Question about NetGear WN3500RP Dual-Band WiFi Extender
Having trouble connecting my wifi extender
I can't seem to connect my extender to my wireless device
rahul26485
  • 611 Answers
SOURCE: router
there is no other devices signal affect to your wireless .do one thing reinstall ur wireless adpator
Posted on Jun 03, 2008
  • 117 Answers
SOURCE: Can't connect wifi with my NetGear WNR3500 Router
which operating system, you are using
Posted on Mar 18, 2010
  • 10 Answers
SOURCE: i have installed Usb wifi device not able to connect to internet
you need the latest 3rd party driver, it fixed me up. download it here: http://proaudiosoft.com/wg111v2.html
Posted on Apr 27, 2010
MUKHTAR
  • 2017 Answers
SOURCE: My main computer has access to the internet but
make sure in router you configure ssid correctely and it is available to for other .just reconfigure the router .
Hope this helps. Please rate my response.
Thanks.
Have a good day
Posted on Dec 27, 2010
TechyDrood
  • 2072 Answers
SOURCE: how do i get a netgearn300 router to get a connection from a wifi device
Well connecting to your router is simply a matter of joining your wireless network. When you try and connect to the PS3 the router will automatically route your traffic to the PS3. The real question is does a PS3 support SMB or CIFS (file sharing protocols) that windows will understand. If it does just enable them on the PS3. Then in Windows open up "Computer" and click "Map a Network Drive", select a drive letter to map to on your local computer and for an address it will be in the form \\<PS3 hostname>\<share name>
Posted on Nov 23, 2011
My Netgear WN3000RP Wi-Fi Range Extender is not working since last night . please help
Try unplugging BOTH the repeater and the router, Then, plug the router back in and let it establish a connection. Then, plug the repeater in and let it reestablish the connection.
Feb 03, 2015 | NetGear Universal WiFi Range Extender...
What kind of wireless access point or extender should I use to project wifi in far bedrooms of a long, train-car like house?
Hi James, the wireless extender is the best way but you should go for the plug in type.....this plugs into the mains and gives you wifi and 1 wired connection, so you can plug into the room you want wifi to reach, I have linked a Netgear option but there are others! EX2700
Jan 18, 2015 | NetGear Computers & Internet
Why doesn&#39;t my netgear extender ask for name and password when I try to use it to connect to internet. It tells me that there is an authentication problem
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-...
Oct 26, 2014 | NetGear N300 Essentials Edition Wi-Fi...
HOW DO I CONNECT MY EXTENDER THROUGH WIFI
It need to be wire connected to another router, once it has an IP you can access the device with a web browser and configure wireless access pretty much with the same information as your actual wireless access point, same network ID and key.
Aug 13, 2014 | NETGEAR CONSUMER New - Netgear Wn2500rp...
How to set up netgear ex6100 wifi range extender
Overview:
This article describes how to set up a NETGEAR EX6100 in Extender Mode
The extender connects wirelessly to your existing WiFi network, and then it creates a new WiFi extended network and links the two WiFi networks.
Symptoms:
Cannot connect to extender
Extender broadcasting EX6100_NETGEAR_2GEXT
Extender broadcasting EX6100_NETGEAR_5GEXT
Extender cannot access Internet or network
Process:
1. Place your extender in the same room as your WiFi router.
2. Plug the extender into an electric outlet and wait one minute.The PowerLED lights green.
If the Power LED does not light, press the Power button on the side.
3. Make sure that the mode switch on the extender is set to Extender.
4. Use a WiFi network utility on a computer or mobile device to find and connect to the EX6100_NETGEAR_2GEXT or EX6100_NETGEAR_5GEXT (SSID) WiFi network.
Note: EX6100_NETGEAR_2GEXT and EX6100_NETGEAR_5GEXT are the default name of your extender's wireless networks, and by default it is unsecured. If you changed the wireless name or security in the past, connect to the new name or enter the passphrase when prompted. EX6100_NETGEAR_5GEXT is only visible if your wireless adapter is 5 GHz capable.
After the wireless connection with the computer or mobile device is established, the Client Link LED lights solid green.
5. Open a web browser window from the same computer or mobile device.The browser takes you directly to NETGEAR genie Smart Setup.
Note: If you are not automatically directed to NETGEAR genie, launch an Internet browser and type www.mywifiext.net in the address field of the browser. Enter admin for the user name and password for the password.
6. Select a 2.4GHz WiFi network to extend and click the Continue button.
7. Type the network passphrase (also called password or security key) in the Passphrase field and click the Continue button.
8. Repeat steps 6 and 7 to select a 5GHz WiFi network.
Note: If your router does not support the 5GHz band, click the Skip button.
9. Select Private Network(home network) or Public Network radio button, and click Continue.
Note: Selecting Public Network will enable NAT and DHCP on the EX6100. For more info on NAT refer to: What is NAT (Network Address Translation)?
10. Type the name (SSID) for your WiFi extended network in the 2.4GHz and 5GHz Network Name (SSID) field and click the Continue button.
Note: You can use the same security settings as your existing network by selecting the Use the same security mode check box.
The WiFi extended network settings are applied.
11. Use a WiFi network manager on a mobile device or computer to connect to the extenders newly created WiFi network.
12. Click on the check box and click on Continue to finalize the installation.
13. Unplug the extender and move it to a new location closer to the area with a poor WiFi signal.
Note: The location you choose must be within the range of your existing WiFi router network.
14. Plug the extender into an electrical outlet and wait one minute. The Power LED lights green. Connect to the extender network and enjoy the extended Wifi network.
May 02, 2014 | Computers & Internet
How can i boost and speed up my Wifi network reception ?
Firstly download WiFi Analyser from Google Play store and compare you WiFi with others in your area. This will enable you to change the channel. Change channel by logging into your router - 192.168.1.1.
Try moving your router to a more central place in your home and use the analyser to check if any improvement.
Next try a wireless extender. This will drop your speed a little but give a stronger signal in weak areas.
Also try power line adapters.
If you are using a few devices ensure that you are not mixing wireless g and n products at same time. Using a g product will mean that your whole wireless will be running at that speed even when your other device is n. If you need both connect another g router to one of the n router LAN ports with dhcp disabled. That way you can have the two devices connected at the correct speed.
Some routers will let you connect a bigger aerial which could boost you reception. Some devices have very poor wireless antennas - seems you what you pay for in this area.
Apr 16, 2014 | Android Apps
Mywifiext net welcome
You can't connect the range extender to the wireless router or you can't connect your wireless devices to the range extender?
If its the router what is the name and model of the router?
Nov 19, 2013 | Computers & Internet
Expand range extender
You can install a wireless range extender. Try a Netgear Dual Band WiFi Range Extender, this device extends the wireless range of your existing wireless router, it connects to your wireless router using a wireless connection without the need of a LAN cable.
May 19, 2013 | TP-LINK TL-WR1043ND Router
I cant access the 192,168,2,1
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-... Hope i helped you.. great day to you.
Jan 30, 2013 | TENDA A3 150Mbps Wireless Range Extender
NetGear WN3500RP Dual-Band WiFi Extender Logo
132 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
