Question about Car Audio & Video
Need wiring diagram for Pioneer AVIC-Z150BH
Need to connect speed pulse wire(s).
  • 108 Answers
SOURCE: avic-n1 wiring diagram
www.pioneerelectronics.com should have listings and manuals for their products in downloadable pdf form. Also, try visiting www.avic411.com for all your Pioneer Avic series navigation needs.
Posted on Aug 10, 2008
SOURCE: NEED WIRING DIAGRAM
hope this helps,......http://www.nodevice.com/user_manual/pioneer/car_multimedia/avh-p5700dvd.html
Posted on Aug 01, 2009
pctech1
  • 1940 Answers
SOURCE: help i need a wiring diagram for a pioneer
ftp://extra.abt.com/PDF_Files/avhp5700dvd_installation.pdf
This is the installation manual for the AVH-P5700DVD, including a wiring diagram for the wiring harness.
http://www.pac-audio.com/PACProductData/TR7/1_Instructions/tr-7_instructions_010505.pdf
This is the wiring diagram for the PAC TR-7 UNIVERSAL TRIGGER OUTPUT MODULE VIDEO BYPASS.
Posted on Jan 12, 2010
  • 57 Answers
SOURCE: I need a wiring Diagram
911manuals.com
Posted on Aug 22, 2010
brianw74
  • 400 Answers
SOURCE: i need the wiring diagram
Pioneers wiring is easy. Red is ignition-Yellow is battery-Black is ground-Blue is remote for amp or antenna-Orange is illumination-Speaker wires are usually grey, grey w/blk stripe-white, white w/white stripe-green, green w/blk stripe-purple, purple w/blk stripe. Green and purple is rear, white and grey is front
Posted on Sep 18, 2010
Installation of navigation/DVD unit in 2003 Chevy 2500
I'll letr you know if there is a user manual available
Jun 13, 2008 | Car Audio & Video
My avic-z150bh equalizers goes in and out
Amplifier Possilbly Getting Weak After Heating Up Causing Unit To Short Itself
Nov 09, 2013 | In-Dash Navigation AVIC-Z150BH
Pink wire whats it for, it on a pioneer avic-d2
The brake sensor wire (Lt Green) can be simulated with a toggle switch to ground.
Pink (CAR SPEED SIGNAL INPUT)
The mobile navigation system is connected here to detect the distance
the vehicle travels. Always connect the vehicle’s speed detection
circuit or the ND-PG1 speed pulse generator, sold separately. Failure
to make this connection will increase errors in the location display.
Orange/white
To lighting switch terminal
Light green
Used to detect the ON/OFF status of the parking brake. This lead
must be connected to the power supply side of the parking brake
switch. If this connection is made incorrectly or omitted, certain
functions of your navigation system will be unusable.
Violet/white
(REVERSEGEAR SIGNAL INPUT)
This is connected so that the navigation system can
detect whether the vehicle is moving forwards or
backwards. Connect the violet/white lead to the
lead whose voltage changes when the shift lever is
put in reverse. Unless connected, the sensor may
not detect your vehicle traveling forward/backward
properly, and thus the position of your vehicle
detected by the sensor may be misaligned from the
actual position.
Note: When you use the ND-PG1 speed pulse
generator (sold separately), please make sure
to connect this lead.
When you use a rear view camera, please make
sure to connect this lead. Otherwise you cannot
switch to rear view camera picture.
Further detail can be found here:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130AVICD2.PDF
Feb 23, 2010 | Pioneer AVIC-D2 DVD Nav/6.5"...
Speed sensor
The VSS or speed sense wire is used for navigation systems. The VSS wire sends a series of pulses (from 800 to just over 1,000 per mile) only when the vehicle is in motion. If the VSS wire is not hooked up, the navigation system will not realize that the car is moving at all, and will be unable to track position. If you need a wire color and location I can provide one for your vehicle. Hope this helps.
Mar 02, 2009 | Pioneer AVIC-D2 DVD Nav/6.5"...
I need the wiring harness for pioneer avic-n2
i need wiring diagrame for pioneer avic n2 cpn1955
Aug 22, 2008 | Televison & Video
Avic-n1 wiring diagram
Aug 03, 2008 | Pioneer AVIC-N1 Car DVD Player
The navigation is off track or something
there should be a vss wire hooked up that helps the unit know where it is.. go to the connection check screen and make sure the speed sense is pulseing
Feb 22, 2008 | Pioneer AVIC-D1 Car Video Player
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
