Question about Amana ABB1927DE Bottom Freezer Refrigerator
Bottom freezer not working. Frige OK
Refrigerator works ,bottom freezer doesn't. I would like to know what to look for to troubleshoot it. Unfortunately it's in a boat house at the bottom of 120 steps.Don't have the brand or model till I see it but would like to minimize the # trips up the steps. Any help appreciated. Thanks, UPat
I have a Kenmore refrigerator 795690002900 bottom freezer. The freezer is working but the fridge doesn`t work. The temp adjustment for freezer lits up the 6 and 7 will not adjust, the fridge part does not...
Mine bottom freezer 10 or so year old unit did the same thing, problem was the thermal switch ("clicks on") on de-ice circuit was broken. Quick "fix" is to defrost the unit by shutting it off, putting frozen food in a cooler. Once the ice melts the path for blowing cold air UP to the frige will be opened. Will work fine for days until the freezer ices up again.
Most likely the "clicks on" or thermal swithch that is bad and will not let the defroster heater work. Easy fix. Everything is BEHIND the pull out frozen food tray. Remove a couple of screws and you will see all the ice. If I remember correctly my clicks on was just to the right of center and took only 5 minutes to replace after defrosting the unit.
Hope this helped,
Ken C
Apr 30, 2012 | Kenmore 71279 Bottom Freezer Refrigerator
My amana frige leaks at the bottom, it is a bottom freezer frige, I moved it lately because I am laying laminate floor, any solutions?
In your shuffling of the refrigerator you may have knocked the condensate drain away from the pain near the compressor that evaporates the water back into the air inside your home. Or you may have the refrigerator leaning in a way that the water pools up near the condensate drain pipe beginning in the rear of the freezer and has frozen over and causing the water to drain over the condensate collector pan behind the rear wall of the freezer. I have more, Sea Breeze
Oct 16, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerator running. freezer will not go below 40
you need to clean the bottom of frige of dust and water there ,, and if that dont work clean pipe that goes up the back of frige
Aug 10, 2009 | Refrigerators
I have a model ARB2257CSR Amana frige (freezer on bottom) and the freezer is not working I think. there is a sound that comes on and off like the motor maybe is trying to come on... the sound comes from...
Sounds like the overload/relay is going out . If the noise is a " click " , replace the o/relay after checking the 3 terminals on compressor for continuity and each terminal to ground ( copper tubing ) .
Jul 15, 2009 | Amana ARB2257CSR Bottom Freezer...
Fridge not cooling
Is there any frost buld up in freezer compartment?Is your freezer fan running?Need more info You may have a freezing issue you will need to leave doors open over night to make sure it is free of ice .Plug it in in the am and see if it works if it does then it froze up.And will need to replace part .Need more info to let you know what it may be Good luck:)
May 10, 2009 | Kenmore 60721 Refrigerator
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My freezer is working but my frige is not cooling
wrong model # ,defrost problem. remove freezer panel, check heater, check limit switch while still covered in ice, if both ohm infinity, replace defrost timer.
Sep 15, 2008 | Haier HTP18GAA Top Freezer Refrigerator
Bottom Freezer working but not side!
Typically the freezer air is circulated into the frige area to provide cooling. If the circ. fan is not working or the air ducts/channels/dampers are blocked with ice, food, etc. then no cool air will get from the freezer to the frige area. Check all the air channels and to see if the dampers are open along with the circulation fan running. The diagrams at the following link should help you see inside better. If your lower circulation fan is running then you likely have an air return/supply channel blocked with ice and will require an old style defrost (unplug unit and leave doors open for 24 hours to melt ice, etc.). If the fan isn't running then that needs to be replaced. Air channels can freeze up if a door is left open slightly overnight or other moisture enters the freezer/frige. http://www.partselect.com/MultiModels.aspx?ModelNum=ER6AHKXPQ&searchTerm=&RefineSearch=0
Nov 20, 2006 | Whirlpool ER6AHKXPQ Top Freezer...
Side by side freezer
Check that the freezer circulating fan is running. The frige section may have dampers or vents (lets the freezer air cool the refer section) that are open too much. Usually the bottom area in the frige has a control lever to meter how much cold air gets to that section (lots for meat, little for fruits, etc.). Check the owners manual for operation of those vent dampers.
Oct 22, 2006 | Maytag 60ADiW Side by Side Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
120 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
