Question about VXI Corporation Blueparrott B250-XT Bluetooth Headset
When I power on it says power on bt flashes red and won't worku
4 digit TV code to set up to BT youview
You might need to reset the remote control if the codes don't work.
If you've got the BT YouView remote that came with the box (with the 'BT Vision' button on it), hold down the two buttons either side of '0', whilst also holding down the power button for around 5 seconds. The blue light on the remote should flash three times to confirm it's successfully reset.
If you've got the retail YouView remote (with the 'TV' and 'PVR' buttons on it), press and hold the 'TV' button and the red coloured button at the same time for 5 seconds. The 'TV' and 'PVR' buttons should flash red 3 times to confirm.
Try your codes again after. I believe 4483 is the code in the setup guide.
May 28, 2015 | Televison & Video
How to configure
For Bluetooth,pull Aux cable out,turn on power at rear of unit,then hold down the power button for several seconds until the LEDs start flashing blue/red.Turn on BT on the sending device and scan for other devices. When the blue/red stops flashing,they are paired.Hit Connect on your phone and it's good to go.
Sep 27, 2014 | Video Cameras
My iPad won't find my Bluetooth speaker
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
Jan 14, 2013 | Harman Kardon JBL Flip black
My tv the light is flashing red green an won't
replace the power supply board. You can get replacement power supplies from www.tvcircuitboards.com
Mar 07, 2012 | LG Televison & Video
Bt studio 1000 phone, the answer phone has stopped bleeping and just flashes
My Answer Phone is full up and the green light and red light is flashing all the time
BT Studio3500 twin
Apr 20, 2010 | British Telecom Lands Phones
How do I get my Uniden BT-109 in discoverable mode ? I have a new cell, and am trying to pair it with the phone , and have no manual?
First, make sure the device is charged and turned off. Hold the power button down until the LED flashes red and blue. The phone will then be in pairing mode.
Mar 16, 2010 | Uniden BT-108 Bluetooth Headset
Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Aug 19, 2009 | TDK Audio Players & Recorders
BT-710 headset clip mini II
Go to your bluetooth settings and make your phone discoverable, normally you need to hold the power button down on your headset until it flashes red and blue, then you will need to select the headset on your phone, the default code is usually 0000
Jul 30, 2009 | Nokia Cell Phones
CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
Apr 19, 2008 | Radio Communications
VXI Corporation Blueparrott B250-XT Bluetooth Headset Logo
12 people viewed this question
Top VXI Corporation Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a VXI Corporation Radio Communication Expert? Answer questions, earn points and help others
