Question about HP LaserJet 1320 Printer
Can't find it on the network
I have a HP Laserjet 1320N. It is connected to the network and, at some point in the past, I was able to make one of the computers in the office connect to it ("WORK1" is the name of the computer). Subsequently, every time I add a new computer, I have to make it talk to the printer *through* WORK1. I really just want to connect directly to the printer... after all, that is why we bought a network printer. However, when I try to BROWSE (we're using XP pro) it never will see the printer. I did push the reset button to make sure the IP address is set: it is. When I try to input the IP address to just "go there" (rather than browsing) it still can't find it. The driver is no help at all. Am I missing something? Thanks, Sam
  • DWDpcRepair May 11, 2010
    have you installed the HP software on each computer you plan on printing from. Possibly a firewall setting not allowing the devices to communicate?
  • HP Master
  • 4,338 Answers
First step is to make the IP address in the printer a static IP. This is done via the printer's control panel menu. Once you know the printer's IP address, you can access it's setup page via the web by typing in the IP address into a browser.
Then you can setup the printer on each computer by adding it by it's IP address rather than trying to have XP search for it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 20, 2009
HP LaserJet 1320n Printer connected with usb to pc running on windows7; faded printing; economode = off; printer Density =3; what could be the problem
Faded printing is usuallly caused by an empty or defective toner cartridge. If the toner is new and the printer was working fine before the toner change then you might have a defective cartridge, or you may not have removed the tape strip from the cartridge when you installed it.
Oct 15, 2011 | HP LaserJet 1320n Printer
I am trying to install my HP LaserJet 1320n printer. However, after I select the correct printer port, it asks me to select the software to install from a list. I have Windows XP and the HP LaserJet...
Go here and download the North American full printing solution. This is exactly the same as having the CD and will self install the printer when it runs, just make sure the printer is disconnected when you start the install. Or you can just download the driver and then point the install to the driver file.
Apr 15, 2011 | HP LaserJet 1320n Printer
I have 1320n printer but i cannot print in network plz solve
YOUR PRINTER IS NOT SHARED ON THE NETWORK FIRST GO TO THAT COMPUTER WHERE IT IS INSTALLED AND GO TO "PRINTER AND FAX" OPTION RIGHT CLICK ON 1320N PRINTER THEN SELECT PROPERTY THEN SELECT SHARE OPTION AND CHECK THE OPTION "SHARE THIS PRINTER".
Jan 19, 2011 | HP LaserJet 1320 Printer
Set up Hp laserjet 1320n & manual
You can get the manual here: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=18972&prodSeriesId=410622
Jun 24, 2009 | HP LaserJet 2420 Printer
Hello, I have a HP laserJet 1320n, I try to connect it to windows vista... but it fails to connect.. how can I solve this problem,,,
does it connect (with the same cable) on another PC? Have you tried anther USB port? Could the cable be bad?
if it is, an HP1320N, perhaps try connecting it through a tcp/ip port if you can't solve the USB problem?
Mar 20, 2009 | HP LaserJet 1320n Printer
How to wirelessly access HP Laserjet 1320n via Apple iBook
You need to disconnect the USB cable and set it up wireless on both units:
Since it is plugged into the router, it should already have an IP address.
Un-install the printer from the computers.
Then re-install the printer from the cd or from HP's website. When you get to the point where it ask you is the printer is attached to the computer or is it over the network. Choose over the net work and the software will find the printer IP and finish setting it up wireless.
Thanks, Joe
Mar 13, 2009 | HP PhotoSmart 1215 InkJet Printer
Hp 1320n cant print jobs simultaneously from different users
You may need to add memory to the printer so it can que the jobs. The memory is very cheap...128MB 100-pin DIMM for HP OEM# C9121A
Or...you could setup a printer server que and let the print server manage the jobs for you instead of having the printer hold the que.
Dec 09, 2008 | HP LaserJet 1320n Printer
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
TRYING TO CONNECT HP LASERJET 1320N TO COMPUTER
unplug the usb from the pc and power down the printer,
then power it back up and plug in to pc see if the computer sees it and then continue the install of the drivers
Dec 06, 2007 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
720 people viewed this question
Seeker5211
Seeker5211
