Question about Garden
Chainsaw hard to start. When it does start and I turn it off I cannot start it again.
    Scholar:
  • 102 Answers
I experienced the same problem with mine. The collar ring split making the pole saw useless. I am one of those who can basically fix anything you can put into my hands......
I have the solution for you! Loosen the collar ring and ensure the matching edges (where it is split) are clean & dry.....(no oil or residue).
Use JB-Weld (available in most department stores, hardware stores and auto suuplies) to repair the collar ring. Use the standard type epoxy (not the fast drying type). You will also need one other item to keep the ring from splitting again. The collar ring has a 2-inch diameter. Go to a hardware store or an auto supply store and ask for a 2-1/2 inch stainless worm clamp. Be sure to get the wider type that is about one-half inch across the stainless band. The clamp is typically used to connect radiator hoses on automotive engines. Make sure the clamp you get is stainless. Unscrew the clamp using safety in mind.....they typically have a large "straight slot" screw; using a screwdriver is a bit dangerous especially if you have to tighten it very tight. If you have access to a nut driver or a small quality socket set, these tools will enable you to tighten the worm clamp very tight. Do not force the collar ring back into service for a few days to ensure that the epoxy has had plenty of time to cure. I repaired mine a few years ago and it still works great!
Please send me a reply once the surgery and recovery is complete.
The total cost for materials is about $9-$10.
I hope this fixes your collar ring for good!
Posted on Jan 02, 2014
Won't start very well only runs when using won't idle always dies then hard to start again
no offence thats a made in china saw poulans are but it might just need carburator cleaned and new filters and plug wouldnt hurt to check the clutch springs either there bad to break
Aug 04, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Husqvara 345 chainsaw hard to start
try running it with out the muffler if ok without the muffler open it and clean the internal screen
Sep 15, 2012 | Husqvarna Garden
I have a Poulan Pro 42CC 2 Cycle Chainsaw, 18" It is about 4 months old it will run but the gear that drives the chain is not moving at all when it runs. I can turn it by hand but it is very hard...
It sounds very much like the chainbrake has activated, grab the hang guard and pull it firmly back to the top hadle, it should click when it has loaded, now try again.
Aug 16, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My saw starts up but dies pump bulb and it starts again then dies again, already replaced diaphram and fuel lines,
The carburator likely needs to be cleaned. Did the old fuel line fall apart it disolved and coated the neddle valve inside the carb and its stuck closed there for on fuel can get to the combustion chamber unless you pump the primer button. this a comon problemyou just need to take the carb apart and clean it look at when you disassemble it and note where the parts go its not that hard to do and you don't need a lot of tools
Dec 14, 2010 | Poulan 18" Wild Thing Chainsaw
Hard starting on a Makita line trimmer? How do I solve this issue?
Try pushing the primer 8-10 times hold the throttle wide open and turn choke too full.when it starts it will probably quit turn choke to halfway and start again.should stay running.If that don,t work carb needs to be rebuilt or replaced.
Nov 29, 2010 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
Need intructions on carberator adjustments for mac-3514 35cc/cm3 runs but hard to start after using it for few minutes.
There is a low speed jet and high speed. Low speed sets the idle or stays running without feathering the throttle./// When setting high speed, hold the throttle wide open until engine revs high, then turn back in(at least ¼ turn) to slow the engine which in turn gives the engine more gas and runs cooler. If you have it too lean on the high speed, it will be hot and hard to start. Sometimes using 40 to 1 mix helps with starting, especially on older chainsaw. good luck
Sep 22, 2010 | McCulloch Garden
Chainsaw starts and runs fine for a few minutes
Try fresh fuel making sure oil and gas mixture is correct. Carb might need cleaning and adjustment.
Jul 26, 2009 | Garden
Bent connecting rod
Ive had blower with bent cranks due to blower scroll comming off and the engine over reved
Jan 18, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
481 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
