Question about Refrigerators
Wr55x10025 part install - Refrigerators
  • Refrigerators Master
  • 2,328 Answers
What is the problem you're having?why do you think the sensor is bad?these sensors hardly ever fail unless you have an older g.e. fridge and at the end of the sensor where the wires go into the sensor has a black ring around it,then it has to be changed out,and usually the mother board too,if you look at the mother board you'll see black relays on it,the newer board is i think wr55x10942,if it doesn't have all 7 relays on it most likely this is your problem but check the sensor to above the evap coil,if it has a black ring around it change that out too,if it's all white you can leave it alone,it would be easier if you can send the model number and tell me what's happening to the machine so i'm not just guessing at things,if it's a side by side open the fridge door and look up on the right side wall up near the ceiling and you'll see the model number,also if the freezer is on the bottom it will be in the same place,freezer on top it will be on the left side wall..write back and i'll do my best to help you,if you're in mass, and you need someone to come out let me know.good luck and send the model number and what the problem is.
Posted on Jan 02, 2014
How do you change part # wr55x10025
This is a thermistor. It depends where it is located how you would be changing it but the generic answer would be unplug the refrigerator. remove the old one leaving some of the leads from the old one before you cut the wires. so you have some wire to work with. Using small wire nuts or crimp connectors wire the new thermistor to the old leads from the old thermistor it is best to either fill the wire connectors or crimp connectores wirh silicone sealant or tape the connectors with electrical tape to prevent water from entering the connections. Put the thermistor into position and away you go.
Apr 01, 2014 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Refigerator and freezer all of the sudden don't seem to keep cold enough
The back wall of your freezer covered with snow? If it is I would suggest you replace the heater and a thermistor - Heater: WR51X10101 Thermistor: WR55X10025. If no snow then it is probably the main pcb: WR55X10656
Mar 24, 2013 | GE GSH22JFT Side by Side Refrigerator
HOTPOINT FRIG GEHSM25GFRESA THERMOSTATS WERE ON 5 NOW ON 1 TO KEEP UNIT FROM GETTING TO COLD
Either your auto damper has frost blocking it open or the=> WR55X10025 Thermister is defective.
Try using a hair drier to force warm air into the damper to see if the damper will close better by melting any ice that may have the damper stuck open.Here is the=> WR09X10050 Damper Thermister Assembly Instructions on how to change this part can also be found on the same page HERE If you have any questions please ask, Thanks Sea Breeze
WR09X10050 Damper Thermister Assembly Below
Jul 11, 2012 | Hotpoint HSS25GFP Side by Side...
Coils frzg up in freezer section refrig side to warm. changed terminator and heater.i have a ge sxs gss22wgmd.
well i wonder if you have changed both the white sensor part number WR55X10025. This is the sensor that tells the mother board to go into defrost. The other terminator is only a backup safety stat. If this dont solve your defrost problem. Then change the motherboard.
Aug 17, 2011 | Refrigerators
Coils in freezer section are a solid block of ice. Cleaned and melted ice but just happened again a month later. defrost cycle malfunction?
Yes. The most likely cause is a burnt out defrost heater (WR51X10101), located at the bottom of the cooling coils. The replacement heater may look different, but instruction included with heater cover that. I would suggest replacing the defrost thermister (WR55X10025) at the same time, located at the top of the cooling coils.
Apr 19, 2011 | GE GSS22SGM Side by Side Refrigerator
Refrigerator won't cool and freezer has ice build up on back.
its a defrst problem most likely the defrost thermister wr55x10025
Jun 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
How to install the sensor part number WR55X10025
To install remove the panel protecting evaporator, cut the 2 wires to the old sensor, crimp the 2 new wires on and snap the new sensor to the clip on the evaporator.
Apr 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrgerator side gets to cold
Possible bad thermister or temp sensor. Part # wr55x10025. Your unit is a dual evaporator system. So fresh food side is independent from freezer. That would be the most likely cause. It retails for $14.00 from ge parts online. Good luck.
Aug 11, 2008 | GE Profile PSW26P Stainless Steel Side by...
Freezer on GE model 25 GSS25SGMDBS not working
change sensor temp- part number WR55X10025. You can get from searpartdirect. approximate$7.00
Jul 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
