Question about Microwave Ovens
My Therabath stopping heating up
It's plugged in, as always, but the unit is no longer heating up. Does it have a fuse of some sort. Can it be fixed?
Kenmore Ultra Wave microwave Model # 665.61652 Quit Working
There are fuses in the unit but why did they go bad? something else has to go bad to cause the fuse to blow, unless the fuse got old or had bad connections at the fuse holder. Can try a new fuse then run and see if it works. Just don't run it empty, just put a container of water in it to test. If it works check all connections and see if any are loose or browned like it has been hot. That's where your problem will be.
Aug 12, 2017 | Microwave Ovens
Hello, I had my RCA rmw 1199 for about 4 months and it just stopped working. Nothing happened to it, it was just in the middle of microwaving and it stopped. We've never been able to get it to operate ever...
Unplug it fully then recheck....Could also be a thermal fuse has gone creating a duel problem with the turntable and Magnatron Heating device ,a cheap fix providing its just a fuse but not advisable to do self repair due to High Voltages within the unit...good luck
Feb 10, 2011 | RCA Microwave Ovens
My microwave just stopped working. No problems until now. In the middle of cooking it just stopped. No display, no beeps, no bouttons working, no light inside. There is power to the outlet I can plug in...
for the microwave to stop suddenly it has blown its internal fuse this is located under the top panel of the unit it should be white with two silver tips ( ceramic fuse) in some cases the fuse will blow for no good reason on the other hand it can be a serious fault the fastest way to check this is to replace the fuse and re test the unit if the fuse blows instantly then bin the microwave if not it the fuse may have simply failed
best of luck always remember unplug the unit first and always replace with same size and and current fuse
please rank this advice if it helped you
Dec 28, 2010 | Kenmore 80402 Microwave Oven
Microwave blowing house fuse, but not right away. Sometimes not, sometimes within 15 seconds, sometimes longer. Any idea what the problem and how to fix? Thanks
PLEASE DO NOT USE OR TOUCH when plugged in. Remove Fuse & UNPLUG IT. The ONLY reason a Fuse "Blows" is due to an Active, to Earth fault. This "Could" place the "Mains" voltage on the "Case" of the Unit, if touched while plugged in it could KILL YOU. Please call a registered professional, to attend to this. It may be in the Unit?, it may be in the wiring?
Feb 10, 2010 | Microwave Ovens
Oven has been working fine. Heating a cup of coffee it just stopped dead. No display. Nothing. Power to outlet working fine. Is there a reset somewhere?
Mine did this when my wife had it on full power for over 10 minutes. We left it set for 15 or so minutes and it came back on. It did the same thing when my niece was heating a liquid with some metal in it. It eventually came back on. There must be a thermal circuit breaker inside the unit. Yours may have a fuse or some sort of circuit breaker inside it, that needs replacing or resetting. Then again some units have a fuse that goes out when the Magnetron shorts out, or goes bad. This would require replacing the Magnetron as well as the fuse.
Sep 12, 2009 | Sharp R-326FS 1100 Watts Microwave Oven
I have a GE microwave, model JVM 3670 BF03. It is an above the range unit. The unit still has power, the clock, turnstyle and fan work fine, but it no longer heats food.
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Aug 18, 2009 | Microwave Ovens
Microwave want heat any longer. Everthing else is
Jul 31, 2009 | Microwave Ovens
I have power to the plug, but nothing to the unit when it is plug
First unplug the unit.
This can be caused by one of two possible conditions.
You may have blown a fuse inside the unit or the thermistor may have blown. You can check them with a simple ohm meter. You will have to take the covers off to access the parts. The thermistor is located at the air outlet. This thermal resistor (thermistor) is designed to open if heated too hot and shut power to prevent fires. You can see a diagrams at;
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=260464
It's usually the thermistor.
The parts can be purchase at electronics stores like Radio Shack.
Mar 30, 2009 | Whirlpool GH7155XHS Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Danby 1000 Watt Microwave is completely dead. Just stopped working right after heating up a dinner.
you may have just blown a fuse inside the microwave or the transformer inside has now failed and will need replacing but it will need to be looked at to see what exactly happened
electech
Nov 27, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
