thank You!!
Posted on May 07, 2011
Burners run cool when set on high, when all but one burner is off, the single burner opporates correctly. Grill worked fine before.
There have been issues lately with the way regulators are not drawing gas out of the cylinders properly, and how some of the newer grills are not heating properly.
The issue with them not heating properly goes back (usually, from just what I have observed) to the position of the gas knobs at the time the cylinder valve is opened. On some grills, if the gas knobs are open when the cylinder valve is opened, the burners will not get the maximum amount of gas to all burners, but the performance of one burner is enhanced if the others are turned off, and this sounds like what's got you.
Turn the gas cylinder valve to the off position, and bleed the gas pressure down at the burners. Close the burner valves. Slowly crack open the tank valve, and work it slowly to full open. With the grill lid open, select and light one burner. If it operates properly, light the other burners. If the first burner does not operate properly, repeat the procedure. If you cannot operate your grill like it is supposed to, the issue may fall to the regulator. If the regulator is an older style, it may not actually be fully compatible with some newer cylinders. This seems to be a newer phenomenon, and seems to be found with the type of cylinders that are swapped for a refill. If this is your case, you will need to upgrade to the newer regulator.
Best regards, --W/D--
Mar 07, 2011 | Viking DVGBQ532-3RTL (LP) All-in-One Grill...
I have had my Charmglow grill for about 4 years and never had a problem with it. However, the other day I started it and came back 10 minutes later it was just at 150 degrees and would not get any...
Sounds like a classic symptom caused by a failing regulator. Replace the regulator, easy to do and not very expensive. Turn off the tank and unscrew the regulator from the tank. Remove the tank and use a 3/4" wrench to remove the hose from the manifold. Do the reverse to install the new regulator. The fitting should be a 3/8" flare, so you do not have to tape it, just snug it on good. Check for leaks using soapy water.
Nov 13, 2010 | Brinkmann Charmglow 810-7400-S Propane...
Flames are very low seems like somethings blocked
There could be a blockage in the valve orifices, but first try replacing your hose and regulator, easy to do and inexpensive.
Jun 29, 2010 | Weber Genesis Silver B Grill
Inadequate flame and heat
I'd change the regulator, clean the burners and the surrounding area. Make sure that the air intakes around the burners aren't blocked , plugged..
Also check the gas orifices for cleanliness... outdoor grilles are nutorious for bug hotels... these little critters move in, lay eggs and it can screw up the burners, orifices... I've several times needed to remove orifices to clean the inside of mini spider nests... Look them over closely..
Jun 01, 2010 | Weber Genesis Silver B Grill
No Gas Getting to Back Burners
sounds like you have debris in the gas regulator,remove the tank and look into hose end to see lf its clear.sometimes just tapping lightly on the reg,will release the debris.u may need to replace hose and regulator to burner assymbly.if this doesnt fix it.
Apr 13, 2010 | Weber Genesis Silver C Grill
Heat is about low or just a little higher on high setting
Low flame, low temperature, yellow flame: This has become the biggest problem with many grills these days and it's almost always because of the regulator (the funny UFO shaped thing on the gas hose). Regulators seem to be stickier these days and when they stick you don't get enough gas to generate a good grilling temperature. To get your regulator unstuck you need to release the pressure on it. Follow these steps exactly:
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
To keep the regulator from sticking again make sure that you turn off the control valves first, then turn off the tank valve. Always open your tank valve slowly. If this doesn't work give it a second try. If you still have low flame then you probably have a faulty regulator that will need to be replaced.
May 24, 2009 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Rangemaster 110 grill flame.
to find out if the regulator is good or bad, turn any of the burners that do not have the problem, one at a time but take a close look at the flame and see if the flame goes lower and lower as you turn a second burner and a third and the fourth one, if the flame goes lower and lower the regulator is bad. but if the problem is with just the grill one , it has to much air, you can turned down the air where the burner meets the valve that supplies gas to it the burner has a vent, it needs to be close a little bit, you can close it little by little and testing the burner on the on position until the splutter goes away.
Dec 11, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Low gas flow - low heat
The only way you can fix the low flame, low heat problem, is to remove the grill, take a medium sized paper-clip (staightened out) and clean out each individual hole on the steel burner, flame tube. (I'm sure there's a technical name for it).
Since they (the holes on the flame tube) face up unprotected, directly under the grill cooking surface they tend to get blocked quickly with continous use and certain foods, like pork ribs. Bad design unless all you plan on grilling is hot dogs.
There are about 500 individual holes, so plan on being there a while. Or in other words, do it close to the cooler.
I've been tempted to toss the thing into the woods a bunch of times over the past 2 years I've owned the dumb thing.
Apr 19, 2008 | Weber Q Grill
Char-Broil Grill 2 Go X200 Gas Grill Logo
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
