Question about Samsung Washing Machines
Can't shut the door the door lock is engauged
Driver door won't lock, interior lights stay on. all lights including dashboard. headlights and taillights also. battery being drained as a result
Light switch has shorted, internally, everything you describe is engauged by that switch, replace the switch. I hope this helps!
Jan 14, 2014 | 2005 Buick Rendezvous
4410 I get 5 blinking lights when I engage 4 wheel drive. 4 wheel not working
ist question is : the handle thats under left side of seat is it ALL the way up , im a big guy and im allways hitting mine with my leg, this is the DIFF lock it won't let you go to 4wd if this is engauged ,after 4wd is engauged by driving forward a feet then it will allow Diff lock
second question is What five lights come on?
Jan 10, 2014 | John Deere Garden
2005 Toyota Tacoma will go in 4 wheel drive high, but just flashes 4-lo when trying to enage in 4-lo.
Flashing means that it did not engauge, you may have to put it in 4 LO and let the truck roll a little to get it to engauge, same with the locking rear diff. These lock via electric motor and you may need to move to get it to mesh.
Dec 28, 2010 | 2007 Toyota Tacoma
Door fuse constantly blinks and dings when running.... do not know where to find fuses.
If you pull that fuse you may loose other features like your electric windows. But if you look under the dash on the driver side then you should see the fuse box. it may have a flap that pulls down and the box is under the flap. if not there then check the glove box. I know it sounds dumb but some models the fuse box is in there. If you were hoping to find a bad fuse for the door problem forget it. The thing is making noise so the power is getting to it. On the inside of the door jam you might look at where the door latches and along that side and the side of the door for a button that engauges when the door is shut and supposedly shuts off the noise. you can oil it and see if the button was stuck or find the wire to that button and disconnect that wire. Best I can do for you from here. If I were your nieghbor I would come right over and fix it for you no charge. Raz
Apr 19, 2010 | 2000 Dodge Neon
Doors will not lock on my 95 model passat. it has cenral locking. (is it possible to disingauge the central locking and just use the key old skool)? the temp here is -10c does that have any thing to do...
sounds like the lock is just sticking open up the drivers door and hose the ****** down with a good degreaser break cleaner is a great friend as it cuts greas like a knife once old dry grease is gone lock should work fine use eithor antiseize or release all to re lube it do not use grease as it will freeze and cause the same problem again if your smart you will place a heater in the car after you remove the door pannel to make it easier to work inside the car
Dec 31, 2009 | 1995 Volkswagen Passat
Craftsman garage door opener does not working.
Press and hold the button on the wall control that has the padlock icon for 3 seconds.
Sep 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
All remotes stopped working on genie opener, hardwired wall switch works fine.
Your lock on the opener is probably engauged. On the wall control there is a button labeled lock. Press and hold this button for three seconds. Your remotes should work now. If they still do not work, you need to reprogram the remotes. Press the learn button on the back of the motor and then press and hold the remote button. The light will blink once. Repeat this step on the other remotes.
Feb 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Intermittent problem w/Sears garage door opener transmitter
If the wall control is flashing, the lock has been engauged. Hold the lock button for 3 seconds to turn off. The light should be solid after doing this.
Feb 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Washing Machines Logo
15 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
