Question about Vehicle Parts & Accessories
Cannot find autopage valet button - Vehicle Parts & Accessories
What is the valet button on an autopage xt-74?
It may be that it allows the valet to unlock the doors and start the engine while not allowing access to the trunk or other storage.
Jan 18, 2015 | C3RS730 LCD
Autopage xt74 alarm in silent mode
The only reason that your alarm would not chirp when locking and unlocking the doors is that the system is in valet. A visual notification that the alarm is in valet mode is the LED light is on solid. If the LED is on solid and you wish to make the alarm active again, turn the ignition on then, press and hold the valet/programming switch for two seconds. The LED light will turn off.
If the LED light is not on solid then, the issue may be with siren itself.
Sep 25, 2012 | Megatronix - TW71 - 5 Button 2 Way LCD...
RS855LCD 2-way remote and key fob dreain batteries
I see this is a old post but, I have this unit in a used van that came with no remotes. A local audio shop paired it up with a AUTOPAGE XT-33. I can lock,unlock,start with this remote. Just remember to keep the drivers open while doing these steps.
1. Turn the Ignition 'switch 'OFF/ON' 3 TIMES and stay in
ON position. Within 15 seconds.
2. Push the Valet switch 2 times and hold in on the2ndpush, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
Exit: Turn Ignition to 'OFF' position, or leave it for 15
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
The Valet switch is a little Red Push Button that should be
mounted under the lower left side of you dash or in the lower
left kick panel near the E-brake pedal.
Jan 14, 2012 | RS855LCD AutoPage MultiChannel 2 Way...
Somehow buttons seem to have been pressed on my remote and now there are 3 "z"'s that have appeared on the remote and I have no idea how to get rid of it. My remote now doesn't make a...
Turn ignition on, hold the red valet switch down for 2 seconds. Then turn ignition off. Your system is in VALET mode.
The remote start and alarm system will not work when in valet.
Aug 06, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
I am having problems with my alarm/ remote start system. My remote is not comunicating with my truck
I am the senior tech support person for Autopage. You will need to do 2 things. First you need to unplug the antenna and let it sit for a few seconds. Then plug it back in. Attempt to hit unlock on the remote. Next step is to completely reprogram the remotes. This can be done by turn the ignition ON 3 times, and then leaving it in the ON position. (ON/OFF, ON/OFF, ON) then press the RED VALET switch 2 times, and holding on the second push (push valet and release, then push valet and hold). Once the siren lets out a long chirp, then release the valet switch, and program the remote by hitting the LOCK button on the remote itself. Program all your remotes you have, until you have programed 4 remote controls into it. It will cancel any prior remote codes. If you still cannot get this correct, you can call my technical support office at 1-800-945-2527 x600. And i will walk you through it.
Aug 23, 2010 | C3 RS900LCD 900MHz SixChannel Alarm System...
Program remote
REMOTE TRANSMITTER PROGRAMMING
Enter:
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in
2. Push the Valet switch 2 times and hold in on the 2nd
Program:
Jul 09, 2010 | RS855LCD AutoPage MultiChannel 2 Way...
WHY WONT MY ALARM BEEP
your alarm may be in valet mode causing the system to act as a keyless entry system. you can verify this by checking your alarms LED light on the dash, If the light is on solid the system is valet mode
Jun 11, 2010 | C3RS727LCD 4Channel Alarm with Remote Car...
How to re program my pager? (autopage 1000
Enter:
Program:
Jun 03, 2010 | RS1000 OLED 2Way OLED Remote Start w 6...
Need to program autopage 5b remote
Note: This mode will only retain the last 4 remote transmitters programmed. If the transmitter memory is exceeded,
the security system will start deleting transmitters from memory in chronological order.
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in ON position. Within 15 seconds.
2. Push the Valet switch 3 times and holding in on 3rd push until a long chirp is heard then release the valet switch.
3. Press and hold any button of the transmitter until the siren responds with a confirming chirp, indicating the signal
has been stored into memory.
4. If you have additional transmitters (up to 4) that need to be programmed, repeat step 3 for each transmitter.
Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. 3 long chirps & 3 parking
light flashes will confirm exit.
Feb 17, 2009 | Megatronix - TW71 - 5 Button 2 Way LCD...
Vehicle Parts & Accessories Logo
15 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
