Question about Proscan PS32600 32" TV
Power cycles on and off - Proscan PS32600 32" TV
    Top Expert:
  • Proscan Master
  • 75,581 Answers
Short circuited component/s at its main board. Contact any service technician. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Posted on Jan 02, 2014
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
Without doing the minimal setting test to see if a time clock works how do you test a time clock with defrost termination the x terminal
8145-20 is 240Volt defrost timer:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#8045
You are testing the 8145-20 timer.
The timer dial should rotate continuously. Trippers on dial rotate around. When they reach the trip switch, the timer starts the defrost cycle.
Terminal 3 has power during defrost cycle.
Terminal 4 has no power during defrost cycle.
With 240Volt timer, terminals 1 and 2 and N and X test for live power to ground at all times.
The limit switch is connected to terminal X and to terminal N.
During the defrost cycle, the limit switch measures the pressure or temperature.
When pressure or temperature reaches the set point, the limit switch closes the circuit and this trips the solenoid inside timer. The solenoid turns off the timer relay, and the defrost cycle ends.
At this point the timer turns off the defrost, and sends power to the refrigeration.
Terminal 3 has no power during refrigeration cycle. (The opposite of defrost cycle).
Terminal 4 has power during refrigeration cycle.
Test these terminals for power to ground. One or the other should have power at all times, but not both.
If timer will not enter defrost cycle, make sure the X-3596 trippers are not worn down.
Disconnect the wire to terminal X and see if defrost cycle will start.
Test terminals 3 and 4 again and see if removing wire from X caused a change.
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 14, 2011 | Paragon 8145-20 Defrost Timer
Intrmitant problems with broadband and phone
This is fairly common problem. Usually broadband problems are resolved by power down and power up this is called power cycling. Modem and router should be power cycled when ever you have problems with broadband. The phone (IP Phones) are as good as the internet service itself. These phones come with a modem which should be power cycled as well. Checking cables is part of the ritual.
good luck!
Sep 10, 2011 | Computers & Internet
What is cycle power? My printer can't work!
its just a defination for ur question Power cycling is the act of turning a piece of equipment, usually a computer, off and then on again. Reasons for power cycling include having an electronic device reinitialize its configuration or recover from an unresponsive state of its mission critical functionality, such as in a crash or hang situation. Power cycling can also be used to reset network activity inside a modem. Power cycling can be done manually, usually using a switch on the device to be cycled; automatically, through some type of device, system, or network management monitoring and control; or by remote control; through a communication channel. In the data center environment, remote control power cycling can usually be done through a Power distribution unit, over TCP/IP. In the home environment, this can be done through home automation powerline communications, via IP protocols (wired or wireless), or by phone line.
Mar 12, 2010 | HP PSC 2410 All-In-One InkJet Printer
Cycles on and off
check the power cables and make sure about power fluctuation issues on your eletric system. the power cable may be loose of cut from inside-out. if it's a malcontact issue, try to use something to keep the power cable in place. duct-tape may help. that's the solution i can give you by your description. try to solve this as fast as you can, since this power-on and power-off cycles reduce considerably the monitor's lifespan.
Feb 06, 2010 | Liquid Video Computers & Internet
Power light flashin orange, status light flashing red on WT610 NEC
if the status light is flashing .5 seconds on and 2.5 seconds off - you need to replace the lamp cover correctly.
if the status light is flashing .5 seconds on and .5 seconds off in 2 - 6 cycles the error is: 2 cycles - the projector is overheated. Move the projector to a cooler location, or/and remove dust in the light path. 3 cycles - the power unit is not working correctly. 4 cycles - the fans are not working correctly 5 cycles - lamp fails to light. Wait a full minute and then turn on again.
Jan 25, 2009 | NEC WT610 DLP Projector
Hoshizaki KM-450MAB Ice Machine
maybe not. it could be that the heating cycle is taking a lot of time to remove the ice from the evaporator that is why the electronics is shutting off the compressor as a protection. check the heating cycle if it is working fine. check the evaporator for dirt that would hold the ice slab from falling down quickly. check the level of the unit. it may have move and now its out of level. the unit must be leveled with the ground.
Feb 21, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Proscan PS32600 32" TV Logo
29 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
